Question about Ovens
I ordered arcona products over aq week ago. I realized the next day that arcona did not hv my new adress. I WAS at 1101 west stevens apt 161 santa ana ca. I am Now 801 loarra st apt 104 anaheim ca 92801. I gv my phone # 714 388 8256. This is my 3rd email. I paid for my products and not receiving anything. I am Not happy. Please resolve this problem and call me with an out come. Thank you. Kasi howarth 714 388 8256
Kems308sss05 starts heating to a preset temp, then stalls. Both broil/bake elements get hot, no spots or breaks. When I try to preheat again, the start temp is less than the # it stalled at.
Top 42 Complaints and Reviews about KitchenAid Wall Ovens
www.consumeraffairs.com > Homeowners > Ranges/Ovens/Stoves
Rating: 1.6 - ‎35 votes I missed 2-days of work, once for diagnosis and then another for them to ...KEMS308SSS05 - I purchased this product in Jan 2012. ... Ordered parts, two weeks later parts came and when the heating element was .... I used the self-cleaning unit in top and bottom and noticed in November the temperature took a long time to ...
Nov 08, 2015 | Ovens
Tip
I have the same issue, however, whirlpool and the three recommended service...
Equipment is Whirlpool double oven RBD305PDS14 built-in.  After a very stormy summer 2007, I thought a power surge may have zapped the control board.  Problem initially presented on display as error & fault "E6 F2"; simply pressing "Timer Off" would usually clear this error & fault code.
However, some months later, the display would often go completely blank followed by the beep sequence "short-long-short-short-short" (Morse code: dit dah dit dit dit).  No error & fault code would appear.  Pressing any keypad oven control did not work at all in this condition.  When power was cycled at the breaker panel, the usual "PF" with clock display did not appear.
[TURN OVEN POWER OFF AT BREAKER!!!]
After following the excellent information on "how to remove the control panel" posted in this forum, I first tested the "control panel thermal fuse" (refer to the tech sheet that should be behind the control panel once it is removed).  It showed a closed circuit.
I turned my attention to the "flexible" keypad connector cable (error & fault code "E6 F2" is a keypad or keypad connector problem; again, refer to tech sheet).  The control panel has a board mounted female connector with two tabs that may be gently pulled upward to release the flexible cable.
I cleaned the flexible cable contact area (it seats into the board mounted female connector) carefully with a Q tip and some isopropyl alcohol.  I reinserted the flexible cable and gently pressed down on the two tabs (noted above) on the board mounted female connector.  VERY GENTLY tug on the flexible cable to insure it is gripped by the connector.
After all of this monkey business, I re-mounted the control panel display panel on the oven and restored power.  So far, so good.  After applying power, the "PF" with clock display always appears.  I am able to set the clock and press "Start".  Over functions normally.  The clock displays as normal and I no longer observe the problem I described above.
BTW, I noted the incoming 240V has transient suppression (no surge protection, however).
on Dec 22, 2010 | Whirlpool RBS245PDS Electric Single Oven
Some weeks ago the display dimmed and on the next day it was completely dark. Except the light nothing works anymore. Pressing of the UPPER OFF or LOWER OFF buttons has no effect. There is no error co
the display dimmed the it went out hummmm sounds the usual
could be a dry bad solders on the controller pcb...
as its now gone out...
sounds like the psu section of the controller board has failed
you can take a look around for the details or take it to a service guy who will prob just remove and replace the controller board or you can order the controller board and fit it yourself
basically you have a low voltage supply to the controller
and this switches the high voltage and fan controls of the oven so whats happened is the low voltage supply to the controller board has failed as you say it went dim this tells me that the display inverter section or its supply has failed and as the supply to the controllers sections and display inverter its safe to assume that the main low voltage supply section on the controller pcb has a problem
this is usually caused by bad capacitors that can cause other components to fails this is why a service engineer will avoid trying to repair and and will refresh the controller pcb
so.... if your up for it youll need a DVM and a diagram
other than this a new board...
Nov 28, 2014 | Ovens
On January 31st 2014 I ordered an oven from Big Brands Online.They took the payment for it from my account that day. They said delivery would be 3 working days. After five days I got intouch to see where...
And your question is? If you have time, you can order online and save money sometime but, if you need it buy it local you will get it sooner and less trouble. It takes up to 4 weeks to get money back.
Mar 07, 2014 | Ovens
Frigidaire oven
Yes, that sounds like a relay on the oven control board. Here is the part to order that has a 365 day, any part, any reason return policy so you may want to order from them.
Jun 25, 2013 | Ovens
Beko OFT12300X double oven top oven getting exceptionally hot inside when only the bottom oven is on
I know of nothing unusual about this, the oven vents some through the top burner.
May 19, 2017 | Ovens
Need instructions for self cleaning oven
Product Information
If you have a question pertaining to Viking product line or if you own a product and require assistance with non-technical information, please submit your request using the Product Information Online Form below. If you wish to speak to a customer service representative please call us at 1-888-VIKING1 (1-888-845-4641), then press 2.
Oven repair in Santa Ana, CA
Appliance repair in Santa Ana, CA
Jan 24, 2011 | Viking VESO105 Electric Single Oven
Whirlpool oven knobs for old model RRE25P2
Hello. You can order them directly from Whirlpool parts. Go to this link http://www.google.com/search?q=whirlpool+RRE25P2+oven+knobs&hl=en&sourceid=gd&rlz=1Q1DLUS_enUS358US358&aq=t
Regards, Joe
ps please rate my answer. thankyou.
Jan 20, 2010 | Ovens
I have a F & P wall double oven model OD302, first used 2 weeks ago, and the temperature, although set at 375 degrees, rises to only 122. All settings were used, ie. aero bake, bake, etc. The right...
The name F&P says it all! If there was any brand that gave the most problems, in products then F&P is the first on the list. With LG as the second
You say this is possibly a new installation of only 2 weeks. Don't dither around seeing if its a simple fix, get the installers/sellers back to fix it . It will probably need replacing as the control is faulty.
Thanks for using FIXYA
Dec 03, 2009 | Fisher and Paykel Ovens
Glass in oven door is cracked, inner glass completely fallen out
this is a fairly common problem with glass doors on any make of oven
Oct 21, 2008 | Whirlpool RBS305PD Electric Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
