Question about HP Pavilion Computers & Internet
Dos command to run windows or how to do system recovery from usb
Ze4220
  • HP Master
  • 7,627 Answers
Reboot and tap F-8 to enter the Boot Menu, select USB. HP Support cam be found here: http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=242222
Posted on Jan 23, 2013
SOURCE: C ++ is not working.
please refer the following link..... and follow the procedures.....
http://support.microsoft.com/kb/324767
Posted on Jun 07, 2009
  • 909 Answers
SOURCE: I am unable to run chkdsk from the dos prompt
You can run it in the operating system, but it will run on reboot only as the O.S. locks the drive you are using
chkdsk /f will run a full check for you, also you can do a more thorough check and recovery from my computer, right click the drive and select properties, open the tools tab and pick what you need to do, the drive will be checked on next reboot.
Posted on Nov 06, 2009
paul7of9
  • 1189 Answers
SOURCE: my laptop unable to give sound out put why?
  • Hi, these instructions will help you with the Audio problem. These are the steps to setup and 'restore' the “Audio Drivers2_bing.gif" "Start" button, go to and click in the (right, pane) Control Panel. Scroll to find the Sound category; select “Audio Devices, and Sound Themes” click, “PlaybackNext, click on the Active "Speakers,” select “Configure” to "Audio channels." The (Speaker Setup) "wizard,” appear! Select (Test) click, Next, adjust "sound" (Level). Select the Enhancements button make changes. Open the Controller Information (block), open the Properties to "update" Drivers. Check to see if Device usage: (enable) if not?" Enable it. *Note: “After making all changes, click 'OK, 'Save," and apply!” before exiting. To finish: Restart the computer. “If the solution help ratings it is appreciated, thanks
Posted on Mar 20, 2010
jomabug76
  • 1148 Answers
SOURCE: how to repair windows xp
insert windows cd ,,push repair windows option,,or go to control panel ,,sytem restore will fix that
Posted on Nov 04, 2010
duane_wong
  • 6826 Answers
SOURCE: Hi, I have a netbook
I'm afraid that you'll have to get some installation disks for an operating system and boot from it using an external DVD drive (for Windows 7 for instance). If System Recovery doesn't proceed, that's the only way I know to load an operating system.
Posted on Dec 18, 2010
Cannot load Windows 7 from hard drive. Possible with recovery discs.
Run the Check Disk Utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
May 31, 2012 | Computers & Internet
Tip
How to Break Windows Administrator Password from DOS Command Prompt?
<p>A windows administrator account is a user account that gives full access to the machine. It is by far the number one target for someone trying to gain illegal access to your network and resource. So Administrators should change administrator password frequently to avoid unauthorized access to the domain or desktop machine. <br /> <p><br /> Then something bad happens. Password can be easily forgot or lost. If you <b>forgot windows administrator password</b>, how could you <b><a href="http://recoverlostpassword.com/products/windowspasswordrecoery.html">break windows administrator password</a></b> and gain access to your admin account?<br /> <br /> <p><br /> Here is how to break windows administrator password from DOS command prompt</b><br /><br /> <ol> <li>Login as administrator or user account that has administrator privileges.</li> <li>Click <b>Start</b> -&gt; <b>Run</b> </li><img src="click-run.jpg" /> <li>Type <b>CMD</b></li><img src="type-cmd.jpg" /> <li>Then the DOS shell screen will appear like below, Type "net user username password/domain" into the command prompt.</li> <p>Replace username with the user account you login and the password with the new password you want to assign to that account. /domain is optional. If you are in a domain, specify the domain otherwise leave it.<br /> <li>Once you click<b> Enter</b>, your password will be changed, like the example, the administrator will change the password of the user Michelle to 123456.</li><img src="net-user-password.jpg" /></ol> <p><b>NOTE: </b>If you do not have administrator rights on the machine, you will get the error message stating "System error 5 has occurred. Access is denied." <br /> <p><br /> If you receive this error message that means you couldn't <b><a href="http://recoverlostpassword.com/products/windowspasswordrecoery.html">break windows administrator password</a></b> from DOS command prompt. At this time, SmartKey Windows Password Recovery comes in hands.<br /> <p> <br /> <b>SmartKey Windows Password Recovery</b> is a powerful password hacking which can help to break Windows administrator and domain password by burning a bootable <b>Windows Password Reset CD</b>/DVD or USB flash drive. With this bootable password reset cd, breaking windows admin password is a child's job.<br /> <p><br /> Here is how to <b>break windows administrator password </b>with Windows Password Recovery </b><br /> <p> <br /> Step 1: Download and install SmartKey Windows Password Recovery software.<br /> Step 2: Burn Windows Password Recovery software to CD/DVD or USB flash drive.<br /> Step 3: Breaking the lost or forgotten windows administrator password.<br /> Only need 3 simple steps. Your windows administrator password has been broken.<br /> <br /> <p><br /> <b>Contact:</b><br /> Official Website: <a href="http://recoverlostpassword.com/products/windowspasswordrecoery.html">http://recoverlostpassword.com/products/windowspasswordrecoery.html</a><br /> Email: <a href="mailto:support@recoverlostpassword.com">support@recoverlostpassword.com</a> <br /> <p> <br /> <p><b>Related Article:</b><br /> <a href="http://recoverlostpassword.com/article/break-word-password.html"><img src="jiantou.gif" /> How to Break Word password</a>?<br /> <p style="font-weight: bold;"><br /> <p style="font-weight: bold;">Article Source:<br /><a href="http://recoverlostpassword.com/article/break-windows-administrator-password-from-dos.html">http://recoverlostpassword.com/article/break-windows-administrator-password-from-dos.html</a><br />
on May 24, 2011 | Computers & Internet
Please help me..i have a aspire one d260 netbook..the problem is bootmgr is missing..it has no cd drive and i dont have a external cd drive to use.. how can i fix it using only a usb flash drive..how can...
You might have to take it to the shop. Lesson learned. Never buy a computer without a CD Drive because one day the system is going to croak.You will need a operatingsystem disk or a repair disk to fix it. Insert it in the drive then bootfrom it. You want to get to a dos command prompt (black screen with whitelettering) and type the following commands. Press ENTER after eachcommand.
bootrec.exe /fixmbr
bootrec.exe /fixboot
bootrec.exe /rebuildbcd
Reboot and see if the problem is solved. If not get back to the doscommand prompt and run the check disk utility.Torun the check disk utility you will need a repair disc or a operating systemdisc. Put the disc in the cd drive and boot from it. You want toget to the Dos Command Prompt (Black screen with white letters) and type thefollowing command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
May 29, 2012 | Acer Aspire One D260 Netbook
My sony vaio pcg-7v2l keeps booting up to Vaio Recovery tools but when I run diagnostics it says everything is ok.
Try running the Check Disk Utility.
You have either missing or corrupt boot or system files. Run the Check Disk Utility.
May 23, 2012 | Computers & Internet
Bootmgr is missing
Never, Ever, Never, buy a another computer without a cd drive or you'll be faced with your current situation.
I don't know exactly how you are going to get this done because you need a cd drive to do it. If somehow you can get to a dos prompt you might be able to fix it and run the steps below.
You will need a operating system disk or a repair disk to fix it. Insert it in the drive then boot from it. You want to get to a dos command prompt (black screen with white lettering) and type the following commands. Press ENTER after each command.
bootrec.exe /fixmbr
Reboot and see if the problem is solved. If not get back to the dos command prompt and run the check disk utility.
May 21, 2012 | Acer Aspire One D260 Netbook
Toshiba 5205-S705 is giving an error msg boot.mgr is missing..i tried booting from xp through cd rom but didn work tried to boot with usb as well but didn work any solution pls mail prashantaishu@gmai
bootrec.exe /fixmbr
May 13, 2012 | Toshiba Satellite 5205-S705 Notebook
Need To Reboot to factory settings
System Recovery is Factory Settings. Did you make the System Recovery Disk or are you trying to use the Recovery Partition that the manufacturer put on your hard drive?
Anyway, for the time being lets forget about system Recovery since you say it does not work.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Apr 26, 2012 | Acer Computers & Internet
Cant get emachine to go past recovery management
LOL, Vista or Windows 7??
Check Disk UtilityTo run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.If check disk does not solve the problem you might have to reinstall your operating system.
Apr 09, 2012 | Computers & Internet
Hello, I need to disable caching on bios ami 02.59 as i get blue screen irql not less or equal 0x0000000a , 0x00000007,0x00000002, 0x00000000, 0x804e89f where do i find the disable caching option, i...
No, windows 7 dvd will not work with xp. You will need a xp system disc to fix this. Boot from the xp operating system disc and when it comes up click Repair. When the dos command prompt comes up run the check disk utility.
Mar 31, 2012 | ASUS Computers & Internet
OXOOOOOOA5 (OXOOO1OOOA OXOOOOOOOO,OXOOOOOOOO,OXOOOOOOOO)
This looks like the codes from a Blue Screen Of Death (BSOD). If so you will need a system disk to boot from and get to a dos command prompt (black screen with white writing) and type the following command:
chkdsk /r
Check Disk Repair will run for well over an hour and you will see the percentage of completion going from high to low but that is normal. Let it run to completion and then reboot.
In Windows XP to get to the dos command prompt boot from the system disk and when the options come up select Repair. Select 1 for the Windows Operating System and when it asks for the Administrator Password just press enter.
In Windows Vista to get to the dos command prompt boot from the system disk and when the options screen open you could try a startup repair. If it fails look the dos command at the bottom of the Recovery Console.
Mar 23, 2012 | eMachines ET1641-02w (PT.NA60X.001) PC...
Computers & Internet Logo
23 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
