Question about SanDisk Sansa e260 MP3 Player
Nothing will show up ...
I tried formating my sansa e260 4gb, by going here (http://www.sandisk.com/Assets/File/Downl...), saving the folder on my desktop, conecting my mp3 to my laptop, and then drag and drop the pp5022.mi4 from my laptop to the 16MB Format folder. when i disconected my mp3 from the laptop, all that came up was a black screen and this ( load main image failed, switch to recovery mode ) on top. What should i do?
  • Anonymous Feb 09, 2008
    Only the blue circle light comes on - black screen
    Scholar:
  • 67 Answers
First connect your player and after windows has found it open your 'my computer' folder. if you see the player listed as a drive, right click on it and then click format. You will lose all data/songs but you can always reload them later from your music library. Make sure you use FAT format if windows gives you the option. after format is complete, disconnect the player and it should reboot. After that, you may need to go to the sandisk website and upgrade the firmware. Don't try reformatting from the website. it never seems to work.
Posted on Jul 29, 2007
Operating manual
how to download the instructions manual for sansa Sandisk C240 MP3?
Dec 16, 2008 | SanDisk Sansa c240 MP3 Player
On the file to download http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
Go ahead and do this, in case the DB is corrupted:
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Mar 10, 2008 | SanDisk Sansa e250 MP3 Player
Lost my instructions to my sandisk sansa m240 mp3 player
I looked long and hard and was able to find the answer.. It should not be this hard but here you go; Its the link to the pdf file:
http://www.sandisk.com/Assets/File/pdf/retail/Sansa_ug_Eng_m200.pdf
Glad to help!
Jan 10, 2008 | SanDisk Sansa m240 MP3 Player
User guide
Go here and download the latest updater.
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
I set mine to never check for updates then do it manually but that is your call.
Install the updater and plug you c250 in.
It will show you any updates for the Firmware AND User Guide.
Note: The firmware updates will be installed on the c250 and the guide will be installed in the folder the updater is in (should give you a link in the start menu)
Dec 07, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
Troubleshooting
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://www.sandisk.com/Assets/File/Downl... You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Best of Luck.
Sep 09, 2007 | SanDisk Sansa e260 MP3 Player
Hello. Seems like your player is encountering either a file or system error, causing it to freeze. One solution would be to see if your player would be detected by your PC, then attempt to format it. Another solution would be to re-apply the firmware. Here are the steps: Switch your Sansa E250 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E250 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E250 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E250 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E250 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E250 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downl... Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred. Step 3: When the process is complete, unplug your E250 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your E250 and 90-99% of the time, it would boot up successfully.
Apr 20, 2007 | SanDisk Sansa e250 MP3 Player
Major damage on my sansa e260
2. change lock switch to orange position 3. Press and hold rec button (at left side) 4. while pressing the rec button, turn the player on 5. it will appear the boot menu. connect the USB cable and try to continue the firmware 6. if it doesn't work, do a firmware downgrade. download this file: http://www.sandisk.com/Assets/File/Downl... 7. execute the application while in boot mode
Apr 10, 2007 | SanDisk Sansa e260 MP3 Player
CAN'T FORMAT
do following: 2. change lock switch to orange position 3. Press and hold rec button (at left side) 4. while pressing the rec button, turn the player on 5. it will appear the boot menu. connect the USB cable and try to continue the firmware 6. if it doesn't work, do a firmware downgrade. download this file: http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe 7. execute the application while in boot mode good luck darek
Mar 26, 2007 | SanDisk Sansa e260 MP3 Player
HELP ME PLEASE!!!
Hi Alina. Seems like oyur Sansa E260 is experiencing some system errors. Here's a procedure you could try -- it's setting your player to the Recovery Mode and re-flashing its firmware. I hope this helps: RECOVERY MODE Switch your Sansa E260 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E260 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E260 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E260 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E260 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E260 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downl... Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred which caused the "Load Main Image Failed" notification in the first place. Step 3: When the process is complete, unplug your E260 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your E260 and 90-99% of the time, it would boot up successfully. If not, try steps 1-4 again
Mar 24, 2007 | SanDisk Sansa e260 MP3 Player
Songs When Selected Play Something Else & Songs that are missing altogether
Follow this link - it explains how to update your player's firmware http://www.sandisk.com/Retail/Default.aspx?CatID=1376 Hopefully this should solve the problem. if you need the user guide find it here; http://www.sandisk.com/Assets/File/pdf/retail/Sansa_e200_UserManual.pdf I Hope this helps :)
Mar 11, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
61 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
