Washer wont spin or drain
So a few days ago my washer just stopped mid cycle and will not drain or do a final spin. I did some looking and it said to check the pump and drain hoses. so I took it apart and checked the hoses and pump for ant ojects in the way. It appeared to be clear. It was making a humming noise for a little while then stopped and now it just doesnt do anything on any of the cycles ie* perm press delicate. It will only fill and agitate. Please help i really need my washer! Oh also i read it could be the lid switch?
  • Washing Mach... Master
  • 17,129 Answers
Yes, you can check the LID switch as it needs to activate the program to move forward. If the water fills up and there is no wash cycle, check if the motor hums, if so check the capacitor, check the friction on the spindle/drum. If the spindle does not agitate with movement the assembly must be reset.
Posted on Jan 24, 2013
watugot
  • 290 Answers
SOURCE: Kenmore 80 series won't spin
If it is draining then the motor is turning the pump so it is ok.
This washer has no belt so that is not the problem.
Remove the cabinet and bypass the lid switch wires and put into a spin. Watch the clutch to see if it is turning. If the clutch housing is not turning and you know for sure the coupler is not broken then you need a new transmission. If the clutch housing is turning but the basket is not spinning you have something binding the basket or you need a new basket drive and clutch.
If you have only looked at the coupler from underneath you may not be able to tell if it is broken in the center. If it is broken again your transmission is not staying in neutral drain until the water is drained. That means it is going into spin with full load of clothes and water. This puts a lot of pressure on the coupler and causes them to fail prematurely. If this is the case you will need a new transmission.
Post back if you have any questions.
Posted on Nov 05, 2007
  • 209 Answers
SOURCE: wont drain
I am a retired engineer of 20 years and the problem is the pump, remove plug from wall,drain the machine by hand first, remove the bottom back of the machine and test the 2 connectors on the pump for a circuit with a multimeter assuming you have the ability, an open circuit means a new pump is wanted, it may also be blocked / remove and clean out all bottom pipes and check inside pump for rotating impeller movement, it must be free to spin, if readings on meter are fine, build up and try again, work with safety, water and electric don't mix, also it may be that a wire has come off, check that first sorry,
Posted on Sep 09, 2007
SOURCE: Kitchenaid Washer Model #KAWS700JQ4
Washer has a motor coupler linking motor to transmission. If this motor coupler is broken or has rounded out where it engages the motor and/or transmission gear it will only fill and drain. You can view this coupler by leaning washer back against the wall & looking underneath with a flashlight. There may be a sound dampener panel on the bottom that you have to remove to see it. It is two pieces of white plastic with a rubber grommet in the middle.
Posted on Dec 16, 2008
jumptrout51
  • 3361 Answers
SOURCE: will fill and drain wont agitate or spin
Replace the lid switch.
Posted on Mar 11, 2009
  • 240 Answers
SOURCE: No Spin No Drain
Lid switch is most likely the problem, if lid switch is visible under lid on right side then this is older design and common problem switch.
if you have console frame covers on front sides, snap off from top, a screw is at bottom front corners of console, remove and pull console forward and fold back. If lid swich is hidden then you will see it at left on top of cabinet with console folded back. a 5/16 screw holds a green ground wire to cab. remove and switch will unclip with lid up. If lid switch was visible under lid then you need to remove 2 brass clips holding cabinet on top of base to back, pry with screwdriver to unclip. undo harness connection on cabinet top, this is your lid switch connection. sw body is held by 2 phillips screws, harness tube held by clips on underside of cabinet top. ground wire with 5/16 screw present at sw body. New versions of this switch have metel shield attached.
Posted on Apr 26, 2009
Doesn't work. Why does it stop mid-cycle?
washing machine stopped mid cycle, won't drain : DIY - Reddit
https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
Troubleshoot - washer stops mid cycle, won't drain or spin ...
? 1:58
https://www.youtube.com/watch?v=6Gc0ZgLD6a4
Jun 20, 2012 - Uploaded by searspartsdirect
Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
Why does my washer stop half way through cycle - Ken
Dec 18, 2015 | Washing Machines
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
I cannot get my washer to drain. Its stops and starts beeping
Sometimes the pump gets a bit clogged. Tip the machine back so you can see underneath (best if it is empty!) and spin the fan attached to the pump a few times in each direction with your finger. Then see how it goes. I saw this solution on a forum a year or so ago and it worked well for me.
Jun 25, 2010 | Fisher and Paykel GWL11 Top Load Washer
I am getting a vibrating noise from my washer right before the final spin. Levleling looks good. This happened a couple days ago. We drained out the water and the washer would work again, but would stop at...
It sounds like you could have multiple issues but a possible cause of the vibrating right before the final spin is a broken shock absorber if one or both are gone it will throw off the center of gravity inside the machine and allow it to move freely and at high speed or even low speed this is not good. part number for both shocks is 134560400. If your machine just stops before the spin cycle and only drains, you could have a faulty door switch. the washer will not spin for safety reasons if this is gone. part number for the door lock switch is 131763245. as well the striker that hits this door switch can be broken and sometime pieces will be left inside the mechanism. part number for the striker is 134456640. The last cause of your washer not spinning could be a motor speed control board, if this is faulty, the motor will not receive the proper amperage to send the motor into spin cycle. speed control board part number is 134409904. Hope this helps.
Thanks
Oct 12, 2009 | Frigidaire Affinity ATF7000E Front Load...
Washer stops in mid cycle
This is probably normal. There is a natural pause between agitating and draining, and again between draining and spinning. Hope this helps!
Feb 04, 2009 | Whirlpool LTE5243D Top Load Stacked...
My whirlpool duet washer indicates "5d"...
unplug.
open the bottom panel,3 screws on bottom
check the drain plug ,
remove the plug , mop up water ,
look inside for clogs ,
look above the ball,
look inside the propellers, spin the pumps propeller by hand.
reassemble.
close panel.
finally .
feel around the inside of the front rubber gasket for items.
Oct 27, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore he2 front load washer
remove bottom panel open pump port and ck for foreign objects lean washer toward rear wall this will help help keep water toward rear and reduce flooding floor might try opening door first and dipping out as much water as possible with bottom panel removed reach up to lock area there is a tear shaped plastic peace pull it down to release door
Jun 02, 2008 | Washing Machines
Washing machine won't drain
replace the lid switch. that's what i have to do with mine. i researched it a few weeks ago. Simple cheap fix - i think it was about $20
Mar 17, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
It sounds like you may have some bad contacts in the timer or you may have a bad lid switch which will not allow it to go into a spin during the rinse cycles or the final spin.
Oct 30, 2007 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
104 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
