Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Liftmaster professional 1/3 keypad no longer opens garage door, resetting does not work, is there a battery in nthere somewhere? I am a pretty handy female as long as you don't ask about wiring
  • 1 more comment
  • Linda DeLong Jan 24, 2013
    well, after searching around, I found the answer. Simple in my case. I didn't realize this had a battery, thought it was all hardwired. Replacing the battery did the trick. Thanks all
  • Linda DeLong Jan 25, 2013
    It was the battery, located at the bottom, prying it open was not an easy thing, but once opened and after cleaning the connection, garage door is opening fine
  • 11 Answers
SOURCE: Sears Craftsman Garage Door Opener Wireless Keypad Model and a LiftMaster Chamberlain Professional Garage Door
I had the same frustrating dilemma with my Craftsman LiftMaster garage door and Keypad, Model 139.53754-01 (dated 10/06; and has the # 315 MHz).
To resolve “the dilemma”, grab your keypad, climb up on a ladder to access the garage door opener’s motor unit. On the right side of the motor unit, remove the white plastic casing by pressing buttons on each side and pulling down. This will expose the programming area, and for our purposes, the “Learn” button.
1. On the motor unit, press and release the “Learn” button. The Learn indicator light will glow steadily for 30 seconds.
2. Within 30 seconds, enter a four digit personal identification number (PIN) of your choice on the keypad. Then press and hold the ENTER button.
3. Release the ENTER button when the motor unit lights blink. The code has been “learned”/stored/activated.
Good Luck, and I Hope this Helps!
Gail
For possible future reference:
How to change an existing, known PIN
(Changing an existing PIN can be done with the wireless remote keypad, and does not require access of the motor unit.)
From the keypad:
1. Enter the four digits of the present PIN, then press and hold the # button. The opener light will blink twice. Release the # button.
2. Enter your new 4-digit PIN and press Enter. The motor unit lights will blink once when the PIN has been “learned”/stored/activated. Test by entering the new PIN, and pressing Enter.
Posted on Jun 24, 2008
SOURCE: Chamberlain Liftmaster Professional 1/2 HP
Okay...upon further inspection, my left spring has broken in two. Going to call around for some quotes to replace the spring. Thanks for the suggestions.
Posted on Jul 25, 2008
  • 244 Answers
SOURCE: keypad garage door opener will not operate
what keypad are you using with new opener? Frequency has changed. can't use old one. you probably never needed to change things; just needed to follow proper coding procedures.
Posted on Jan 28, 2009
Door Tech
  • 98 Answers
SOURCE: Liftmaster Key Pad
Yes, this is a common problem. I recommend the Domino GD-1. It is a wired keypad but the batteries are on the inside so they stay warm, plus you can use from 1 - 6 digits instead of just 4. It is harder to install but worth the effort.
It does not come with wire so you will have to get some bell wire.
Posted on Feb 07, 2009
  • 3197 Answers
SOURCE: I have LiftMaster garage door model 41A3039 and
To program the keypad, first unplug the garage door opener from the electrical outlet. Next remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next enter your desired four-digit PIN number into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
Posted on Jul 13, 2009
Chambelin 1/2 hp security model 400 serial number 39189v00003
replace the battery. If that doesn't work , replace the remote.
Aug 22, 2014 | Sears Craftsman LiftMaster Chamberlain...
I have a Chamberlain Liftmaster Professional 1/3 hp garage door opener. I'm unable to find the model number, but it was made in April 2004 and has an orange learn button. It has been working fine since...
Do you mean the numeric keypad is no longer controlling the garage door? If so, have you changed the battery for the keypad? Frequently, if the battery is low, the keypad will stop working when the door is closed but works to close an open door. On most Chamberlain garage door openers, this is a 9V battery. You may need a small Philips screw driver to open the battery compartment at the bottom of the keypad.
After changing the battery, try the learn code procedure again. I've found it easiest to have two people involved when programming the keypad to the garage door opener. One handles the Learn button and the other types in the desired code.
I hope this helps.
May 22, 2017 | Vacuums
Remote Control closes garage door but does not open
It sounds like a case of your keypad losing signal strength enough that it cannot transmit through the closed door. If a new battery doesn't do the job a new keypad will.
Sep 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster Keypad problem
First thing to do is make sure it has a good battery installed. If this doesn't take care of the problem then the keypad is going bad and needs to be replaced. It is important that you get the same keypad as there are others out there that look the same but will not work.
Jul 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster problems with the wireless keypad...
If you reset your code by pressing the smart/learn button and then keying in your code and pressing enter and it still doesn't work it has just quit on you. Make sure if you replace it you get the same model number.
May 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
52 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
