Question about Geospring Hybrid 50 Gallon Heat Pump Electric Hot Water Heater - EnerStar
Geospring hybird water heater says wiring wrong at 120 volts
Model GEH50DNSRSA lightly used. Picked this up figuring I may be able to fix, and in hooking it up the panel display says"incorrect voltage of 120, correct wiring to 240" or heat pump error. There are no errors in the diagnostic menu and voltage is good. I did find according to the wring diagram, that from the factory the blue and yellow wires were switched at compressor for heat pump. Figure this may have done damage to board possibly.
mastatech
  • 478 Answers
SOURCE: air conditioner model AEW10AJS1 wiring problem.
That is the temp prob it belongs in the air flow, its only connected on one end
Posted on Mar 29, 2009
  • 358 Answers
SOURCE: GE AGQ10AJ - Compressor not turning on
Most of the cases when tou heard a click on and off is aproblem with the compresor that goes off on overload, when the compresor try to start and is stuck , burned or the starting coil inside it is open it's overheat and goes off by the thermo bimetal switch.Also could be the capacitor, to check it you need a capacitor tester,but if you don't have it you can try to put anew one (no more than 10 $) and see what happend if still the compresor is getting hot and won't turn on it's burned, jamed or open , and you have to replce it ,if it's less than a year old it should be under warranty but if not is an expensive job and you better get a new unit.
Posted on Apr 15, 2009
TheMobilian
  • 8220 Answers
SOURCE: GE Room Heat/Cool unit will not heat with heat pump
If it was me I would cnage the sensor first. Simply because it is way cheaper than the control board and these sensors are fickle as hell to begin with.
Posted on May 14, 2009
  • 19 Answers
SOURCE: I am concerned the wiring diagram provided for a
Those terminals on a ductless split are reserved for the communication wires from the out door to indoor unit. L L N should be line 1, line 2, and neutral (ground) there should be a 1 2 3 N terminal block in the indoor unit also, those terminals would most likely be for the communication between the two units.
Posted on May 18, 2009
flatech
  • 111 Answers
SOURCE: Trying to install new programmable thermostat.
Standard hook up for Heat pump.
Red wire----------R
Green-------------G
Blue----------------C
Yellow-------------Y
Orange------------O
White--------------W1 with a jumper to E sometimes will also say Aux, varies with Manif. of T-stat.
Hope this helps you out.
Posted on Oct 24, 2009
Can I install a 19 gallon hot water tank to a 120 volt breaker?
Anon, It would only work if that was meant to be hooked up that way. Check the specifications in the manual or the plate on the heater itself. Check the attached links,instruction and guides, 1st link shows typical wire hook up on both 120 and 240 v. Good luck .
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Basic 220 Volt water heater circuit
Common Mistakes in Hot Water Heater Installation Hot Water Heaters
How to Install 120 Volt 20 Gallon Electric Water Heater
electric hot water heater specification plate Google Search
May 22, 2016 | Water Water Heaters
I got an error code FC on my Geospring Hybrid Water Heater. Please help
Sounds like you aren't the only one having this problem. The FC indicates a compressor failure. Here are the results one customer got after complaining directly to GE.
My Geospring hybrid water heater recently reported a heat pump failure and generated an error code called "hfc code f-c." Although GE will not tell you what this means, apparently it means failed compressor and mainly involves a failed part called the "evaporator asm." I think what happens is the coils in it leak, releasing the refrigerant inside. The heat pump cannot work without it. When this happens, it switches to "regular" resistant electric heat, which defeats the purpose of paying the extra expense and owning a hybrid water heater like the Geospring. I discovered this problem to be widely reported on the internet. I even found repair companies advertising hfc code f-c repair ... Google even autofilled it after I typed only "ge hybrid w," so clearly many people are having this problem. I've owned mine for about 2.5 years, but I think it lasted this long because our hot water use is relatively low. Others reported this problem in as little as a few months. BTW, evaporator coils last at least 10 years (the life expectancy of a Geospring), so there is no way this part should be failing so frequently and so quickly ... this is clearly GE's fault. I would not recommend buying the Geospring until GE comes clean and can assure the public that it has solved the problem on ALL Geospring models (I own the DNSRSA model) and is no longer using shoddy parts for manufacturing OR repair and extends full warranty coverage for all its customers that have this problem (and the other problems reported, such as power supply and main board).
FOLLOW UP (2/6/13): My Geospring has been repaired. GE agreed to do the repair for no charge for parts and labor. GE is also reimbursing me for extra energy consumed due to the heat pump failure. I asked if the problem had been solved so that the same part would not fail again and I was told that it was because the evaporator has been redesigned. OTOH, when I asked the repairman what the real problem was, he said, "China" (a man of few words). We'll see how it works out, I'll let you know if it doesn't! I did not have problems arranging for the repair, though I'm sorry to hear that others have. Could be because I live in a metropolitan area that might have more readily available resources than others. If you own a Geospring with the dreaded infamous "hfc code f-c," please make sure GE gives you the same consideration I got: free repair with no charge for parts and labor, plus a check for energy reimbursement.
Jan 07, 2014 | Water Heaters
Filter light keeps beeping
GE knows there is a problem with this and will send a serviceman out with parts to fix free of charge even if you are out of warranty as I was. Just call them at 888-443-4394
Jul 07, 2013 | General Electric GE GeoSpring Hybrid Water...
GeoSpring GEH50DNSRSA wire diagram
Here are all the resources that are available for GE heat pump without calling GE and hearing them tell you to call service technician:
http://waterheatertimer.org/GE-heat-pump-manuals-by-date.html
http://waterheatertimer.org/Review-GE-Heat-Pump-water-heater.html
There is no wiring diagram for the bundles of wires coming from chip control board.
As general rule, these things are made to last 10 years, and afterwards will not function or be repairable. It's like a window air conditioner, except connected to water pipes, and connected to computer chip and multiple sensors, each susceptible to failure, and then the machine is used 24 hours a day, 365.
Designs have changed continually from 2009 to 2010 to 2012 models.
It's likely you got a nice piece of junk with depleted anode rod and failed sensors that stopped working and somebody got rid of it because it wasn't repairable.
http://waterheatertimer.org/How-to-recycle-water-heater.html
Add a comment
Jun 02, 2013 | Reliance & 40 Gal Electric Mobile Home...
Install problems ge hybrid water heater
1) Copy following links for detailed resources:
http://waterheatertimer.org/Review-GE-Heat-Pump-water-heater.html#error
2) T2 is tank temperature sensor failure located just above upper element.
Call for service/ warranty.
Call GE 888-433-4394
3) Was water heater completely full of water before applying power.
Do you have 10 gauge wire and 30 amp breaker.
Is unit receiving 208-240 Volt power. Click breaker fully on-off.
Move wire to another same size circuit breaker.
Mar 03, 2013 | General Electric Ge Appliances GEH50DNSRSA...
Keep getting a f9 and f10 code . how do we fix what do they mean
1) F9 and F10 appear to be element failure/ Call for service
http://waterheatertimer.org/Review-GE-Heat-Pump-water-heater.html#element
2) Copy following link for more GE Hybrid Geospring resources:
3) Call GE and they will tell you to call for service:
1-888-443-4394
4) 2009 service manual says you can clear fault codes by pressing Filter, Lock, Vacation button sequentially within 3 seconds. Scroll to clear all fault codes using arrow keys. When that is highlighted, press Filter, Lock, Vacation again.
Others report this does not work, so it may depend on model. Or maybe buttons need to be pressed simultaneously.
5) GE does not want folks working on their own water heater.
Do not buy expensive water heaters you cannot fix yourself.
Average service call for GE heat pump is $400 which helps defeat anticipated savings from buying hybrid.
Jan 26, 2013 | General Electric GE GeoSpring Hybrid Water...
The water heater red light keeps flashing rapidly on my Powervent 2 model 41VRP40N. It is not producing hot water and when I read the manual it says it needs more heat. What does this mean. How do I fix...
There are many things to check. The single most important test is for 24V at the gas valve after the ignitor is supposed tp be on. 19 V or less and there is either a bad ground or the ingition control board has failed. (Wire ground problems are a high probablilty)
Here is what the book says:
PROBLEM #1 - HOT SURFACE IGNITOR DOES NOT GLOW RED
(Remember to wait for purge time, 17/34 seconds, on models so equipped).
Possible causes
A. No main power
B. Faulty transformer
C. Faulty thermostat
D. Faulty limit switch
E. Faulty blower interlock switch
F. Faulty hot surface ignitor
G. Faulty ignition control
Solution
Step #1
Perform normal system checks of main power, transformer, thermostat, limit
switch, blower interlock switch, and replace faulty component.
Step #2
With power on and thermostat set at its highest position, check voltage
between "TH" and "TR" on HS780 ignition control. If 24 volts is not present
check output at transformer. If no, replace transformer. If transformer
checks out OK look at other controls in the 24 volt circuit I.E.: thermostat,
limit switch, blower interlock switch. Check for 120 volts between "neut"
(L2) and "120" (L1). Check for 120 volts at the ignitor across "IGN" and
"IGN" terminals on the HS780 ignition module. If 120 volts is present,
replace ignitor. If no, replace the 780 series module
PROBLEM #2 - IGNITOR GLOWS RED BUT MAIN BURNER
WOULDN'T LIGHT
Possible causes
A. Improper ignitor alignment
B. Faulty ignition control
C. Faulty gas valve
D. High inlet gas pressure
E. Polarity reversed
F. No earth ground
Solution
Step #1
Check for availability of gas at gas valve. Make sure the manual valve
upstream of the gas valve and the gas valve are in the full on position. Also
make sure gas is being supplied to the system at the proper pressure, too
high will lock-up the valve.
Step #2
Check proper polarity of "NEUT" and "120" on the ignition control by reversing
the wires, if reversed gas valve will not open. If this does not solve the
problem, replace wires as they were.
Step #3
Check for proper ignitor position.
Step #4
Check for a good earth ground by using a meter connected between L1
and furnace chassis. Should read 120 volts, if no, check and/or repair ignition
ground wire or ignition control mounting screws.
CAUTION POLARITY MUST BE OBSERVED
Step #5
Check for 24 volts at the gas valve terminals; "1" and "2" on a 7200 series,
"M" and "C" on a 7100 series, "TH" and "TR" on a 7000 series. If yes,
check wire integrity or change the gas valve. If no, change the 780 series
ignition module.
That is pretty much all of the troubleshooting required.
Thanks for choosing FixYa,
Kelly
Feb 14, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
Geospring Hybrid 50 Gallon Heat Pump Electric Hot Water Heater - EnerStar Logo
118 people viewed this question
Top GE Water Heaters Experts
Steven's...
Steven's...
RSole
Gene Haynes
Are you a GE Water Heater Expert? Answer questions, earn points and help others
