Question about MTX Dodge Ram Quad Cab 2002-2003 Thunderform, Loaded with Dual 10 Inch Subs and Amplified, Charcoal Car Speaker
Brake lights stay on when engine is running. How do I repair??
Brake lights work fine when engine is off. When engine is running they stay on constantly.
  • 625 Answers
It sounds as if your brake switch plunger is not making contact at the peddle. The way it works is when it's touching, the light is out and, when you step on the brake peddle the plunger from the switch travels outward and turns the light on. OR
The wires are corroded somewhere in the line (possibly at the rear light housing) whereby the brake light wire is powered through an active 12 volt line when the vehicle is running.
Posted on Feb 12, 2013
On My 1998 Toyota Camy when the car is on my brakes lights wont go off but if the car its off the brake light work fine why??
These Toyotas had daytime running lights. The headlights and the taillights turn on when you start the car. If you press the brake pedal, the rear lights (and the brake light in the rear window) should come on brighter.
I have never heard of the brake light staying on (The brighter filament in the two-filament bulb). Hope this helps.
Mar 03, 2015 | 1998 Toyota Camry
1985 dashboard brake light stays on
Your post gives the year of the truck as a 1993 and 1985...
The light on the dash may be your parking brake.
May 26, 2014 | 1993 Ford F150 SuperCab
What goes wrong with abs brake module in 99 dodge ram 2500 diesel truck
It isn't often we get enough information to make a diagnosis, but I think we can in this case.
You have a break light switch under the dashboard that is plastic, and has a "plunger" button.
When you press the brake pedal, that allows the plunger button to extend, which closes contacts inside the switch, and makes the brake lights come on.
If and when that switch either breaks or gets loose, the plunger will stay extended, and the brake lights will stay on, discharging the battery.
God bless your efforts to see & fix this.
Jan 18, 2018 | Dodge Ram 2500 Cars & Trucks
The brake lights stay on when engine is running on 2002 ram pickup . How can
I suggest to scanning the ABS module in order to know ffault codes there.
Jan 23, 2013 | Dodge Dakota Cars & Trucks
My breaks light stay on even if my car is not running???
Hi Chris....When you release the brake pedal, there is a switch underneath the brake pedal that disconnects the circuit to your brake lights causing your brake lights to switch off. Sometimes this brake light switch will go bad and need replacement. For the most part, replacing the brake light switch is very simple. Simply replace the brake light switch with a new one. If your brake light stays on after you turn your car off and you don't want to run your battery down, you may be able to get down underneath the brake pedal and manually pull up on the brake light switch to deactivate it until you can get it repaired. This method will only work if the brake light switch is just sticking.
I hope this helps FixYa!
Aug 25, 2011 | 1992 Buick Regal
2005 Dodge Caravan . Brake lights stay on !
Try pulling back on the brake pedal if lights go off then either switch adjustment or the brake booster is allowing the pedal to drop down if it's running (vacuum) or brake pedal mechanism is binding.
Jan 25, 2010 | 2005 Dodge Caravan
02 harley fxdwg brake light stays on
Make sure your rear brake pedal has freeplay in it. when you slowly push the lever down by hand you should be able to feel some freeplay. if not the the reason it keeps staying on is because the vibration of the motor is actually pumping up your brake ( light too ) and not releasing it until it bleeds off the pressure.
Jun 23, 2009 | 2002 Harley Davidson FXDWG Dyna Wide Glide
Installed new led taillight and now there is no brake light/blowi
I fixed it. The LED light needs a "load equalizer" to operate properly. Instructions said nothing of needing one. I combed the internet and found the answer. I responded to FixYa by e-mail "REPLY" and informed of the fix. Thanks for your help...I'll remember your site for future needs.
Mar 19, 2009 | 2004 Harley Davidson FLSTF - FLSTFI Fat...
BRAKE LIGHTS STAY ON ENGINE RUNNING BUT CAR WONT DRIVE
there is a button on your brake pedal lever that while braking gets depressed, and turns on your brake lights. Now this component is a plastic piece that can get knocked loose rather simply. You either need to re-secure this component, or replace it
(you can get this part at any junk yard for nothing more than some pocket change)
Jan 29, 2009 | 2001 Audi A4
MTX Dodge Ram Quad Cab 2002-2003 Thunderform, Loaded with Dual 10 Inch Subs and Amplified, Charcoal Car Speaker Logo
43 people viewed this question
Top MTX Car Audio & Video Experts
hoyzee1
Mark Skinner
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
