Washer wont fill - Washing Machines
  • Washing Mach... Master
  • 17,129 Answers
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Posted on Jan 24, 2013
Washer machine front loader wont fill up and wont drain
it maybe that the pump winding is open circuit some machines use the pump winding as the neutral line for the water valves so if the pump fails they wont fill no point in it filling if it wont empty
Mar 09, 2014 | Indesit W 123 Front Load Washer
Why wont the washer start filling ?
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 25, 2010 | Kenmore 23822 Top Load Washer
Washer wont fill
heatman101
dhjd
May 20, 2010 | GE WBSE2090A Top Load Washer
Washer wont agitate or stop filling on any setting
Hello Friend, Just replace the water pressure/level switch. Replacement will make it fill correctly and agitate. Happy to help.
Nov 18, 2009 | Kenmore 24712 Top Load Washer
Washer filles with water but wont change cycles
start filling the washer on the warm cycle,turn washer off,if the water keeps filling then you have a bad water inlet valve,if it turns off then you have a loose water level hose or the water level switch is bad-mike
Jul 21, 2009 | Kenmore 22422 Top Load Washer
Washer wont initially fill. all other operations
Check the screen on the inlet hose from water fill. If not, it is the timer that you set (it's not functional)
Jul 08, 2009 | Kenmore Washing Machines
Water wont fill washer. The water currently in
The pump is probably clogged with a coin. Pull off the hoses and check the pump. Make sure you put a pan under the hoses to catch the water
Jun 27, 2009 | Frigidaire Washing Machines
Washer fills up but wont spin
roof, if it fills and just sits there it could be the pressure switch, grab the end caps on each side of the consol and pull them off. Remove the two screws under them and flip the consol up. On the left side you will see the pressure switch with a rubber tube going to it. Get yourself a piece of tubing about the same size in diameter. After the washer fills, remove the tube from the pressure switch and blow into with the spare tubing. If the washer starts agitating, the pressure switch is the problem. Catriver.
Sep 29, 2007 | Kenmore 13202 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
