Question about Maytag Dryers
Dryer is squeeling through the cycle - Maytag Dryers
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 169 Answers
Most of the time when this happens it is one of two things. The belt has gotten loose and is slipping, or the drum bearing is weak causing the drum to rub on parts of the housing.
Posted on Jan 24, 2013
MY LG DRYER DLE 5977W HAS A VERY LOUD (AND GETTING LOUDER BY THE DAY) SQUEELING NOISE AT THE BEGINNING OF EACH CYCLE. WITHIN A COUPLE OF MINUTES THE SQUEELING NOISE CEASES. ANY IDEAS ON HOW I MAY REMEDY...
your dryer drum wheels that support the drum are either stuck on their shaft or the shaft that they turn on are rusty or eroded out on the wheels/spindle and are creating the noise you hear,you need to access the drum and lower area to see these wheels there are 4 wheels 2 at the back of the drum and 2 at the front of the drum,the rear 2 are most likely the porblem,from the heat of the dryer element
Sep 06, 2012 | LG DLE5977 Electric Dryer
Loud squeeling noise. Sounds like a bearing.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Nov 20, 2010 | LG DLG5988 Gas Dryer
Squeeky dryer
belt is stretched from a worn bearing in the belts idler pulley
Replace the belt along with the pulley sold at most Sears stores
Jun 20, 2010 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
11087088601 dyer squeels at start; will stop after a bit
The belt is loose and is most likely due to the belt being stretched out. Replace the belt and the tensioner also to solve this squeal.
Apr 14, 2010 | Dryers
Dryer making a high pitch squeeling sound when
The idler bearing that keeps tension on the belt is going out due to heat leaching the grease out of it. Have it replaced.
Apr 13, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Squeels while drum spins
Belt loose , drum bearing shot
Tighten first , replace second
Jan 03, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Maytag dryer squeeks when I first turn it on. Started about a couple of weeks ago. Squeek would go away after a few minutes, however now it is continuous.
Hi, The most popular squeeling issue in the Maytag dryer is caused from the idler pulley. The idler pulley keeps tension on the belt. The next possible problem could be the 2 rear drum rollers. These rollers are fastened to the rear bulk head and they support the drum. The third possibility is the motor bearing. Usually, when the motor starts to squeel, the motor will shut off suring the cycle and will not restart until the motor cools down.
I would advise you to change the idler pulley as well as the rear support rollers. The cost for these parts are very costly and a little preventive maintainance goes a long way.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Sep 13, 2009 | Dryers
Squeeling noise when dryer runs
Replace the dryer rear drum support bearing.
Problem will be solved.
Feb 22, 2009 | Kenmore 62622 Electric Dryer
Squeeling sound on spin cycle
This sounds like the same problem I had with my 887-327. It seems that coins can fall into the water pump from the bottom of the drum. I had to pull the water pump off the direct drive and turn the blades until the dimes came out. After I reinstalled the pump everything was quite again.
Nov 24, 2008 | Kenmore 88732 Top Load Stacked Washer /...
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
