I can't get my computer to recognize the port that printer is plugged in to. I just bought this printer and it won't print anything. I have tried troubleshooting and the printer makers on line support.
  • Wayne Mineard
    Wayne Mineard May 11, 2010
    More specifics please:
    Make and model of the printer.
    Operating system you are using.
  • Richard O
    Richard O May 11, 2010
    Is it a usb printer?
    Scholar:
  • 164 Answers
Normally Windows will automatically detected and load drivers for standard, ECP, and EPP parallel printer ports. USB ports used for printers, that's more complicated and often requires that drivers and/or software be loaded BEFORE connecting a USB printer
Posted on Feb 20, 2009
Why won't my printer print after I installed the software? It says its ready but nothing will print
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 18, 2011 | Lexmark PhotoJet Z705 InkJet Printer
Computer doesnt recognize the printer
1.) Check the power plug for the printer and make sure all cords are connected properly.
2.) If the printer plugs in via USB, try all of the USB ports on your computer. (if not disregard)
3.) Uninstall old printer software/drivers (if any)
4.) Sometimes all you need for it to recognize the printer is to restart while it is plugged in.
5.) If you think the printer isn't recognized, still try and print something. You may find it to be a choose able printer in the print window.
Hope this helps!
Feb 22, 2011 | Computers & Internet
HP J4680 Printer worked fine then suddenly stopped.
Generally a reset or, unplug and re-plug in can clear the problem..
Jan 31, 2010 | HP J4680 Office Jet All-In-One Printer
USB not recognized during printing and scanning
Some motherboard or operating systems have problems if you leave usb devices plugged in. They don't recognize that the device is still there and ignore it. These are referred to as "Legacy USB devices". There are a couple of things to try.
Make sure the problem isn't the printer if you can. If you have another computer just plug it in long enough to for the operating system to recognize something has been plugged in.
On this computer giving you the problem. unplug the usb cable and insert into a different USB port. Usually this is enough to "fix" it and make it usable.
Next is to unplug the usb and reboot the computer a few times. Then insert into a different usb port.
Past this point if it still isn't working then you need to go to control panel-system-hardware manager-usb devices and delete all entries under the usb header. Then reboot. This forces the operating system to find all the usb ports and reinstalls the drivers. Then plug in the usb and it should work again.
Oct 23, 2009 | HP Photosmart C3180 All-In-One InkJet...
Bought new computer - no parallel port. bought
got to printer and faxes left click your printer and select properties then click "port" tab now look for USB and check mark it click aply and then close then try to print :)
Sep 23, 2009 | HP LaserJet 6mp Printer
HP Laser 4L driver for USB port
Not all USB adapters are the same, you need the one that is made for your printer, I would try a different adapter before going too deep, because when you plug it in your computer should see it even without drivers.
Jul 21, 2009 | HP LaserJet 4L Printer
HP Photosmart Printer, Mac won't recognize with USB
Sounds like their is not communications between your printer and computer. Could be a bad USB cable - swap out and see if that fixes it. If not it could be a faulty USB port on the computer or printer. You can check the computer USB port by connecting another device, but there is no way to check the HP's USB port. I would also check printer USB port for dust bunnies! If you're not able to resolve, I think it is time for another printer.
Jan 07, 2009 | HP Photosmart 8050 InkJet Printer
Computer won't recognize USB ports
If you are plugging a USB device into a different port it takes some time to recognize and install it - it re-installs for every port. There could be cable and/or port issues as well. Plug the printer into a USB port that the mouse does work on and allow several minutes for it to detect install it.
Dec 18, 2008 | Dell Dimension E521 PC Desktop
Recognizes printer, won't print
What i'm getting at is if the printer was not used for a long time the cartridges may have dried out.
Robert
Aug 30, 2008 | HP Photosmart 8250 InkJet Printer
My hp psc 1210 won't work with vista
I had a similar problem! Here is what eventually worked for me, after searching through postings for hours on end...
First, I made sure I had the new driver. Second, (and this might be different for you), my computer recognized my printer, but any time I sent something to print, it never made its way there. The little printer icon at the bottom said 1 document pending, then quickly said 0 documents pending, but nothing ever printed. When I ran HP diagnostics, it said everything was okay with the printer, and even printed a test page! But still nothing from any other program. So, eventually I went to control panel, then printers, then I clicked on the HP printer, then right clicked and went to properties. I changed two things in here, and I'm not sure which one was the solution. First, I changed the security settings (in the security tab) so that every user had access to all options for the printer. Second, on the advanced tab, I selected print directly to printer instead of the spool print documents option. And tada it worked!
May not solve anyone elses problem, but I didn't see this solution in any of the posting sites, so I thought I'd share it. Give it a try!
Aug 27, 2007 | HP PSC 1210 All-In-One InkJet Printer
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
