Question about Coaster Louis Philippe 200431 Sleigh Bed
Lost machine bolts for louis philippe sleighbed
Bolt size for side rails
  • lynn miller Jan 24, 2013
    Thanks very much, very helpful.
  • 3,904 Answers
You can pick replacement up at a hardware store. If you need to figure out how long just line up the holes the bolt goes through, put a straw or somthing like it through, mark the depth and that is the size you need. I am guessing it is about a 3 1/2 inch long bolt at 3/8inch in diameter....may be a 1/2 inch in diameter.
Posted on Jan 23, 2013
I need replacement bolts for a Pottery Barn king Sumatra Bed.
It is very likely they are metric threads. 6 or 8 mm are most likely.
These thread sizes come in two different thread pitches (fine and coarse). Buy a mix at a small hardware store. You could even bring the headboard with you and a friendly associate might bring a handful out to the car with you to test which one fits.
Sep 04, 2014 | Baby Gear
Alternator bolt size
the head size for socket size or actual bolt spec.?
you lost the bolt (not stated) or just want to unscrew it?
I'll'' guess at lost.
its metric.
and is 6mm or 8mm ? in size. (i bet 8)
buy some 6 and 8s in the store and see if one fits.
if one fits , you now know the diameter in mm and the pitch.
now buy the correct length (use a ruler)
Jan 27, 2014 | Honda CR-V Cars & Trucks
Bolt size for 2008 ford focus side mirror
Thread size is 8mm 10mm is the head size meaning you use a 10mm socket
Apr 01, 2013 | 2008 Ford Focus SE Sedan
What size wrench do I need to remove the rear bolt on the bracket over the fues rail replacing the intake manifold?
I'm sorry but I do not know what size wrench you need for that. You might call a Lincoln dealership and see if they know. A workshop manual might also have that information. Good luck!
Dec 26, 2011 | 1999 Lincoln Town Car
Abs sistem code c0265
ABS light on, DTCs set. Some 1999-2004 midsize and full-size GM pickups and SUV's (full list below) may illuminate the ABS light and store DTC C0201 or C0265 in the ABS computer. In addition, code U1041 may set in other modules or you may encounter lost communication between your scanner and the ABS module.
According to GM, all of these problems are probably due to a bad connection at ABS ground GlK), which you'll find on the frame rail just underneath the driver's-side door. Restoring the integrity of the ground should eliminate all the problems. Here's how to go about it:
Start by getting the truck up in the air. Next, locate ground GIlO at the frame rail. Note that several ground wires may be there, but GIlO is the one with the heaviest wire (12-gauge). Disconnect the ground from the rail and use a "whiz wheel" to clean the area in front of and behind the ground connection. Now get a bolt, two star washers and a nut. Install the bolt, ground connection eyelet and star washer on one side of the rail and the other star washer and nut on the other side. Torque the nut to 79 in.-lbs. To complete the fix, spray the bare frame rail with rubberized undercoating (Part No. 12378398 or equivalent), lower the truck, then conduct a road test to ensure that the ABS light stays out.
Mar 01, 2011 | 2000 GMC Safari
I need to know what bolts to remove in order to remove the seats from a cadillac escalade ext
Hello: First remove the plastic covers at the front and rear of the seat tracks (do it carefully so you don't break them) then remove the bolts in the rear (move the seat all the way forward) one on each side. It will either be a 15mm bolt head or a torx head bolt depending on what year truck (don't remember what size torx) after removing rear bolts, move seat all the way forward disconnect ALL electrical connectors, tilt seat forward to disconnect hooks in seat rail and you should beable to remove seat. On some tear models you may have to disconnect the seat belt.
Feb 08, 2011 | Cadillac Escalade EXT Cars & Trucks
Exhaust Manifold giving me trouble
If you have a Drill Machine and access to the snapped bolt, then drill a hole smaller the bolt size in the cetre of the bolt, then insert the Bolt Extractor tool in the centre of bolt, lightly hit it with hammer so it grab the bolt.Now with proper size of spanner tight Extractor Tool in side the snapped bolt by moving the spanner anti clockwise, In this way you can remove the snapped bolt. Note: The ribs or threds of Extractor Tool are opposit to the threads of the normal bolt. So you tight the Extractor Tool, you are unscrewing the snapped bolt.
Jun 02, 2009 | 1993 Nissan Maxima
Trying to turn our crib into a toddler bed
Part needed: Allen Wrench
Safety rail
Safety rail bolt
Make sure the mattress support in in lowest position. Remove the front top rail and front panel. Attach both safety rails ( small side pieces) to the crib end leg using the safety rail bolts.
Mar 25, 2009 | Delta Enterprise Baby Gear
Convert to toddler bed
They do have answers on their website, you may want to check your printed or online crib instructions to remind yourself how you put the crib together, too.
I found the answers here:
http://www.pali-design.com/index.php?path=customer_services&template=faq&section=customer_services&subsection=faq&page=faq
i've pasted them below. You can make it a toddler bed without a side rail just by removing the movable side of your crib, and you can install the side rail instead of the movable side if you want it to look a little more finished and help keep your child from rolling out of the bed.
FAQ
How to convert a crib into a toddler bed
To convert a crib into a toddler bed you must loosen the two front gold bolts left and right side of the crib and remove the dropside (the front gate that goes up and down). After removing the dropside be very careful that you tighten back your two gold bolts.
How to install the streight rail (toddler rail)
To install a streight (toddler) rail loosen the two front gold bolts left and right side of the crib and remove the dropside, once you have removed the dropside replace with the streight rail. Always be very careful and make sure you tighten back your two gold bolts in the front.
Oct 14, 2007 | Pali Sabrina Crib
Coaster Louis Philippe 200431 Sleigh Bed Logo
567 people viewed this question
Top Coaster Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Coaster Baby Gear Expert? Answer questions, earn points and help others
