Question about Konami Rock Revolution with Drum Kit xbox 360, 2008
Play konami drum kit on a computer
Trying to make a connection to my computer
I want to play pes 2011
All you need is to connect the device following the instructions as you have not specified the details of the device. connect to the TV video/audio inputs, select AV and switch on to play.
Nov 12, 2011 | Konami Video Game Consoles & Games
Playing through Metal gear solid 4 and i get this CD icon with a question mark after 10 minutes of playing and it appears every 2 minutes. I have had the game since launch and have never had this problem...
It sounds like your disk is scratched. The easiest solution is to go to a video rental store and have them re-surface it (most likely for a fee) or you can go to a store and look for a dvd scratch repair kit (cost between $15.99-$30.00) if neither of these work you will most likely need to buy a new disc
Aug 30, 2011 | Konami Metal Gear Solid 4: Guns of the...
Alesis DM6 electronic drum kit module sound problems: The mix in, display and sensors are working on the module but no drum sound is produced through the monitor or through headphones (but an ipod can be...
It appears that you have to select a "Kit" of drums when using the external triggers. It appears that the volume level for the kit and that for each voice MAY all have to be set, especially after new firmware download. Read manual about KIT volume level and selecting voice and volume level for those. Manual is NOT very clear about these things and you have to try them as this is where the probllem is.
May 08, 2011 | Alesis DM6 Electronic Drum Set
I'm trying to use the pads of my Yamaha DTXplorer drum kit as triggers for the sounds stored on my Alesis SR-18 drum machine. I have seen that Alesis markets a trigger module of their own which they...
you need to determine what midi note the DTXplorer is using for the snare, kick and 3rd tom, and set the SR-18 accordingly, or vica-versa. the midi notes for each instrument has to be the same.
if you cannot change the midi note in either unit to make them correspond, you can download a "midi mapper" program (i think e-drum might be one), there is freeware available if you search CNet. with a midi mapper program, you would have to get a midi/usb adapter for your computer and rouite the midi signal through a computer. midi mapping software allows you to change the midi note, when the hardware itself is incapable of doing so.
Mar 09, 2011 | Yamaha DTXtreme III Drum Trigger Module
I have save problem i play and ynlock new cards but when i quite the game everything reset and the new cards disepaire i get bored so please help me solving this problem and ,tnx :))))))
I have save problem i Problem with the Konami Yu-Gi-Oh! Power of Chaos: Joey the Passion for Windows i have save problem i play and ynlock new cards but when i quite the game everything reset and the new cards disepairei get bored so please help me solving this problem and ,tnx :))))))
Jan 17, 2011 | Konami Yu-Gi-Oh! Power of Chaos: Joey the...
Why middle east cant play metal gear online
all online games require an average of 100mbs online connection speed. and the connection you are using there may not be fast enough to connect to the host system. try having the person in the middle east to host a game
Aug 02, 2010 | Konami Metal Gear Solid 4: Guns of the...
My Ion iED05 Drum Kit Says connect module and wont work?
I had the same problem, still doesn't connect. I got Joy to Key application and Battery 3 demo and mapped the pads to the keyboard letters of the laptop and now it works, got the idea from:
http://www.wibwobweb.com/blog/articles-by-me/using-the-ion-ied05-usb-drum-kit-with-midi-capable-software/
Aug 21, 2009 | ION Audio iED01 Electronic Drum Set
Having problems With Crime Life gang Wars?
Was there any previous mistakes with your computer if so you need to buy a computer scanner to see if there any virous trying to breach in so try that out..
May 31, 2009 | Konami Crime Life: Gang Wars for Xbox
I want to connect my YAMAHA DTXPRESS IV SPECIAL to my PC
Any pro-audio interface with a midi input would do the trick. There are numerous products out there that offer this. You can get a simple usb midi interface, and connect the Yamaha up with a midi cable running from the midi out of the drum module to the nidi in of the interface.
one of the simpler ones:...
http://www.amazon.com/M-Audio-Midisport-Uno-MIDI-Interface/dp/B00007JRBM
Jan 24, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
Konami Rock Revolution with Drum Kit xbox 360, 2008 Logo
46 people viewed this question
Top Konami Video Game Consoles & Games Experts
Dan Shibata
Dan Shibata
Are you a Konami Video Game Console and Game Expert? Answer questions, earn points and help others
