Question about Sony KP-46WT510 46" Rear Projection HDTV
Convergence problem I need to wear 3D glasses when i watch my Sony KP-46WT510, please help.
  • felys2000 Jan 30, 2009
    Color messing up picture messed up.
  • Sony Master
  • 8,617 Answers
You need to replace the convergence ICs, pico fusses and possibly a couple of the feed resistors. you can get the kit for your model at the following link which contains the parts and instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/sony-kp46wt510-convergence-repair-kit/cName/convergence-repair-kits
Posted on Feb 01, 2009
My sony tv model # KP-46WT510 the picture bows to the middle i tried fixing the convergence and it does nothing what else should i try
If the convergence feature did not fix the issue then you will need to install a convergence repair kit. Your model uses the Sony type 1 convergence repair kit which is available from www.tvrepairworld.com and includes the parts and the CD with instructions.
Aug 28, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
Hello i have a sony KP-46WT510 model 45" TV, and
Below are two of the most common problems encountered with projection TV sets.
Problem #1 - CONVERGENCE PROBLEM
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on Projection TV sets and a fairly simple DIY fix.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
47a7bc4.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from TvRepairKits.com
Their kits include a step by step instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Problem #2 CRT Fluid is Cloudy
Projection tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around video.
Pic of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
BEFORE
Set after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
AFTER
724bcba.pngSolution #2 - CRT FLUID FIX
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc
Feb 18, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
I have a red shadow in 3d on sony KP-46WT510 TV.
Ur convergence is dead.Problems:Are 3D colors,colors misaligns,and colors out of focus.Know how to solders?Must change 2 convergence ICS,and some or all the resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
Feb 17, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
The STK392-560 ICs have gone bad. They need to be replaced by a qualified TV2_bing.gif technician. The repair cost is from $200 and up.
Best of Luck
Nour BMI
Feb 17, 2010 | Sony Televison & Video
Focus issue after replacing convergence IC's
pull the fron grill off the set then remove the cardboard covering the hole that is in the front of the set you will find a square box that has 6 controls on it adjust the focus for the red, blue and green crts, do not adjust the three marked screen control.
Sep 10, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Sony projection tv convergence problem
You need to replace the convergance IC's and a pico fuse on the power supply
Sep 03, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
My sony wide screen projection model kp-46wt510 has a red shadow
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jan 20, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
RGB lamps are not aligned
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Jan 18, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Picture looks curved (concave curve) on my sony KP-46WT510
You may have a convergence problem. Here are some of the most common symptoms and example photos.
  • Screen looks 3D
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
May 21, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Red ghosts
red convergence went haywire... you need to relace I'm thinking two convergence ICs mounted on heatsink on convergence panel. replace both for usually they both blow replace any burnt resitors too, and hardest of all now you need to reconverge the whole thing.....which is a fine art.....u might be able to do it with the remote ...but u need a manual to go throught the steps really ..but not me i do em in my sleep. take it to shop unless your technical.
Aug 17, 2007 | Sony KP-53HS30 53" Rear Projection...
Sony KP-46WT510 46" Rear Projection HDTV Logo
169 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
