Question about Kenwood Excelon X500-1
Kenwood Excelon X500-1 cuts out light flashes
Amp cuts out light flashes
MrLard
  • 94 Answers
SOURCE: kenwood excelon kacx401m
Sounds like an overload, amp switches on, can't get enough juice and switches off. Get a friend with a volt meter to measure the voltage at the amp power terminal as you turn it on, if it drops below 10.5v the amp hasn't got enough juice. Some amps can cut out before the fuse blows, so you never know it's an overload. I'm not sure what you mean by a 'power slide door'
Posted on Apr 24, 2007
zzedly
  • 300 Answers
SOURCE: Kenwood Excelon KAC-X521
According to page 7 of the radio's manual, E-02 means the amp has failed and DC is being applied to the speakers. It also says "Turn the POWER switch "OFF" and release the protection."
Posted on Mar 05, 2008
rteemon
  • 578 Answers
SOURCE: Kenwood Excelon KAC-x521
low voltage check power source
Posted on Jun 26, 2009
  • 11 Answers
SOURCE: blinking E-03
somthing is fried on your motherboard
Posted on Jul 30, 2009
  • 85 Answers
SOURCE: My kenwood excelon x1200m amp
You may have blown a fuse. There should be one on the amp itself and the other is generally installed on the main 12V power cable. Most installers put it in the engine compartment for easy access. Pull each fuse and make sure it's still intact. If not you'll need to replace it. Most auto parts stores will carry the fuse, just take the old one in to make sure you get the correct amperage.
Posted on May 02, 2011
My subwoofer doesn't receive power, all amp fuses are fine, amp powers on, remote wire and rca wires are connected and intact. Before it stopped working all together the woofer would cut out and after...
If you are getting power to the amp, try this....Find a small speaker, unhook your sub and wire speaker to amp. Turn on your system at a low volume....If the other speaker is playing through amp, then your sub is shot.....If the small speaker doesnt work, then its either your channel is gone on the amp or the rcas have quit off off your head unit.
Oct 07, 2010 | Kenwood eXcelon X1200M Car Amp
I have a kenwood eXcelon KDC-X759 and after i hooked it up it just kept flashing code off, and it will take a cd but no sound and the radio works fine
does the cd seem to be working other than no sound? if so, are you running the audio through an amplifier? if you are using an amplifier, you may be using the antenna remote wire (blue) instead of the amp remote wire (blue/white stripe) to turn the amp on. when using the antenna remote wire it turns off when going to cd mode.
Aug 13, 2010 | Kenwood eXcelon KDC-X759 CD Player
Kenwood Excelon KAC-X811D blinking e-03
Hello mogly20,
The amp probably won't know if it's you or the homeless guy, so try smashing a glass bottle on it like he did. If that doesn't work, I'd recommend you locate another homeless guy and buy another amp.
Hope this helps.
Aug 08, 2009 | Kenwood Excelon KAC-X521 Car Audio...
Blinking E-03
Apr 28, 2009 | Kenwood Excelon KAC-X811D Car Audio...
No sound flashing e-02 in window
Turn power off this will release the protection turn power back on if code is still flashing contact kenwood dealer
Jan 04, 2009 | Kenwood Excelon KAC-X621 Car Audio...
It comes on but
I believe that the amplifier is in protection mode; more than likely you either have an internal short in the amp or a bad speaker running off of the amp.
Jun 06, 2008 | Kenwood eXcelon KAC-X812D Car Audio...
Kenwood Excelon X500-1 Logo
323 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
