Washing machine starts washing on drying cycle
  • Washing Mach... Master
  • 17,129 Answers
Possible that there are errors on the memory that seems to make the cycle go out of turn. Switch off machine for sometime, press down all control buttons, when switching back press and hold start/stop button.
Also check the inlet and drain filters and valve, check door switch.
Posted on Jan 24, 2013
Coldcut
  • 1554 Answers
SOURCE: washing machine slowly fills with water when off
Its likely the diaphragm on the water valve is clogged with hard water deposits and is leaking.
You can try to fix it by running some CLR cleaner through the water hose with it disconnected from the tap. or just replace the water valve.
a symptom of this issue is that water is always filling the machine. and you have hard water.
you can get to the water valves and take them out and replace/clean them by removing the top cover (3screws in top rear)
unplug the AC cord.
follow the water hose from the tap the first dual block you see has 4 wires and the hoses plastic connected to it. easy to remove.
But if the machine is not leaking all the time and the machine just wildly decides to activate the relays for water ( you will hear the solenoids click for more water flow then the issue could be the computer control unit.
Posted on Feb 13, 2008
  • 96 Answers
SOURCE: E20 error when starting tumble dry cycle
E20 on your machine means some sort of Drain problem. If it actually goes through the Spin cycle o.k. then there is most likely some water still not drained out at the time of the tumble dry. Check the drain to make sure it isn't clogged. also the drain hose.
Posted on Mar 12, 2008
SOURCE: My WVF 2402 washer/dryer washes clothes ok but doesn't dry them.
Sorry I'm way late with this but I've only just noticed it. Unplug the machine from the mains! Remove the lid (with a torx screwdriver) and you'll notice a small circular device with 2 leads attached on the top of the machine, in the centre there's a small button, press it and it should click......you've fixed it This is a thermal cutout safety device designed to switch the drying heater off if it becomes too hot. The probable cause for this is that you've over filled the machine and the air didn't circulate freely. as a rule of thumb, dry 1/2 as many clothes as you wash.
Posted on Apr 26, 2008
SOURCE: why wont my machine start drying?
I called Whirlpool on 08706008989. The machine can only dry half a load of washing at a time. At the end of the washing cycle, the Programme dial should be at either the sun or half sun symbol. Remove half the washing, set the drying time via the drying time dial and press the 1/2 Load Dryer button - Voila dry clothes!
Posted on Jul 14, 2008
hattonhall
  • 349 Answers
SOURCE: the machine washes fine, but adds water on the drying cycle
The machine sounds faulty. You can bypass this by turning off the tap and respinning the clothes until the machine is fixed properly,
Posted on Oct 19, 2009
Testimonial: "Thanks for clarifying that it is a washing machine problem as opposed to a plumbing problem. "
The dishwasher runs through it's cycle but does not clean the dishes properly and leaves a cloudy film and smears on the inside of the machine and the dishes
    Common Problem
  1. Confirm the wash water is hot
    1. Try heated wash(sani wash) if available
    2. Run hot water in sink to warm up before starting
    3. At least 120 degree Fahrenheit water temperature
  2. Open door check wash arm position start washer for a minute
    1. Confirm wash arm has rotated
    2. Check for plugged spray tips at either end of wash arm.
    3. Use small tweezers to remove
    4. Check for rack and dishes interfering with arm rotation
  3. Place cup in upper rack with opening up cycle washer.
    1. Confirm that cup quickly fills with water
    2. Not washing check water level in tub mim 1 1/2 inch
  4. Discontinue use of rinse/dry liquid additive.
    1. Confirm rinse/dry additive not leaking from dispenser into tub
    2. Washer detergent contains sparkle additive and too much sparkle/rinses/dry additive will coat dishes
    3. Try alternative wash detergent that contains minimal rinse/dry additive and use without liquid rinse/dry additive.
  5. It will take several wash cycles after the elimination of rinse/dry to purge the oily film from dishes and machine..
  6. If success "joy" is achieved with no additives then cautiously add back wash detergent with additives. Additives are important to facilitate drying and protecting the glassware china from leaching. The leaching process permanently etches the surface of glassware leaving a cloudy appearance.
Jan 03, 2016 | Dishwashers
My Zanussi WJD 1257 washer/dryer's drying cycle has started finishing early. No error codes. The wash cycle works fine but the drying cycle is simply stopping prematurely. You can set it to dry for 45...
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 01, 2013 | Zanussi Washing Machines
Error 4 ON HAIER WASHING MACHINE.
Error U04 means the door is open.
Put your knee against the door handle and press it against the handle until you hear a click. The machine should start filling within a minute.
This is a problem I had start occurring about a month after I started using the machine. You will soon do this for every load, a minor annoyance on a cheap machine.
Error EC4 refers to the temperature of the air vent.
Within 30 minutes of dry cycle there is 5 minutes in which the temperature is not increasing.
Ask the technician to
repair it.
Alternatively make a custom cycle with no drying cycle and hang dry the laundry. I usually do this myself as opposed to listening to it groan for 2-3 hours.
Aug 10, 2010 | Haier HWD1000
Water building up during the dry cycle and clothes getting wetter
1) Make sure wash cycle is 100% finished (sometimes dryer will start before - usu on synthetic cycle & allows water to continue flowing in)
2) Manually start the dry cycle after you ensure wash cycle is finished and push in the wash cycle button.
Hope that helps! If not, you may need a new control module (I did - hope you don't!)
Apr 19, 2010 | Haier XQG65-11SU Front Load Washer / Dryer
Whirpool 1100TXP Dishwasher.
is your water temp set at 120 degrees
Apr 07, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Cant use dryer
Hi Haziel,
Is it that you want to dry only or wash 'n' dry straight through in one go?
If it's to dry only...
1. Switch the machine on
2. Press the Auto Dry or Timed Dry button until the neon light illuminates.
3. For Auto Dry press the button for 2 seconds to achieve the neon indicator to light up. then press the button until the glow is beside the level of drying you require.
4. For Timed Dry press the button until the time you require is in the display.
5. Press the Start/Pause key to start the cycle
Please note: in the Timed dry any time above 60 minutes will be displayed as 70, 75, 80, 85 etc. but then will be shown as 1:10, 1:15, 1:20, 1:25.
For wash 'n' dry straight through...
1. Switch the machine on.
2. Select the fabric.
3. Change the temperature or spin speed if necessary.
4. Select any extra options if required.
5. Follow the above to achieve the drying accompanied by the wash.
6. Then press the Start/Pause button to get the cycle under way.
There is a downloadable PDF of the user manual for this machine on the Service Force website, if you require the programming sequence guide, which, is covered in the user manual, should this explanation prove unhelpful.
I hope this does help you
WD Pro
Feb 17, 2008 | Zanussi WJD1667W Front Load Washer / Dryer
LG Washing Machine All-in-One
Some magic happened today!
I got the thing (wd-12331ad) to dry without having to run a wash first!
Also, I seemed to get it to do a spin only run...
The way to get it to dry :
(for a set time - I've not managed to get any of the auto-dry settings to work)
from machine being off:
> press the power button.
> press the "Dry" button 'til "Time" lights up
>>> press "Dry" again to get the desired duration
> press the spin button 'til the spin speed shows blank/ the RPM light goes out.
> press "Start/Pause"
It will then dry for the number of minutes specified!
Not perfect, I know but that's serious progress from where I was before; having to re-run a wash cycle to get it to dry anything...
Something to note:
- The machine worryingly sounds like it's starting to fill with water when you start the "Just Dry" program which scared me at first. BUT it stops after a second or so (I think it's just cleaning out the detergent tray so it doesn't bake any leftover powder)
For "spin only" from machine being off:
>>> if you press "Start/Pause" now you get a 13 minute 1200 spin cycle
>>> press the spin button again and then "Start/Pause", it seems to drain itself for 1 minute
>>> pressing spin repeatedly, cycles through the spin speeds.
Things I don't know:
- I don't know if you can combine spin and heat.
- I don't know whether the auto-dry programs are available
- I don't know what other programs are available from the "Dry"/"Spin" buttons
...So if anyone does any experimenting, please let us know the results, you never know, we might end up with a half way useful set of instructions! I'm starting to think the machine's not half as bad as it seems when following the manual alone.
Hope that helps.
Will
Jan 03, 2008 | LG WD-12126RD Front Load Washer / Dryer
Why wont my machine start drying?
Oct 28, 2007 | Whirlpool AWG320 Front Load Washer / Dryer
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
