LG Studioworks 45 14" CRT Monitor Logo
Posted on Jan 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Re trace lines in 14'' CRT
Found Re- trace lines in 14'' CRT.When we open the gun we noticed that heater is damaged and holes observed on cathode walls.
Anonymous
Level 3:
  • Master 6,784 Answers
  • Posted on Jan 28, 2009
Anonymous
Master
Level 3:
Answers
6784
Questions
Helped
2972265
Points
24702
This monitor will unfortunately have to be replaced. the repair parts will take some time to order. try the troubleshooting charts on the LG website.
Anonymous
Level 3:
  • Master 2,071 Answers
Anonymous
Master
Level 3:
Answers
2071
Questions
Helped
1015324
Points
5371
Just unsoldered CRT socket from circuit board ,when taken already clean the socket used a sand paper and laquer thnner or alcohol to clean socket very well and rebuild or simply resoldered all soldered joints parts in the CRT board. In vertical section replaced all the electrolytic capacitor there .If retraced line still exist thats the time you replaced the CRT .Feel free whatever the result.
Hope it may help you;
Regards;
VOTIT
What couses red diagonal line and red back ground picture on my toshiba television.
short on crt board check driver transisters on crt board if you want to confirm then switch them with green gun transisters from crt just swich them and see if next coclor show difrent if yes transister bad if not open crt cathode from red side to see if crt cathode shorting
2answers
There are re-trace lines across the CRT.
check the G2 ,if to high retrace lines wil be vissable.If ok check the RGB,12V on picturetube panel.
Are the lines in one collor then check the circuit of theat collor
tip
SONY TRINITRON ONE COLOUR PREDOMINANT SCREEN
Sony Trinitron sets are of CRT [Caothde Ray Tube] types. The common fault seen in these type of TVs are any one colour predominant on screen wih sound OK. Either red, blue or green colour with some thin horizontal lines at about an inch apart will be seen on the entire screen. This is totally a display card problem, which can be seen pluged onto the picutre tube neck. There are three electron guns for every picture tube, which emits red, blue, and green beams, which in turn illuminates the phosphor on the screen to get that colour. If no emission from all guns, results in a blank screen, ie black screen without any disply at all. The three colour beams together produces proper coloured picture what we see on screen. These three gun's terminals are brought out by pins of the picture tube outside to which video signals are given in appropriate proportion to produce a TV picture. Normally, all these three pins are biased with a voltage of about 170 to160VDC+ve. Take one colour gun, as an example and and let me describe the problem.
Let it be a green gun. These guns are called cathodes of the picture tube. If it gets a voltage with respect to its grid, it will emit electrons according to the voltage applied to it. This is a negative process, that is, as the voltage at this pin drops, its emisson incresses and vice versa. If the emission increase, the colour with respect to that gun also will increase and gets predominant at the screen. So when we see a green predominant screen, there will be less voltage at the green cathode with resepect to the other two. If red colour is predominant, the voltage at red cathode will be less than the other two. If blue colour is predominat, the voltage at the blue cathode will be less than the other two.
We must find out the reason for this fault first. Assume that your Tv has a red predominant screen with some thin lines across it, at about one inch apart of the entire screen, it is clear that the the red cathode voltage is very lower than the other two. the main reason for this fault, normally seen in most of the Sony Trinitron, are loose soldering points either to the picture tube base socket or the resistor connected between the red drive transistor's collector point. Resoldering the most of these points on the base card by applying a little more solder will rectify this probelm. Other possibility is shorted video output transistor of that cathode. A direct short [collector to emitter] of these transistors will drop volatge to very low at that respective cathode of the picture tube, and that colour will be pridominant along with lines. Replacing the transistor will solve the problem. In some cases, the resistor connected to that transistor may have blown out. If so, it should alo be replaced. Whatever the case may be, voltage at the respective cathode that emits colour will be very low with respect to the other two. Find out the reason and rectify it. You can compare the voltages of the other two cathodes with respect to the faulty colur cathode. Cathode pins will be marked on the base card, and can be identified. It is best to pull out the base card from the picture tube neck and place it somewhere a safe place without shorting it with other parts of the TV. You can measure the voltages of these points very easly, without fearing the damge to the picture tube. After all are found Ok, replug the base card and switch on the TV. The set will be alright. In rare cases, chroma IC also can be a reason for this fault. if it is faulty, after a short period after switch on the TV, the IC will overheat and shutdown the entire system.
on Mar 21, 2011 • Televison & Video
My monitor turns yellowish i can still work what is the problem. the monitor is a Acer V233H
The red "gun" of your CRT monitor is going bad. You will need to get a new monitor, and you should seriously consider an LCD flat screen. It will save you allot in electricity.
A CRT monitor is a very cool piece of technology inside... even though they are going obsolete with the advent of modern LCD displays.
In every CRT (Cathode Ray Tube) monitor, there is a trio of "Electron Guns"- they fire electrons at the front of the screen, hitting it with billions upon billions of electrons... the "bullets". Each gun is aimed at a set of colored targets, called "pixels"... one gun hits red ones, one for green, and one for blue. Combinations of these colors make up everything we can see.
When the red "gun" cannot fire enough electron "bullets" at the screen, the blue and green together make the picture appear yellowish.
If you want to learn more, look up "cathode ray tube" on wikipedia for starters!
A word of warning- the technology is very cool (I used to teach how CRT screens worked as part of my job teaching Missile fire control radar for the Navy), BUT:
THERE ARE VERY HIGH VOLTAGES INSIDE A CRT MONITOR THAT CAN KILL!!! DO NOT OPEN
THE CASE!!!!
Remember- the electron "guns" inside are shooting billions and billions of electrons at the front of the screen. They are being collected from the screen by a high voltage "supply". Most CRT's operate with anywhere from 15 to 45 THOUSAND VOLTS!
IM A TV TECH. I HAVE A SONY LCD KP-60XBR800 I HAVE NO RASTER. POWER OK, MENU OK BUT NO RASTER ON TUNER, TUNER VOLTS OK,CAN YOU HELP ME PLEASE. THANKS my email [email protected]
check the high voltage with the screen control turned up high where there is no raster. suspect problem within the video circuit where there is no high voltage or defective picture tube.some time when the screen is black and the screen control advanced,you can see if the tv has video or vertical or horizontal problems on the screen.service the high voltage circuit if there is no raster or high voltage is seen.no raster can be caused by the no heater or filament in the CRT.---- a defective picture tube can cause many problems, such as, poor brightness ,missing colors,intermittent picture,poor focus,a single-colored raster,arching in the gun assembly,retrace lines in the picture,negative picture,chassis shutdown,noheater or filament lit and no raster to name a few.an open filament or heater can cause no picture or no raster symptom.a defective CRT can have an extremely bright screen.loose particles of the cathode element can lodge between the grids and cause an intermittent black and white picture. simply tap the ends of the CRT gun assembly and notice if the picture begins to flash off and on.---- with a leaky picture tube after turn on the raster dims and get extremely bright.a dim picture with no green in the raster can result from a bad green assembly. a heater-to-cathode short can cause a raster to change colour or a result in no raster at all.replace the picture tube if there is severe arching in the neck of CRT. excessive brightness with retrace lines and a vertical collapse to a thin line can be caused by a bad coil on the neck board of the picture tube.rejuvenate the picture tube when there is very bright green screen. check for the resistance change on the resistors of the CRT neck board for an excessively bright picture with retrace lines.excessive dust inside the CRT spark gaps within the picture tube socket can cause the very bright raster and the chassis shutdown.a defective video amp,luminance buffer,or reference transistor can cause a bright picture with retrace lines. -------- for getting any required parts to replace you can get it from www.radioshack.com or from www.partstore.com or from www.shopjimmy.com --------- thanks.please do rate the solution.thank you for using fixya.keep updated.
Tv image turns green squiggly lines
Hi
This symptoms is made by defective shorted Green Cathode gun, or shorted in the CRT Board. this need to check the CRT Board.
Thanks!
Sony KV-32FV27 ...no Green?
HI
You have defective RGB Circuit, Check the green Gun Cathode path, maybe you have open resistor or open driver transistor. or open Variable resistor.
Thanks!
1helpful
3answers
Screen Flickers
MONITOR ABCs
The monitor is a hardware device which physically connects to your video card. The monitor allows information and current status be be visually outputted similar to a TV.
monitor.gif Like most TVs, the computer monitor has a CRT, or Cathode Ray Tube, which is found inside the computer monitor as illustrated in the above picture. The CRT is the main component and most expensive part within your computer monitor. Within the CRT are three electron guns, Red, Green and Blue. Each of these guns streams a steady flow of electrons, left to right, for each line of your monitor. As the electrons hit the phosphors on the CRT, the phosphor will glow certain intensities. As a new line begins, the guns will then begin at the left and continue right; these guns will repeat this process sometimes thousands of times until the screen has been completely drawn line by line. Once the phosphors on the CRT have been hit with an electron they will only glow for a short period of time; because of this, the CRT must be refreshed, which means the process will be repeated as explained above. If the video card's refresh rate is not set high enough, you may encounter a flicker or a noticeable steady line scrolling from the top to the bottom of your screen. If you are encountering this issue, resolutions have been described on our video card page.
MINIMUM RESOLUTION The size is an important factor of the computer's running resolution. When picking the resolution, try basing it off the monitor's size for best use. 13-inch 640 x 480 15-inch 800 x 600 17-inch 1,024 x 768 21-inch 1,280 x 1,024
Hope this works for ya/Please dont for get to vote.
2answers
My tv video is turn off but sounds perfect
donot quickly replaced the tube! try this first get 2 megohms 1/2w resistor solder it between blue gun and green gun.if this make the picture still, bad tube.u can still rejuvinate it.if not,bad capacitor in vertical or bad g2(screen) adjuster.
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
