Question about Canon Office Equipment & Supplies
MG8120 6C10 error
Have error code 6C10 printer was working changed ink and viola...6C10. did all of the power on/off. Removed head, pins appear intact. Ink blotter appears saturated. How can I reset on this model?
    Problem Solver:
  • 21 Answers
The error code indicates an issue with the purge unit.
This usually requires a repair\service of the unit.
first of all please turn off the unit....unplug the power cable
now remove the cartridge...manually slide the carriage assembly\ printhead back and forth
also clean the rail against which the assembly slides with a tissue ensuring that there is no ink residue on it
clean the golden contacts of the cartridges and the printhead with a cotton swab dipped in little alcohol
once these steps have been done follow the below steps as well
manually move the printhead to far left
on the far right there is a little white plastic tab that is spring loaded
just check that if its not getting jammed
push the tab towards the front of the printer
once done just turn on and check the status
in case still the issue persists and you get the same error code, then it is an issue with the purge unit.. if the unit is within warranty cover please contact Canon and get the unit serviced...if not, you need to contact a repair tech for physical replacement of the part..however, my personal suggestion is that a repair will not be cost effective
http://www.smoothprinterservice.com
Posted on Jan 24, 2013
starcomp
  • 117 Answers
SOURCE: MP600 / Error Code 5010
it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Posted on Mar 07, 2008
  • 421 Answers
SOURCE: waste ink near full for Canon Pixma 780
http://www.tradebit.com/filedetail.php/3901083-canon-pixma-mp780-service-manual
Genuine Canon Service Manual for the MP780
Posted on Sep 21, 2008
tigertail
  • 163 Answers
SOURCE: waste ink pad saturated. EPSON STYLUS PHOTO R360
Replacing the pads is costly, messy and requires the printer to be taken completely apart. If you have little or no experience of stripping down printers it is best left to a proffessional. Contact Epson to find your nearest service centre, but remember to get a quote as it may be more economical to replace the printer. Sometimes the counter can "jump" to the end of life number, this especially happens where 3rd party or refilled inks have been used. If you believe this to be the case and there is no sign of ink leakage and the pads look fairly clean then you can just reset the counter using special software called the SSC utility. See these sites:
http://www.ssclg.com/epsone.shtml
http://inkjetprinterhelp.us/epsonSSC.html
More information about this issue and the "official" Epson resetter is available from the Epson web site, please read this link:
http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
Please take a moment to rate this solution. Thanks.
Posted on Apr 14, 2009
pineworks
  • 4041 Answers
SOURCE: Current Problem on Printer """E5"""
This error means waste ink counter is full.
Solution:
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Press resume
Posted on Jan 25, 2010
pineworks
  • 4041 Answers
SOURCE: Ink System Failure code appears on Hp Photosmart D7360 printer
Hi ok try I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 08, 2010
Epson printer error codes
The error code E-90 appears when the print head is not able to move back and forth freely.
If the ink cartridge cover is not completely closed, the print head may have trouble moving back and forth. Follow these steps to close the ink cartridge cover:
  1. Turn off the printer
  2. Lift up the scanner.
  3. Press down on the ink cartridge cover to make sure it is completely closed.
  4. Close the scanner and turn the printer back on.
- or, If the packing materials are not removed, the print head will be unable to move and the error code E-90 may appear on the control panel display. Follow these steps to remove the packing materials:
  2. Lift up the scanner to access the printer area.
  3. Remove the tape from the ink cartridge holder.
  4. Close the scanner.
  5. Turn the printer back on
epson-printer-error-codes-quwd4e0otlw35mvdaq3xmige-2-0.jpg epson-printer-error-codes-quwd4e0otlw35mvdaq3xmige-2-2.jpg epson-printer-error-codes-quwd4e0otlw35mvdaq3xmige-2-5.jpg
Sep 01, 2014 | Epson Stylus DX6050 All-In-One InkJet...
Error Code 0xc1ab0001 What do I do?
The "Oxc1ab" series errors can be removed by resetting the printer. Unplug the USB cable from the printer, remove the ink cartridges. When the "Insert ink cartridges" message appears unplug the power cord from the printer. Wait 1 minute (at least), then reconnect the power cord and turn on the printer if it didn't come on by itself. Reinsert the ink, close the unit and print a calibration page if prompted to do so. Finally reconnect the USB cable to the printer. If this doesn't work, the unit needs service (or replacement if the service call will cost more than a new printer).
Thank you!!
Jul 05, 2010 | HP Photosmart 2575 All-In-One InkJet...
Error code Oxc 18a 0007 appears and can not print
The "Ox18" series errors can be removed by resetting the printer. Unplug the USB cable from the printer, remove the ink cartridges. When the "Insert ink cartridges" message appears unplug the power cord from the printer. Wait 1 minute (at least), then reconnect the power cord and turn on the printer if it didn't come on by itself. Reinsert the ink, close the unit and print a calibration page if prompted to do so. Finally reconnect the USB cable to the printer. If this doesn't work, the unit needs service (or replacement if the service call will cost more than a new printer).
Thank you!!
May 19, 2010 | HP Photosmart 3210 Printer
E-90 error message on Epson CX6000
If the error code E-90 appears on your Stylus CX control panel display, the print head may not be able to move back and forth freely.
  1. Turn off the Stylus CX.
  4. Close the scanner and turn the Stylus CX back on.
Also
  5. Close the scanner.
  6. Turn the Stylus CX back on.
Aug 07, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Canon Pixma 210 series has an error code 6000, won't print or scan
Hope this helps
With thanks to a canon tech
Ok Well again I will repeat this answer with a titch more detail.
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs replacement. A Pixma MP830 would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow.
Procedure to reset Printer canon MP145 and Canon MP160 with Error Code Message for Printer Canon MP145 and Canon MP160, you can find error code message the end of this post:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Unplug cable power. (for MP145 / MP150)
6) Turn Off Power. (for MP160)
Error Code :
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
May 22, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Error code 5010 and 5C20
on't know this error code, but this info might help
With thanks to a canon tech Ok Well again I will repeat this answer with a titch more detail.
button pressing
Error Code :
E3-3 = Paper jam
E4 = No ink
E29 = EEPROM error
May 14, 2009 | Canon PIXMA MP610 InkJet Printer
ERROR CODE 3802
This is how I fixed this problem may or may not work for you. I removed the ink!!! Then I removed the ink tray. This is fairly easy if you fell the top of the ink tray you will find a small square that is slightly raised push in on the square while pushing down on the tray this will release the print head. Very carefully clean with 92% alcohol and a q-tip! Don't apply pressure to the print head it will ruin it!!!!!!!
This allow to air dry for at least a 5min. Reinsert then recalibrate the printer! go to printer status and at the very top you will see a rench and hammer icon press it then follow directions!!!!!!
Good luck and god bless
Nov 03, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Canon Pixma MP530 All-In-One
I had contacted Canon to resolve my problem.
Through the technician I am informed that the printer has to be sent back for service as one of the 4 pins on print-head print has dropped off leaving only 3pins that is why the error code U043 simply occur which is why replacing another new ink cartridge does not resolve the issue.
I have understand from him that:-
  1. Most of the time when error code flash up, usually are due to the unique feature that Canon has build on the ink cartridges not properly done which resulted to be faulty. Canon's purpose is to prevent the usage of 3rd party ink cartridges. Of course this causes inconvenient to users, but if users are not using 3rd party ink cartridges, once detected is Canon's ink cartridge issue, do contact Canon, they will provide house call for 1 to 1 exchange for the ink cartridge.
  2. Other times if by replacing new ink cartridge the problem for error code still occurs, it might be the pin on the print-head has lost the alighting, this will require for Canon to service to alight back the pin on print-head in order for the printer to operate smoothly again.
  3. If your problem is like mine, inputting the ink cartridge into the wrong slot, well I guess only have to contact Canon as the printer's components used seem to be highly sensitive, by input the wrong slot would have caused scatches on the pin, well it is better to have the ink cartridge remove by the expert than to DIY. (Maybe check with your own nearby technician if by any lucks they can help to rescue your printer, which I hope Canon does not have further enhancement on their printer with other Unique features to prevent users from using 3rd party technical support.)
I hope the above information will help all the troubled Canon printer users as I notice from previous search on this website, there are other users having problem like ink cartridge is only partial used, but error code appear to check ink cartridge, maybe trying to taking out and putting back, it works sometime and problem occurs again, by replace a new ink cartridge will help as the partial used one would be faulty already, and do call up Canon to report the issue and they will exchange a new ink cartridge for the faulty partial used cartridge.
Mar 26, 2008 | Canon Pixma MP500 All-In-One InkJet...
Print head
mukuwa, here are a couple of suggestions: How do I clear a Machine Error 41? Description: * Machine Error 41 indicates a mechanical malfunction of the FAX/DCP/MFC. * Unplug the unit from the power source and then plug it back in again. * If the error message continues to be displayed on the LCD, please contact Brother Customer Service. 1. Open the Scanner cover by pulling up on the edge of the scanner just above the LCD. 2. After 15 seconds, re-close the Scanner cover. 3. The LCD will then display Have you removed Blck? 1 Yes 2 No. The LCD will display this question for ALL 4 colours (not just the ones replaced). If 1 Yes is selected, the LCD will then display Change to new (colour)? 1 Yes 2 No. Note o "Change to new (colour)?" will only appear if 1 Yes is selected for "Have you removed (colour)?" If 2 NO is selected for the "removed" question, the LCD will then move on to the question for the next colour. o If "1 Yes" is NOT selected for the colour(s) that was replaced, the LCD will return to "Ink Empty". 4. After all the correct selections are made, the machine will then go into a cleaning. Once the cleaning is complete, the LCD will return to date and time. If you still have the same problem, contact Brother Customer Service. http://welcome.solutions.brother.com/bsc/public/eu/gb/en/faq/faq_top.htm?reg=eu&c=gb&lang=en&prod=mfc3820cn_eu Let me know what happens. Good Luck, Tim
Mar 15, 2007 | Brother MFC 3820CN All-In-One InkJet...
101 people viewed this question
old marine
old marine
