Question about New Balance 1400 Treadmill
Deck won't lay flat
After we had the treadmill raised for the holidays, I lowered the deck and noticed that one corner of the deck does not touch the ground. I raised & lowered a few times & also tried to adjust the incline when it was down but NO success. Nothing trapped under the deck. Can anyone help???
3 Suggested Answers
  • 218 Answers
SOURCE: treadmill turns off when increasing incline. New Balance 2500
there is a short in the incline the motor is bad
Posted on Aug 11, 2010
Testimonial: "I agree. The problem is that it requires servicing. My (cheap) fix is just to use it without changing incline! "
ercupa190
  • 12223 Answers
SOURCE: My Reebok v6.80 treadmill turns and lights up but won't go.
1) LUBE the deck belt,you have a WORN deck belt, this happen because you didnot lube according with the schedule maintenance
29 LUBE the rollers bearing too
3) Test the drive belt motor, for worn or crack, or adjust if is possible
4) Test the input voltage motor, if there are the motor need repair
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Posted on Nov 28, 2012
I have a John Deere LX178 lawn tractor and the mower deck will not raise/lower. It is all the way down and pushing in the button is how i've ALWAYS adjusted the height. It will not budge
1) NEVER adjust to where the deck wheels touch the ground. The wheels are to ride 1/4" off the ground. 2) The long lever to your left which raises & lowers the deck has 3 settings. 1- Fully back toward you which has the deck raised (called transport mode). 2- Halfway down which is the normal mowing mode (called float mode) 3- Fully away from you which sets the deck fully on the ground. This mode is ONLY used for VERY rough terrain where the deck risks getting pushed into "transport" or "full up" mode & getting stuck there. 3) On front-to-back tilt, the front should be 1/2inch lower than the back for least damage to the grass. Ok-now to adjust "cutting" height. 1) Park on a level, flat surface. 2) Pull the deck lever fully back toward you to put the deck into "transport" mode. 3) twist the "cutting" height knob (just below your seat) to the height you want the grass cut. Has choices by 1/2" increments from 1" to 3.5". The deck in "transport" mode is 4". 4) Lower the deck lever to the midway/"floating" mode point. 5) Adjust each deck wheel with its own peg & pin to have at least 1/4" clearance from ground. Thats it for "cutting height" adjustments
call your deere dealer,
Troubleshooting
Service Mower
cant find info for you,call dealer
Jun 03, 2015 | Garden
My Sole F63 was working fine. One day, after we unplugged the treadmill and plugged it back in, the treadmill went through a start up process. It elevated the desk for a couple of seconds and stopped and...
I would check the main wiring harness, from the motor board to the console. Check the connection where the main frame connects inside the right upright bar. Remove the triangle shaped plastic cover bolt and side it up the upright bar. You will see the harness. Pull it through the acess hole the check the connection.Make sure all connections are tight.inclines motors rarely fail. To get it down you can reverse the red and black wires from the incline motor to the motor controller. Then run the calibration, once it's down just pull the safety key. It could be the display board or MCB
Dec 02, 2014 | Sole Fitness F63 Treadmill
Why can't I raise or lower the deck?
Sounds like you have jammed linkages which raise and lower deck, you can try this which usually works best with assistant.
With engine off, shake the deck vigorously (up,down, back and forth) while try to raise deck with lever.
Check for worn or damaged arms, springs, deck mounting points, etc and repair or replace.
Sep 01, 2014 | Garden
John deere 855-70 manual
On ALL Deere riding lawn mowers, 1st, position the deck under the tractor. Depending on the belt drive: either PTO (the yellow button on the dash panel), or tension engaged-(a lever on the right side of the operator\'s seat), you loop the drive belt from the front of the deck to the pulley, always in the lower front area of the tractor\'s engine. If it has "beltguards" too close to the pulley, you must loosen the retaining bolt for the guard, it will allow the belt to squeeze by and onto the pulley. Then, 2nd but don\'t forget to retighten after slipping the belt on, push the "Deck heighth" lever fwd to drop the deck "hangars" at the rear of the deck into position to "pin" the eyelets with the supplied pins, washers and keepers: usually a cotter pin or a lynchpin that inserts thru a hole on the smooth bolt-pin. The easy part\'s over, but don\'t panic. 3rd, lift the front of the deck onto a block, allowing a heighth to apply the "adjusting rod" into the front of the mower chassis. Screw the retaining nut onto the threaded (long bolt) and remove the block. You\'re done. Next, and very important, RAISE & LOWER the deck, engage the belt tension, (here you may have to clear the area and start the engine to engage the PTO drive, if it\'s electronically controlled belt-drive), this assures nothing is "misaligned" or improperly positioned. Now, if the machine is on a flat surface, lower the deck to a point just above the ground and measure the distance in four (4) corners of the deck and record the ht. Make the adjustments to LEVEL the deck. Now you\'re ready to start the engine from the operator\'s seat, slightly increase the engine from idle to 1/4 throttle speed so that engaging the drive belt won\'t kill the engine. Ensure the belts run smoothly, the blades turn, and the engine doesn\'t "bog". Lower the deck to a desired cutting ht., now MOW the grass!
Jan 28, 2014 | Garden
Belt feels like it slips when I'm walking
If the belt is worn on the underside you will definitely want to replace the belt. The link at the bottom will take you to a video on how to use a liquid lube on your treadmill. Lubricating the belt/deck every 30 days will prolong the life of the belt and the deck.
The friction caused by excessive wear on the belt and/or the deck can cause a high amp draw and make the drive motor work harder than it's designed to.
How to Lubricate Treadmill Using Liquid Lube Video
Jan 17, 2013 | Precor 9.21 Treadmill
Treadmill deck will not fold in the storage position
HOW TO FOLD THE TREADMILL FOR STORAGEBefore folding the treadmill, adjust the incline to the lowest position. If this is not done, the treadmill may become permanently damaged. Remove the key and unplugthe power cord. CAUTION: You must be able to safely lift45 pounds (20 kg) to raise, lower, or move the treadmill. 1. Hold the metal frame firmly in the location shown bythe arrow at the right. CAUTION: To decrease the possibility of injury, do not lift the frame by the plastic footrails. To raise the frame, bend your legs, keep yourback straight, and lift with your legs. Raise the frameabout halfway to the vertical position. 2. Raise the frame until the latch knob locks into the storageposition. Make sure that the latch knob is locked in thestorage position.To protect the floor or carpet from damage, place amat under the treadmill. Keep the treadmill out of direct sunlight. Do not leave the treadmill in the storage
position in temperatures above 85 Fahrenheit.
http://www.treadmilldoctor.com/?utm_source=fixya&utm_medium=CPC&utm_campaign=Mendi
Jul 15, 2012 | Epic View 550 Treadmill
2000 craftman lawn tractor 917.270822 blades will not engage
If your blades won't engage when you raise the lever to engage them AND that lever moves freely without the normally expected resistance, then you've lost the cotter pin that connects the lever rod to the mower deck assembly. Very easy fix! Using the mower deck raise/lower lever, lower the mower deck to "down" position. Now, lay on your side along the right side of the mower and look up (use a flashlight) under the mower at the top of the mower deck while moving the blade engagement lever "up" (which pushes the connected rod down). At the end of the rod, you will see a hole where the mower deck and rod connect. Align the hole at the end of the rod with the matching "pin" on the mower deck (you'll see it) and insert a new cotter pin to secure them together. Use a nail if you don't have a cotter pin. Voila! you are done. The blade engagement lever will now engage/disengage your mower blades successfully. Just remember that mower deck must be down, or lowered, before you engage the blades!
Jun 22, 2012 | Garden
Won't cut on low height setting
there are several rods that support the deck if one is missing it can allow the deck to move in the wrong dirrection
May 22, 2012 | Garden
I need to know how to take deck loose to replace the belt.
To remove the deck from a riding mower you will need to lower the deck fully first. Then laying on the ground look above the deck and see at what points the deck is connected to the rest of the mower. Also at this point, remove the belt from the engine pulley. You should see some pins that can be removed to unhook the deck. For example on a Craftsman 42" there are two on the front of the deck, two above the deck connected to the lowering mechanism and one to guide the back up and down and one that connects the cable/linkage for engaging the deck. Then raise the lowering mechanism up out of the way and the deck should just slide out. With the deck removed take note of the routing, but usually there is a belt routing sticker on the deck.
Under the seat you will find the make and model number, record these and take to your local lawn mower repair parts store and they should have the appropriate replacement belt.
If this was really helpful, please rate.
Jul 10, 2011 | Garden
The twin blades do not cut at an even level. How do I adjust this?
I would start by getting the mower onto a flat piece of concrete. Lower the deck all the way and measure the distance between each corner and the ground, then raise the deck all the way and measure the distance between each corner and the ground. While the deck is up make sure that both blades are mounted correctly, not upside down. Get a manual and find the adjustments and how they work, then make the adjustments to make the distance the same between each corner and the ground. If you can't find a manual look for threaded rods and nuts and/or pins and think it through before you start making the adjustments. I find these problems are generally due to an upside down blade or someone not putting the deck back on as they took it off.
May 06, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
New Balance 1400 Treadmill Logo
29 people viewed this question
Top New Balance Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Howard
Howard
Electro Med Services...
Are you a New Balance Exercise and Fitnes Expert? Answer questions, earn points and help others
