Question about Yamaha RX-V463 Receiver
Rx-v463, no sound from rear speakers, and hookups
We just bought this system and have spent 4 hours working on this already. We bout the Quintet III speakers and 2 Klipich subwoofers. There is only 1 output for the subwoofer, but the salesman said it is possible to hook up 2 on this receiver but we can't get it to work. Also, we do the auto test and all speakers (except our one sub we can't get hooked up right), but then when it finishes, it will only output sound on the front 2 speakers and sub. We are not getting any sound out of the center or rear speakers. We are shot and I swear I have read this manual 8 times over but maybe I am just missing something still. Can anyone help. We are using HDMI cables and we have a 40" Polaroid TV.
    Novelist:
    Champion:
  • 236 Answers
Sir please check first the volume setting of rear and center speaker it could be set to min. you can not hook 2sub via the sub out because it only has one rca output. but you can use the passive connection via the speakers. you control though the subs by the amount of db you put on your main speakers. if test fails for the rear and center, try using a dvd source and set to any video dsp. raise the volume of rear and center. if still no sound coming, have it checked by the dealer could be a problm with the dsp.
Posted on Feb 10, 2009
  • 6,784 Answers
Sounds like an internal software issue dealing with this device.you may have to return it to the manufacture for this repair.
Posted on Jan 28, 2009
Speakers not playing
The problem can be the cable or speakers or RX-V463 or settings. Need to check one by one.
Set the RX-V on DTS or Dolby Digital
1) Check Cables - connect the 2 (surround) cables from RXV's Centre Out to Centre speaker. If the Centre speaker works, then cables are ok.
2) Check speakers - Connect each Surround speaker to RXV's Centre out. If it works Speakers are ok.
3) Check RXV - Set it on DTS or Dolby Digital
Connect RXV's surround out (one at a time) L and R to the Centre speaker. If there is no sound, the problem could be RXV's settings (I need to read the manual).
Hope this helps.
Nov 20, 2013 | Yamaha RX-V463 Receiver
How do I connect my Yamaha RX-V463 surround sound system to an analog tv? The tv only has the three RCA jacks for audio and video. the RX-V463 has many jacks, and the manual is no help. the manual does...
Actually, the Quick Start Guide on page 6 of the manual shows the TV connection.
Consider that the TV is simply a visual element in your entertainment system and the rest will sound easy.
Run a single RCA cable from the receiver to the TV's Video IN so you can use its menus and view whatever video comes into the receiver.
Manage whatever audio you want to hear in HI-FI directly from its source to the receiver and NOT washed through the inferior audio electronics and speakers of the TV.
Jul 18, 2010 | Yamaha RX-V463 Receiver
RX-V465 is on for 30 - 45 minutes and suddenly sound goes way up and unit shuts down. Happens with audio and video systems and TV. Unit is not overheating.This on a 4 month old machine and problem started...
Maybe some speaker wire is loose and sometimes makes a short-circuit. Check all wires or better disconnect all wires and try to have the receiver turned on without the speakers and see if it helps. If yes, there is issue either with the wires, connections or speakers. If the receiver still powers off without the wires, it is probably faulty and you need to send it for service.
Apr 28, 2010 | Yamaha RX-V463 Receiver
Black screen, hear voices , but no picture playing?
check your screen back Light or get a working screen and test it or your screen flax is bad
Mar 31, 2017 | Mitsubishi WD-73C9 73" DLP TV
Yamaha RX-V463 Receiver Speaker Setup
That receiver has A and B channels. Look for the Speaker button and press it until B appears on the diplay. The other room speakers will play the same thing as in the main room.
Jul 05, 2009 | Yamaha RX-V463 Receiver
Yamaha RX V463 AV Receiver-I have an LG digital LCD tv and hooked up the two up by HDMI and an optical cable. I Only get sound from the right front and the subwoofer The Rest of the 4 speakers have no...
If you're getting audio out of one speaker, it's likely not an issue with how the TV's connected to the receiver, but an issue with how your speaker's are connected.
If you run a "speaker test", do you get audio out of all your speakers? If not, it's likely you mixed up your positive and negative connections when connecting your speakers.
Mar 19, 2009 | Yamaha RX-V463 Receiver
Problem is starting Auto Setup on my Yamaha rx-v463 receiver
You need to press the AMP button before you press the ENTER button. Always press AMP first when selecting menu, enter, any surround mode, or one of the amp functions in ORANGE above the green numeric buttons.
Got this from Yamaha.
BG
Jan 26, 2009 | Yamaha RX-V463 Receiver
Yamaha RX-V463 component hook ups
This receiver does not have video conversion capabilities. In the owners manual it mentions this. So HD in = HD out. Analog in = analog out on the video portion
Nov 02, 2008 | Yamaha RX-V463 Receiver
Rx-v461
but does it sound normal in all other sources?
Feb 18, 2008 | Yamaha RX-V661 Receiver
Yamaha RX-V463 Receiver Logo
324 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
