Question about HP Officejet Pro L7780 All-In-One InkJet Printer
L7780 has died. I unplugged the ethernet and the whole thing died
No power at all now. no #3 or #6 or ok #3 or 0n #6 or on ok nothing brings it back to life, I unplugged the power chord from a strip and put into a direct outlet. Nothing Dead! it's less than a month old.
  • 142 Answers
Return under warranty....sounds like power supply or main board died.
Posted on Jan 28, 2009
We purchased our DVD player about 3 mths ago and everything was fine, then about a week ago after the kids were watching TV and went to record a show the DVD turned itself off. Now when we turn on our DVD...
If you only purchased it 3 months ago it should still be under warranty.
Just bring it back to your place of purchase for a refund or exchange.
Apr 16, 2011 | Televison & Video
Our HP Officejet Pro L7780 All-in-One have had a paperjam. I have removed all the paper, but the printer shows the whole time there's a paperjam again. The printer makes a sound when you turn on the...
Try unplugging the power cord of the printer from the back of it while it's turned on and then plug it back in.
If you still gave the message try pressing ok and see if you get rid of it.
Here are some work arounds for that issue:*Try removing and reinserting the cartridges and make sure they are properly fitted in. *Remove and reinsert the duplexer *Try cleaning the rollers infront of the printer and from the back of the printer. *As for the rollers try, moving them and turn them around with your fingers. *Turn the power off and then on
This is a hardware issue already so if all else fails for your printer. It's better to just call tech support. If the printer is in warranty they will be able to replace it. If it isn't they might let you in on a good deal.
Feb 03, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
My HP L7780 will not print blue although it has a new cyan cartridge installed. The print head tests okay on the control panel.
If the machine functions well otherwise ( no errors ) then you should try to run the cleaning function from the printer software. Locate the printer in the printer folder and right-click the icon and select properties. Then select preferences at the bottom of the window, and select the maintainence tab. Select clean, and follow the directions. If you see no improvement after 3-5 cleans, it is more than likely the printhead. Contact HP directly to see about warranty replacement of the printhead. There is a warranty date on the side of the printhead itself. The printhead may also just be prematurely defective, so if out of warranty, try to replace it.
Sep 29, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
The printer screen freezes and i cant do nothing i have disconnected the power sometimes it work but freezes again
Please follow the below steps.
STEP 1.
1. Un plug the power chord from the back of the printer.
2. Press and hold the power button of the printer.Wait for 30 seconds.
3. While holding the power button, re-plug the power cable.
4. Turn on the printer, if it is not on.
STEP 2.
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
May 13, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
Rt164 reset button does not work to default
Hi friend
I hope it will work for you,please follow the steps:
1) Give the router power,then with a pen press the reset button for 10 secs,after that unplug the power cable from the router for 10 secs and wait
2) After 10 secs plug the power cable back,and press the reset button for another 10 secs,after that unplug the power cable again for 10 secs. and wait.
3) After 10secs plug the power cable back and press the reset button for 10 secs, after that unplug the power cable again for 10 secs and wait.
It will bring the router back to default settings.
now if your ethernet ports have limited connectivity,please follow the steps:
If you have windows XP try this
1) connect the computer with a wire to the router
2) click start menu>contrlo panel>to your left you will see switch to classic view,click that
3) Double click and open the icon named network connection
4) right click the icon named local area network connection,click properties
5) Now click the tab named "configure" under the general tab
6) Click the tab named "Advanced"
7) Under that tab you will see something named "Property"
8) Inside that white box you will see either "Speed/Duplex" or "Link Speed/Duplex", select that
9) To your right just beside property you will see 10 mbps half duplex,select that and click OK
10)Click Ok if you find any or click Close,whicever is there.
Restart the computer and enjoy working without any limited connectivity.
warm regards
Chiranjeet Mitra
Oct 08, 2009 | Computers & Internet
I have a paper Jam... how do I solve this????????
ok so the paper is in the printer right now and is stuck?
Jul 20, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Paper Size Error: The specified custom paper size is not supported in the selected tray. I have a Hp Officejet pro L7780 All in one. I checked the default printer and paper handling and it all says letter...
1. Press the OK button to bring you back.
2. Press the menu button repeatedly until paper size comes up
3. Use arrows to change paper size from automatic to whatever size you are looking for.
4. Start Copy
This worked for the HP Officejet 7210 All in one
Jun 01, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
C330 wont turn on or power up
It took a nap...
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Jan 22, 2009 | Garmin StreetPilot C330 GPS Receiver
HP L7780 will not align and will not print in black. When I print out the self-testpage, it prints only in magenta. I have gone through 5 hours of BS with HP and nothing seems to work.
I just went through this problem. I called HP and they said to do a Semi-Reset, which is where you first make sure the plug is directly plugged into the wall outlet, not a power strip or battery backup, unplug the printer while it is powered on, wait 20-30 seconds,and while holding # and 6 plug the cord back into the printer, wait for a message or blank screen and then push the "On/Off" button. This has worked for me a few times now, although you have to go through some setup to get it back to where you like it.
Dec 20, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
"Turn Power Off then on Again" error
Try performing a reset on the device. Unplug the power cable, then hold # and 3 while powering it back up.
Aug 20, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
HP Officejet Pro L7780 All-In-One InkJet Printer Logo
76 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
