Seeking information on jbl ap25 3 way speaker
Need to print out speaker details
I would like a full manual for the JBL xtreme speaker?
JBL Xtreme ' Splashproof Bluetooth Speaker with ... - JBL.com
www.jbl.com > Wireless > Portable Bluetooth Speakers
JBL
Rating: 4.7 - ‎35 reviews
Splashproof JBL Xtreme Bluetooth speaker with explosive sound, 15 hours playtime, dual USB port can link multiple speakers and ... Product Specs & Manuals.
JBL Xtreme ' Splashproof Bluetooth Speaker with Powerful ...
uk.jbl.com > Wireless > Portables
JBL
Rating: 4.8 - ‎36 reviews
Splashproof JBL Xtreme Bluetooth speaker with explosive sound, 15 hours ... http://uk.jbl.com/bluetooth-portables/XTREME.html? ... Product Specs & Manuals.
Jan 05, 2016 | JBL Audio Players & Recorders
How do i charge a jbl speaker
Charge? What is model designation please? Add this detail and resubmit for service
Jun 04, 2015 | JBL Audio Players & Recorders
No more subs in jbl prx-512m
First check the speaker with a multimeter.
If it is OK, then check/repair the Class D amp that drives the speaker,
up to the input stage.
There are board part numbers printed on the PCB and some are
available on line.
Have a tech to guide you ,should you feel to Diy.
Oct 17, 2012 | JBL New Jbl Prx512m 12 Powered Monitor...
My speaker no sounds, were is the JBL service center in the philippines?
Hey there,
I did a search on the JBL website for you, here is the address and the phone number of the JBL Service Center in the Philippines:
Philippines
AUDIOPHILE
1142 Pres. Quirino Ext.
Paco, Manila 1007
Philippines
Tel: +63 2 588-0918
Fax: +63 2 564-1720
If you need any additional information, simply post a response on this page. I`ll be happy to assist you further. :)
Regards,
Aaron Busch
Senior Tech of LiveFix Support Services (LiveFix.net)
May 02, 2011 | JBL CREATURE II Computer Speakers
I need a driver for JBL speakers E221915
are we talking about the driver as in woofer or driver and in computer driver... there isnt a computer driver since this is set up as a portable music speaker for ipod or mps players. but if you need a replacement woofer you can order one using this information.
Visit the Harman Audio Store to purchase accessories & replacement parts for your products or call 1.800.336.4525 9:00am - 6:30pm EST Monday - Friday.
Jan 30, 2011 | JBL (JBLONTOUR) Computer Speakers
I have a set of teac speakers that are about 40 years old and I need to replace a woofer. I just do not know which one to buy. The speakers were bought in Germany, the model number is LS-80 and they have...
These sound like they a JBL speaker.
1. You will need the impedence and diameter spec and the Hz (hertz) specifications to get a replacement set.
you can call JBL Altec-Lansing is the company that manufacturer this series of speaker.\ On the back of you speaker cabinet should be a phone number to the company or check the user manual that you received with the speaker system and they should be able to give full information on how to replace the speaker in question or where to have it repaired.
The cabinet is glued together and will need a cabinet expert to disassemble.
Contact JBL for more information.
Mar 10, 2010 | Electronics - Others
I HAVE 2 CABINETS THAT IM PUTTING 3- 15" JBL SPEAKERSPER CABINET THEY ARE FOR OUR BAND. HOW WOULD I WIRE SPEAKERS TOGETHER. IM AM USING BEHRINGER 2400 AMPS
In order to give you details for connecting the speakers I need to know:
Each speaker details (nominal impedance and handling power).
Since the Behringer 2400 is a discounted model (or misspelled model), the lowest output impedance that this amplifier can handle.
Is there any possibility to plug both the cabinets at the same amplifier?
Reply at this post.
Thanks and regards
Please kindly rate this solution
Stelios
Sep 10, 2009 | JBL 6-1/2\ Round Coaxial Speaker By...
Need to know polarity of power supply for JBL
Look where the plug goes in
There will be a C shape with a dot in the middle. Follow the line attached to the dot and you will see a + or - which is the polarity. Next you need to know Voltage. Look in the same area, or on the label for this info. If there is NO info by the power plug, it might be AC, which has no polarity - just plug it in. The label may have this information and will say something like 12VDC or 12VAC that is the key. DC Matters (+ and -) AC does not.
Mar 26, 2009 | HP JBL Platinum Computer Speakers
Jbl eon g2 problem!
Could be any number of things, the amp may be damaged (do you use these things at high volume?) but if you are only getting bass it could be a fault on the crossover circuitry. Could be a loose wire inside but the build quality on JBL is pretty good so I doubt that.
How long ago did you buy them? If it was recent you may be able to take them back to the shop, otherwise I'd seek a professional repairman.
Btw, did you check the fuse?
Dec 02, 2007 | JBL EON 15-G2 Powered DJ Speaker With EQ...
78 people viewed this question
 Grubhead
Grubhead
