Question about Garden
Won't spark just quit ignighting, is it battery or flint and how do I fix it
  • 755 Answers
Most lawn mowers are magneto fired so no battery is necessary or even there to go bad! Flint?!
Take out the spark plug and see if it is oily or fuel soaked. Once a plug is fouled they wont spark anymore. Try cleaning the plug with a little carb cleaner and a wire brush. You can also get another plug and just try that. Otherwise you probably need another ignition coil. Good luck!
Posted on Jan 26, 2013
The spark ignition on the right front have gas but does not ignite at all. All three the others have sparks.
flint or electric probe to earth needs a clean or
closer inspection to replace the ignighter
Jul 02, 2016 | Kitchen Ranges
Why is there no spark at igniter?
Batteries, Spark and ignighter.??? What chainsaw is it.!!?
Dec 22, 2015 | Garden
Start button won't ignight
Do you have power on the bike, do the lights work, horn work, does the battery have a good charge.
Jun 07, 2013 | Triumph Motorcycles
How do I replace the flint on an old Omega Super Lighter? The old flint appears to be 'corroded' in its tube and I don't want to break it...otherwise the lighter is in great shape.
INCORRECT PRODUCT CATEGORY
I'm sorry but I believe you have this posted in the wrong product category? Please re-post the question in the proper category if this is the case, otherwise you have my apologies. This is the car and truck problem category
Jul 25, 2012 | Cars & Trucks
I have a dyna-glo 120000 rmc-kfa120 heater that won't fire up it tries to when plugged in but then shuts down and light flashes like it is out of fuel and I can't find any owners manuals
I HAVE THE SAME PROBLEM TOOK IT APART AND FOUN A CRACKED HOSE WERE IT CONNECTS TO THE BLOWER CUT ABOUT A 1/1 IN OFF PUT A HOSE CLAP ON IT WORKED FINE THEN STARTED DOING IT AGAIN AFTER A COULPLE OF DAYS TAKE IT ALL APART AGAIN GO THREW IT AGAIN AND PUT IT BACK TOGETHER AND WOKED FINE IT SAYS CHANGE THE FILTER EVERY YEAR ITS NEXT TO THE FOAM FILTER I THINK 4 SCREWS TO GET IT OUT I JUST USED AIR HOSE TO BLOW IT OUT WORKED FINE THEN AGAIN QUIT WORKING SO I DONT HAVE A FIX BUT STILL WORKING ON IT ALSO THE IGNIGHTER SOME HAVE A SPARK PLUG BUT THESE HAVE A 2 PRONG THING 1 SCREW HOLDING IT IN SAND PAPER TO CLEAN THEM TO IM GOING TO TRY A NEW FILTER AN A NEW IGNIGHTER
Dec 13, 2011 | Heating & Cooling
Burners won't light automatically. Will light with a match. Flint doesn't spark anymore. Can flints be replaced and by whom?
If none of the igniters are working then it is probably the igniter module which is relatively easy to replace on most makes and models.
Jul 27, 2011 | Whirlpool Kitchen Ranges
Kitchen aid gas range igniters won't stop
Jammed and broken ignight switch or the spark generator transformer has a short circuit
Jul 13, 2011 | KitchenAid KGSK901SSS Gas Range
Blazer pocket micro torch will not spark. Gas comes out, but no spark to ignite it.
try to open up the part where the spark would come from. there should be a screw on the bottom or top to open it. This is where the flint would be.
The flint is probably worn down or it broke (you can buy new flints at pretty much any convince store around they are i believe $1-2 for 5 of them.
replace the flint and you will have a spark.
May 03, 2011 | Omega Blazer Self - Igniting Butane Micro...
Oven won't light
I am assuming this is a gas stove. You probably need a new flint in the igniter. Simple problem. Check your local hardware store for flint, and refer to your manufacturer's manual for how to install it. If it's not there, a quick call to a service technician should answer the problem. hope this has been helpful.
Oct 24, 2008 | Ovens
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
