Question about HP Photosmart C6180 All-In-One InkJet Printer
Computer/rinter Problems I just bought a HP Photosmart All In One C4440 and it is not printing. I have installed it with the disk it came with. Tried various ports on the computer, tried printing from different programs, tried calling the HP support line, have went to the control panel, and have added it twice to the Printers and Faxes link. Help please.
  • Wayne Mineard
    Wayne Mineard May 11, 2010
    Are you using Vista or XP?
    Also there is a critical communication update for this printer on HP Support. Have you installed it?
    President:
  • 8,637 Answers
Normal 0 You probably already did it like this
Disconnectthe printer or at least be sure it is turned off. I'd doboth and when the CD software program asks you to connect the printerto the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 30, 2009
Hp photosmart C7250 hangs while printing
Hi Georgette,
You have tried your best with possible troubleshooting to fix the issue. There are few possible workaround solution for this issue.
First, If the USB Cable is more than 3-5 ft long, it could be the reason. Also, if the USB Cable is worn out or is broken in-between.
2nd, The printer does not seems to accept command from PC ( win 7 ) using the HP Software. So Uninstall the Software. Restart the PC.
Do not install Printer Software. Connect the Printer USB to PC and Windows 7 will display new hardware detected message.
Continue with the New Hardware Found Wizard and install the drivers it will list by Default.
Try to print and it should work.
If this works, You will be able to print without any problems however if you want to scan a document, you need to use Applications like MS-Paint, Microsoft Word etc, or Use the Scanners and Camera option in Control panel.
You can then install the software disk of printer or the downloaded software from Hp website to install Printer software for SCanning.
If you do so, you will find 2 printer icons in Printers Folder. First one will be with WSD text ( this icon is created when you connect the printer using USB without installing the printer software ) and 2nd icon will be HP Photosmart C7200 All in One ( this will be the Software installed ) and this will be default icon with check mark.
Whenever you want to print from any application, You need to click on File - Print - choose the WSD icon to print.
Regards,
Sean S
Sep 19, 2012 | HP Photosmart C7250 All-In-One Thermal...
I have just tried to install hp 7280 all in oneprinter on a computer with windows 7 version-does not print test page computer is new-printer is almost 2 years old...what do I need to do
Does the printer print its own self test page? if so then check solution center if it states that there are no devices detected or that you need to insert the disk and complete the installation it means that the drivers did not install properly. if you havent already download the full feature software and drivers from hp and uninstall the previous installation that was attempted.
Apr 06, 2010 | HP Photosmart C7280 Printer
HP Photosmart C4440 Printer sounds like a machine gun
i have the same printer and the same problem--did you ever find a solution?
Oct 01, 2009 | Office Equipment & Supplies
An error occured during the installation of the
Step one: Uninstall the All-in-One software Even if the installation failed, some HP software components might have installed on the computer. Follow these steps to use the Windows Add or Remove Programs tool to uninstall the software.
  1. Disconnect the USB cable from the product.
  2. Click Start , and then click Control Panel .
  3. Click Add or Remove Programs . The Add or Remove Programs window opens.
  4. In the Currently installed programs list, select the following items if they are listed:
    • HP Officejet/Photosmart/PSC All-in-One software 9.0
    • HP Imaging device functions 9.0
    • HP Customer Participation program 9.0
    • HP Solution Center 9.0
    • HP Photosmart Essentials 9.0
    If the list of installed HP programs contains any version numbers less than 9.0, select the following items if they are listed:
    • HP Officejet/Photosmart/PSC All-in-One software XX (where XX represents a version number less than 9.0)
    • HP Imaging device functions XX
    • HP Customer Participation program XX
  5. Click Change/Remove , and then follow the on-screen instructions to uninstall the software.
    NOTE: If a prompt displays asking you to remove shared files, click No . Other programs that use these files might not work correctly if the files are deleted.
  6. Restart the computer when prompted to do so.
Apr 24, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP All in One printer causing problems with my computer.
Yes, It is possible that the setup disk is corrupt/virus infected. First try to update your antivirus. Then use Revo unistaller to uninstall the software. Now download fresh setup files from HP site. That will solve your porblem
Dec 16, 2008 | HP Computers & Internet
I have a hp photosmart C4440 printer can't install don't have cd
you can get these drivers from hp web site hp help.com
Dec 09, 2008 | Office Equipment & Supplies
HP Photosmart C4180 won't print
hello
you can get the newest vista software for your laptop from
CLICK HERE
Apr 28, 2008 | HP Photosmart C4180 All-In-One InkJet...
Installation Problems, Please help!
try downloading the software from the HP website and then reinstall the printer. But also try to uninstall it using control panel add/remove programs, restart your computer, and then reinstall using the downloaded driver.
Jan 27, 2008 | HP Photosmart C4280 Aio Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
