Question about Dell OptiPlex Computers & Internet
DELL OPTIPLEZ 740 SEEK FAILURE - OptiPlex Dell Computers & Internet
SOURCE: floppy diskette seek failure
F2 Scroll down to "Drives" and open the menu. choose "Diskette Drive" and turn it "Off".
Posted on May 19, 2008
SOURCE: diskette drive 0 seek failure
My guess if it's new is that it doesn't have a floppy drive but thinks it should.
Enter BIOS setup by hitting F1, F2, Del or similar at startup (there should be a message saying Press <some button> to enter setup).
Then it will depend on your BIOS (they're all different) but you either want to tell it there isn't a floppy drive or tell it not to check for one, or tell it not to display errors if it doesn't find one.
Unfortunately all BIOS's are different so I can't tell exactly what setting you're looking for.
James
Posted on Aug 30, 2008
try to go to bios set up..then change the boot order..in the boot tab,,change the "first boot" label with hard disk..then it wont seek for floppy again..
Posted on Jan 05, 2009
MGCO420
  • 11 Answers
Boot into setup by pressing F2 or F10 depending on your bios and disable the floppy drive setting.
Posted on Jan 14, 2009
tbirdfan1
  • 3051 Answers
SOURCE: Floppy Diskette Seek Failure on boot up
Hello there:
This is a setting in the bios , so what you are going to have to do
is boot into bios and under the boot section and check to see if the floppy drive is a option that is part of the boot sequense if it is change it so that is not part of the boot sequense than go under the periphial section and check to see if it is showing up there as a removable device if so change it or disable it all together since you do not have a floppy drive ok
and this should take care of he problem
I hope that this is very helpful for you
Best regards Michael
Posted on Dec 06, 2009
My dell c521 says diskette drive 0 seek failure
You need to press f2 then go to Standard CMOS Features, then highlight drive A. Change it to none. You should not have anything in there enless you have floppy drive
Jan 14, 2014 | Dell Dimension C521 PC Desktop
My dell optiplex 740 hdd is locked service tag number is 585hw2j
Dell Beep codes
Code
Cause
1-1-2
Microprocessor register failure
1-1-3
NVRAM read/write failure
1-1-4
ROM BIOS checksum failure
1-2-1
Programmable interval timer failure
1-2-2
DMA initialization failure
1-2-3
DMA page register read/write failure
1-3
Video Memory Test failure
1-3-1 through 2-4-4
Memory not being properly identified or used
3-1-1
Slave DMA register failure
3-1-2
Master DMA register failure
3-1-3
Master interrupt mask register failure
3-1-4
Slave interrupt mask register failure
3-2-2
Interrupt vector loading failure
3-2-4
Keyboard Controller Test failure
3-3-1
NVRAM power loss
3-3-2
Invalid NVRAM configuration
3-3-4
3-4-1
Screen initialization failure
3-4-2
Screen retrace failure
3-4-3
Search for video ROM failure
4-2-1
No timer tick
4-2-2
Shutdown failure
4-2-3
Gate A20 failure
4-2-4
Unexpected interrupt in protected mode
4-3-1
Memory failure above address 0FFFFh
4-3-3
Timer-chip counter 2 failure
4-3-4
Time-of-day clock stopped
4-4-1
Serial or parallel port test failure
4-4-2
Failure to decompress code to shadowed memory
4-4-3
Math-coprocessor test failure
4-4-4
Cache test failure
Oct 08, 2012 | Dell OptiPlex 740 PC Desktop
Dell optiplex 745 Floppy Diskette Seek Failure
how to solution. Dell optiplex 745 Floppy Diskette Seek Failure
Jan 20, 2012 | Dell Computers & Internet
Diskette Drive 0 Seek Failure This seems to be a
You are missing the OS.
If you have the restore CD's, use them to restore your Dell to original state, or you can order a set from Dell.
If you do not have a restore CD's you can also boot with a Windows CD and install the OS but you will have to go to the Dell website and download the drivers for your model.
I hope this helped.
Good luck and have a pleasent day.
Jun 20, 2011 | Dell Inspiron 530 Desktop Computer
Boot up screen says "diskette drive 0 seek failure"
Press F2 look through the menus and remove / disable 3.5 floppy drives.
Jan 06, 2010 | Dell Dimension 8400 PC Desktop
Te drive O seek failure
Drive 0 is the first hard drive.
If you are getting a seek failure, your hard drive has gone bad.
Oct 06, 2009 | Dell Inspiron 530 Desktop Computer
New sata hdd seek failure
If you dont have a floppy drive is it disabled in bios.
Are you sure your power supply is powerful enough?
If none of the above then return the hdd - its faulty
Apr 24, 2009 | Dell Dimension 4700 PC Desktop
Floppy diskette seek failure
Jan 14, 2009 | Computers & Internet
Jan 03, 2009 | Dell Dimension E310 PC Desktop
My pc go to diskette drive 0 seek failure
U'r hard drive is not communicating with the system. Open the pc (power off) and check the cable connections. While U'r there, clean with blow or vac. U'r HD may have died. The data may still be there and got to with a new hd.
May 23, 2008 | Dell Computers & Internet
Computers & Internet Logo
299 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
