Question about Canon ImageCLASS MF4450
Mf 4450 prints black streaks
I recently changed the toner and since then I have had nothing but problems. I frequently get the error of wrong paper size, there are black streaks on the printed paper and sometimes the print is either stretched or shrunken.
  • Gilles Jan 24, 2013
    Thanks for 3 replies. This is a printer that is practically brand new so I'm hoping not to have to replace parts. I actually reinstalled original toner cartridge and printer works fine. I believe it is the drive end mechanism on the replacement cartridge that is defective/broken.
Paeroa
  • 457 Answers
SOURCE: "wrong size paper"
Change the cofiguration of the size in your fax machine see if accepts them then
Posted on Sep 09, 2007
Logjam
  • 159 Answers
SOURCE: CKECK PAPER & RECEIVED IN MEMORY
The problem is the paper size doesn't match the size of paper set by the machine. Usually this is corrected by changing the paper in the tray to legal size. However, you may have changed the size of paper in the data, so check that in the user settings.
Posted on Jan 20, 2008
SOURCE: Printing problem
I solved the problem on the MP530 printer of a friend of mine.
BUT: If you are not a DIY, I would strongly recommend not opening this machine.
It took me more than a couple of hours to disassemble, clean and reassemble again.
If you follow the disassembly instructions below, you might be able to do this faster than I did, because I had to figure out how to open the case without breaking anything.
Also, in the end, you will need some less ordinary tools like a very tiny crosshead screwdriver and a slim stick with a hook at the end to get the springs back on their places again. I used a steel instrument with a hook my dentist gave me but I guess one can fix a tool with a bent paperclip.
SECOND BUT: I cleaned up the consequences of this problem so the printer works fine again without that black streak on the back side of the paper. This does not mean that I found and fixed the problem.
Because I have not been able to find out where all this ink comes from in the first place. It is obvious that this ink is NOT produced when the printer prints because in that case it would have been on the front side of the paper and not the back side.
In this printer, once I had disassembled all and was left with the bare printer basement and the unit which does the sheet transport out to the front, I discovered a real mountain of nearly dry ink. The bottom of this mountain was sitting on the basement of the printer which is covered with a special kind of absorbing material which is supposed to deal with waste ink. And the mountain was high enough to rise through the sheet transport unit. Which explains the black streak.
As someone else said, the top of the mountain is underneath the big black cartridge.
So, one might say that this cartridge is/was leaking. But I have not changed the cartridge and the printer does not leak anymore.
To check this, once up and running again, I have been sliding a small piece of paper underneath the inner cover (the one you have to open if you want to change a cartridge).
By inserting this piece of paper while you pull down the cover (which enlarges the inner height of the sheet transport unit) you will be able to push the paper way in, underneath the area where the leak should be.
Whether the printer is off or on, in economy mode or cleaning heads, no single drop of ink came out.
It might of course be that my friend had not completely inserted the cartridge as it should, but in that case the printer should have warned, don’t you think?
I also found that exactly on the spot where the mountain was sitting, there is a small plastic tube which goes right, to the area where the heads are cleaned. I know that this tube is to transport waste ink, but I don’t know in which direction. If it is supposed to suck ink out of this place and spit it out in a lower level absorbing reservoir then fine, but what if it operates in the opposite direction? Then it would be able to spit ink underneath the paper even while you are printing… I am sure that real printer technicians have the answer to this question, so if someone wants to help us out with this one…
Do you still want to clean your printer? (Because that is all I did in the end).
Here you go then:
Next steps in the next post, since apparently text length is very limited here.
Posted on Jan 27, 2008
SOURCE: "always getting check paper size"
the sensor flag at the rear paper path sensor is worn down too short. i have seen this many times
Posted on Jun 04, 2008
SOURCE: i80 black cartidge not printing
Im having the same problem!!!
Posted on Jun 24, 2008
How to solve frequent 'paper jam' error in canon mf 4412 - any solution
Hi
have some experience in repairing printers, if you have to replace the maintenance kit.
now is not expecialista in printer, take the one that will solve.
Jun 11, 2014 | Canon ImageClass MF4412 Toner Black Repl -...
How come my Canon ImageClass MF4122 printer gives fuzzy images?
That is best bet since it appears that your print head is fubar and Canon charges a fortune for them. Cheaper to get a new printer with warranty.
Aug 24, 2017 | Canon New Compatible Black Print Laser Ink...
Bl;ack streaks on paper
Pull down the manual feed tray door.
Load a few sheets of paper in tray 1.
Print something.
As the paper feeds into the printer observe it.
When the paper gets halfway in, open the top cover.
Lift out the toner and look down at the paper.
Does it have a black streak? If yes...change the toner.
If no...change the fuser.
Feb 22, 2011 | HP LaserJet 4 plus Printer
Our copies are streaky like the drum is not clean.... help! There is black streaks on the top of all of our copies on our canon imagerunner 3300.
A) Black Streaks, Shadows, And Ghosting
Adjust the printer's lightness/darkness setting to 2-3 different variables and see if problem disappears. Look at the fusing assembly - is the roller torn or does it have any black buildup? Use caution!!! It gets HOT!
Try another toner also.
Feb 17, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Papers come out with black streeks on them from my sharp FO 4450
If everything is coming out with streaks, it's most likely your cleaning blade which is part of the drum cartridge. I've also seen this from 3rd party toner. Get Sharp toner for your Sharp fax if you don't have it already. If your black streaks are only on copies and sent faxes, this indicates that your scanner is dirty. It's located where you feed your paper in. Lift this part up and you'll see a strip of glass running front to back about 1/2 inch wide. Clean it and that will get rid of lines.
Oct 12, 2009 | Sharp FO-4400 Fax
When copying a black streak
probably a defective toner cartridge, try another one.
Jun 03, 2009 | Office Equipment & Supplies
CLP-500 vertical streaks & a horizontal line with blotches appearing randomly
I've refilled the toner cartridges a few times now and never had a problem with vertical streaks until recently. I refilled both the cyan and magenta and when I ran the test page I had dark vertical streaks on both sides. I fiddled around cleaning things, running cleaning paper through, changing reset resistors but to no avail so eventually decided to buy a replacement refurbished cyan cartridge since the streaks looked mainly blue and bingo... well almost now I just have very light magenta streaks. The issue is obvious when I compared the old and new cartridge, the replacement toner is a much duller cyan and is of the wrong consistency since once it's been in the printer everything gets covered in it which is why I think it causes the banding to occur. I'm just trying to work out now whether to try refilling the magenta again (v. messy) or just go for another refurbished cartridge (£34).
Jun 12, 2008 | Samsung CLP-500 Laser Printer
Canon ImageCLASS MF4450 Logo
104 people viewed this question
old marine
old marine
