Question about ASUS G73SW3DE Republic of Gamers 173Inch 3D Gaming Laptop
Laptop shut down and wont power up
Using laptop was plugged in . tried to hook up adapter to charge camera then laptop shut down and wont power up. its not hot or smells funny could it be the power cord
  • ASUS Master
  • 7,627 Answers
Unplug, remove battery, check for dust in fans and vents, plug in, try to reboot. If it powers up, open Control Panel, Power Options Power , set to High Performance, open Advanced Power settings, set Sleep and Hibernate to Never, Adjust other Advanced settings to your preference. Has it been pulled by the cord? If you have a multimeter check for DC volts at the AC jack plug, that plugs into the laptop. Is the Transformer (brick on the cord) getting warm when plug in? Does the battery charge LED light? Try another cord with the EXACT same power specs.
Posted on Jan 23, 2013
4 Suggested Answers
  • 96 Answers
SOURCE: Burning smell on my laptop
Unless you have the ability to to replace the plug connector part yourself, you will have to take it in to a shop who can do that kind of fine soldering for you. If nothing else is damaged, it should be ok with replacing just that burnt out part.
Posted on Jul 12, 2008
shashank rai
  • 60 Answers
SOURCE: when i plug the power adapter in the laptop wont
no, there is problem with ypur power adapter plug which links with your laptop .few days back i ws having the same problem
Posted on Jul 17, 2010
  • 2567 Answers
SOURCE: I lost my power cord
You will need to buy another power cord for the exact model of your laptop. You can either find it in local computer stores, or you can search for it on ebay.com (usually search by laptop make & model, & usually buy from a top seller).
Posted on Dec 11, 2010
Battery won't hold charge
It most likely needs a new battery, but you could try giving the battery a full charge first:
1. Power off the laptop and disconnect the power adapter.
2. Re-seat the battery (remove/reinsert)
3. Reconnect the power adapter and let it charge overnight. (6 hr+)
4. Disconnect the power adapter.
5. Power on the laptop (run under battery power only)
If it doesn't boot up and shuts down immediately, it's probably time to see about a replacement battery.
2.
Jan 11, 2013 | Samsung Q430 Laptop
Laptop wont recognize charger
Maybe you did damage a component due to overheating? What caused the Laptop to overheat? Does the battery work on another laptop?
Dec 29, 2012 | ASUS Computers & Internet
Hi, my laptop crashes when the ac adaptor is plugged in yet it will charge the battery fine when the laptop is shut down.
Problem description: The laptop shuts off when AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
Possible cause: 1. Power adapter failure.
2. Motherboard failure.
Possible troubleshooting steps and repair solution: First of all, test the power adapter. Make sure the adapter outputs correct voltage. It's possible that the output voltage is not correct and the laptop shuts down to prevent the damage. Test your laptop with another known good power adapter.
If the problem still exists, even after replacing the adapter, most likely it's the motherboard failure. Replace the motherboard.
Resource: Acer Laptop AC Adpaters
Mar 20, 2011 | Acer Computers & Internet
Gateway wont power up the batt has been failing ,if pluged in the charging light comes on for a while then goes out if you try to start it tries then shuts down. could a bad batt cause this
If your battery is more than 2 years old, then it is a distinct possibility. Every battery type has a certain number of charge cycles (drain->recharge->drain) or time period. Lithium batteries run about 2 to 3 (tops) years. NiMH run about 10,000 charge cycles (or it could be 50,000 cycles if you know what to do). But if you're NOT using the original Gateway charger, then plug it into your laptop and see if it works. The 3rd party charger may have burned out the internal power components over time. In the worst case, you'll have to replace either the motherboard (hope you still have the product key!) or the motherboard's power connector, inside the laptop. At best, you might have to continue using the original power adapter. It will probably turn out to be a worn down battery, which needs replacing.
Feb 19, 2011 | Amstron Gateway P170X Laptop AC Power...
Acer aspire 5517 laptop,is plugged in, but is not
try removing the battery and connect the ac adapter. check if it powers up.
Feb 14, 2010 | Computers & Internet
Laptop wont turn on
Try removing the battery and plug in the power adapter and then power on your laptop. If this doesn't work, put the battery back in and plug in the power adapter and try turning it on. If that doesn't work then take the power cable out and try with only the battery. Try in this order and see if it comes back up, if not, you may have some dead hardware.
Mar 12, 2009 | Gateway M305CRV Notebook
Wont turn on
pull the battery and try to power on. if no good test the power adapter with a meter - should give 18-19 volts. if it boots with battery off, power up and put battery back on to charge.
hope this helps
Jan 17, 2009 | Acer TravelMate 6460 (LX.TED0Z.071) PC...
Gateway laptop
Probly its overheating and shuting down.But if it do turn on try to run in safe mode by pressing f8 when booting up.
May 28, 2008 | Computers & Internet
When ac is plugged in the power light blink & notebook unresponsive
Sounds like your ac adapter (brick) is bad and not supplying correct voltage/amperage.
Apr 03, 2008 | Toshiba Satellite 2805-S603 Notebook
ASUS G73SW3DE Republic of Gamers 173Inch 3D Gaming Laptop Logo
100 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
