Question about Mathsoft Solving and Optimization Extension Pack III (46513) for PC
Make a tally chart for the number of students in third fourth and fifth grade classes 26 25 27 27 26 28 27
What are the tune r numbers
For 6 STRING GUITARS, tune strings in
ASCENDING ORDER: Target Hz
For 6 string guitars. Tune in ascending order
First LOW E . . . . . . . . . . . . . . . . . 82.4
Second A . . . . . . . . . . . . . . . . . 110.0
Third D. . . . . . . . . . . . . . . . . . . 146.8
Fourth G. . . . . . . . . . . . . . . . . . 196.0
Fifth B . . . . . . . . . . . . . . . . . . . 246.9
Sixth HIGH E. . . . . . . . . . . . . . . 329.6
For 4-5 string BASS GUITARS, tune strings in
DESCENDING ORDER: Target Hz
For 4 and 5 string Bass Guitars
First G . . . . . . . . . . . . . . . . . . . . . 98.0
Second D. . . . . . . . . . . . . . . . . . . 73.4
Third A. . . . . . . . . . . . . . . . . . . . . 55.0
Fourth E. . . . . . . . . . . . . . . . . . . . 41.2
Fifth B (if 5 string) . . . . . . . . . . . 30.95
The manuals are here.
http://www.snarktuners.com/contact-service
Jan 16, 2016 | Snark Clip-On Guitar & Bass Tuner
Bike will not turn over, security icon flashes alone with the turn signals. Battery test OK.
Have you used the new PIN to manually disable the security system?
Do not turn handlebars, straddle seat or lift motorcycle off the jiffy stand. During a PIN disarm, if the security system detects motorcycle motion the system will activate.
Turn ignition to IGN.
If armed, the odometer window display will read: ENTER PIN and the security lamp will be flashing at a fast rate. The headlight will not be on.
Press and release the left turn signal switch.
In the odometer window, a flashing 1 will appear.
Increment the digit by tapping the left turn signal until the odometer window displays the first digit of the PIN.
The first digit in the odometer will be the first digit in the PIN.
Press right turn switch 1 time.
The first digit is stored and the next digit will flash.
Increment the second digit using the left turn switch until the digit reaches the second digit of the PIN.
The second digit in the odometer will be the second digit in the PIN.
The second digit is stored and the next dash will flash.
Increment the third digit using the left turn switch until it reaches the third digit of the PIN.
The third digit in the odometer will be the third digit in the PIN.
The third digit is stored and the next dash will flash.
Increment the fourth digit using the left turn switch until it reaches the fourth digit of the PIN.
The fourth digit in the odometer will be the fourth digit in the PIN.
The fourth digit is stored and the next dash will flash.
Increment the fifth digit using the left turn switch until it reaches the fifth digit of the PIN.
The fifth digit in the odometer will be the fifth digit in the PIN.
The fifth digit is stored. The security system indicator lamp stops blinking.
Smart Security System is disarmed.
If a mistake is made while entering PIN, turn the ignition Switch to OFF before entering the last digit and then start the procedure from the beginning.
If the procedure fails to disarm the security system, wait two minutes before attempting another PIN disarm.
The security system will remain disarmed until the ignition is turned to OFF.
Apr 04, 2014 | 2005 Harley Davidson FLHTCUI Electra Glide...
Will not read disks. Cycled power usally worked not this time.
First Turn your X-box on
Second Take out your game or CD
Third Open tray
Fourth Close tray
Fifth Repeat Third and Fourth a couple times and let it load then open
Sixth Stop when you hear the xbox make a spinning noise like when it is reading a game
Seventh Open tray
Eighth Pit a game in
Ninth Close tray
Tenth Play you game!
Dec 30, 2010 | Microsoft Xbox 360 Console
Trans whining noise in first, second, third, then disappears shifting into fourth and fifth. any common problems i can look for?
first, second & third all use a lower shaft in the trannsmission called a counter shaft, forth and fifth do not, sounds like you have a bearing going out on the lower shaft. unfourtanly you have to complety dissemble the trannsmission to replace the bearing.....SORRY
Nov 27, 2010 | 1992 Geo Tracker
How to get the silver moon.what is the code for piano
second white key is first... sixth white key is second. fifth black key is third. fifth white key is fourth. first black key is fifth.. thats it. gl
Oct 13, 2010 | Konami Silent Hill for PlayStation 1
How to make tally charts on my laptop?
To create a tally chart in a laptop,the laptop must a spreadsheet package like Microsoft excel
these are the steps involve
-select the data to be use for graph.include the column and row label in sections
-select data
-click on number tab
-click on text
-click ok
-click on chart wizard icon on the tool bar
or
click on insert on menu bar
click on standard tab or custom types tab
under chart type list ,click to select the desire chart type eg tally.
under chart sub -type list,click to select the chart desire.
click on next button.
click on data range tab under series to select rows or columns.
that solve it.I hope you"ll find the solution post useful,dont forget to leave your comment by saying hope hopeful this post is to you
Oct 07, 2010 | Computers & Internet
Computers & Internet Logo
263 people viewed this question
Top Mathsoft Computers & Internet Experts
k24674
Michael Cummings
Level 1 Expert
Bapco
Are you a Mathsoft Computer and Internet Expert? Answer questions, earn points and help others
