Question about Philips DVD580MT DVD Player
Philips 580MT region free hack is acting up,
7 years ago I bought a Philips 580MT and used the hack code to make it region free. Worked fine for 7 years until last night I got an error message and I could hear the sound from region 2 disk but got a scrolling picture in Black White. Any help and or advice? Regular DVDs or NTSC work perfectly. I've tested it out on two different monitors using RGB and Yellow video cable. Same scrolling problem with region 2 but not NTSC
rizla
  • 1463 Answers
SOURCE: Region Code Error for Philips DVP3256
hi
you can try this
>Go to Setup.
>Select Preference Page.
>Press 1, 3, 8, 9, 3, 1 on the Philips DVP3986 DVD Player remote.
>Press the up/down key to select "0" which makes it region free.
>Press ok and exit setup.
riz.
Posted on Feb 24, 2009
SOURCE: Free code for Philips DVP 5980K
1. Press Setup in the remote control
2. Go to Preferences and press OK in the remote control
3. Press the next sequence of numbers "1-3-8-9-3-1" in the remote control
4. Use up and down arrows to change the region
PS: if the sequence doesn't works, do it a little more quickly
Posted on Feb 28, 2009
YourZEN
  • 820 Answers
SOURCE: No audio. Video O.K. PHILIPS DVP642/37
User manual for DVP642/37:
http://www.p4c.philips.com/files/d/dvp642_37/dvp642_37_dfu_eng.pdf
Connections on page 13.
Audio setup from page 28. Page 28:
For simple stereo setup use [Downmix] > [stereo]:
[LT/RT] requires a Dolby Pro logic decoder.
Posted on Sep 06, 2009
  • 10 Answers
SOURCE: No Picture on HDMI using Philips DVP5992.
You can try out by connecting the CVBS (Yello) out from player to TV and connect HDMI out from Player to TV. Goto CVBS input on Sony TV. Select set up and you should get the HDMI Video options availble. Try to change the resulution and check for Video on HDMI source.
Which disc you were playing PAL or NTSC? PAL should work for Europe.
Posted on May 11, 2010
SOURCE: PHILIPS dual screen DVD player
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=PET9422/37&dct=FAQ&faqview=1&new_tmpl=1&refdisplay=HAV_GENERAL_REGION_CODE&refnr=0052950&scy=US&slg=AEN
Above is a link that explains it all, from what it appears you cannot change the codes, and as of now, i haven't been able to find any hacks either.
Posted on Feb 19, 2011
Tip
Samsung BD-1600 region free code
I used it on my brand new Samsung BD-1600 today and it
worked on the first try using the code below.
My unit is a Region 2 (UK) machine.
1) Press the POWER button on the remote to turn on the
machine (no disc in the tray).
2) Wait till the player has booted up and the Samsung logo
screen is displayed.
3) Press the OPEN/CLOSE button on the remote twice, to open
then close the disc tray.
4) As soon as you see "No-Disc" displayed in the top left
corner, press the REPEAT button followed by the 5 digit code
for your current region as listed below.
(Mine was 57538 for region 2)
Don't press the REPEAT button for too long, just smoothly
press REPEAT 5 7 5 3 8.
If it doesn't work straight away, keep trying, mine worked
on the first go.
5) If you're successful, your current region code will be
displayed in the top left corner of the screen.
6) Press '9' to make your player region free.
7) Turn the player off, then on again and test with a
different region disc, or if you don't have one to test
with, just repeat the hack and instead of your old region
code appearing in the top left corner of your screen, you
should see '9' if you've been successful.
The hack can be repeated to turn your machine back to it's
original settings or to a particular region if the disc is
sensative to region free machines.
Region Codes
R1 - 29334
R2 - 57538
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
on Mar 07, 2010 | Televison & Video
In my Philips DVD players, recently I have tried to play few film DVDs, and it showed region error/or wrong region. Could you please help me out with this and tell me what should I do?? I talked to the...
The DVD you're using is probably from elsewhere than the region you live in. It is almost certainly possible to temporarily change the region by using a trick which will not damage your machine in any way. Google "Philips DVP642 region hack" and there will be an answer.
Dec 18, 2010 | Philips DVP642 DVD Player
Region hack code for samsung dvd-p241
You can try to use this tip, which is generally used for all these Samsung models: DVD-709,DVD-809,DVD-909,DVD-511,DVD-611,DVD-615,DVD-811,DVD-M105,DVD-M105 E,DVD-M108,DVD-M203,DVD-M204,DVD-M205,DVD-M305,DVD-M405,DVD-P233,DVD-V530. I think that P-241 is about the same of P-233, which is unlocked with this tip. You can try, and then answer me if worked.
1. Make sure that there is no disc in the tray and switch on the player.
2. Cold start the player, by holding down the PLAY and STOP buttons on the player.
3. You should see a set of language options. Release the PLAY and STOP buttons.
4. Select your language.
5. Press REPEAT then the following codes for the required region the player is already set to (region you bought the player in) do not confuse this with the A-B button:
Region 1 - 2, 9, 3, 3, 4
Region 2 - 3, 8, 7, 6, 7
("E series M105", M205 and M305 users try: 57538)
Region 3 - 5, 6, 7, 3, 2
Region 4 - 7, 6, 8, 8, 4
Region 5 - 5, 3, 8, 1, 4
Region 6 - 2, 4, 4, 6, 2
6. A code will appear, indicating the region setting of your player.
7. Press 9 for region-free, or 1 for region 1, 2 for region 2, etc.
8. Press OPEN/CLOSE on the Player to open the disc tray. You may need to push the tray shut rather than use the player button, in order for the region not to be changed to 4 (M203).
9. Press STANDBY (POWER) on the remote control to close the tray. Next time the player is turned on it will set to the region specified. If the player halts on the FBI Warnings, press Forward Search x2 or faster.
On some models, you will have the ability to disable Macrovision, but you will have to turn off the Quasi-PAL option and set the SCART output type to Video rather than RGB.
Jul 09, 2009 | Philips Magnavox MWD7006 DVD Player
How to unlock code to make my LG BD-390 region free. I am trying to play a dvd I bought in Italy 3 years ago.
Ha.... Found the soultion.
The fix is the same as fr LG 5931.
I.e. download a small file and burnit with e.g. ultraiso on a DVD-R.
Boot yr LG BD370 or 390 with the DVD in the reader - it will flicker some numbers on the Display and then say Region 0.
You get the file here:
http://www.multi-region.net/lg
Worked like a charm :)
Jun 10, 2009 | Sharp DVRW250 DVD Players
Unlock region code for Philips DVP 3256
Region code hack for PHILIPS 3256 x/94
1. Go to Setup. [from remote]
2. Select the Preference Page.
3. Press 1, 3, 8, 9, 3, 1 on the Philips DVD Player remote.
--> It will show current region code [ for example 5 ]
4. Now Press the up/down key to select "0" which makes it region free.
5. Press ok and exit setup.
Probably the same would be applicable for 3258, 3268, 3986.
Good Luck!
Jan 02, 2009 | Philips DVD625 DVD Player
Region free code
See http://www.multi-region.net/philips_dvp3340v , I just used this and it worked beautifully.
Sep 26, 2008 | Philips DVP3340V
How to make philips HTS3565 region free. Any help will be appreciated. Thanks.!
icon_minipost.gifRegion code hack posted by videohelp4k1ng, July 27 2008:
Hack for HTS3050 also worked with my HTS3565D.
Open the tray. Press 99990 on the remote.
Region 0 will appear briefly on the left of the screen.
icon_minipost.gifRegion code hack posted by rocky631689, August 01 2008:
Also works on my Philips HTS3568DW/75
THANK YOU!!!!!!!
icon_minipost.gifRegion code hack posted by mikoyan, August 05 2008:
I´ve just applied to my HTS3565D/37 and it worked great. Do not expect it to show anything in the display, though. You open the tray, click the sequence in the remote and... Done!
Sep 03, 2008 | Philips HTS3500S System
Philips DVP3960 uncolck code
region-free hack?
I used the following and it worked fine for me on a recent purchase of a Philips DVP3960
Power Up the unit with NO Disc in the tray.
Open the tray
Press the SETUP Button on the remote control
Navigate to the PREFERENCES page using the Right Arrow Key
Press the DOWN ARROW one time to select
Press the 1 button on your remote control
Press the 3 button on your remote control
Press the 8 button on your remote control
Press the 9 button on your remote control
The current Region Code Setting will display
Use the UP/DOWN Arrow Keys to select the region required or '0' for All Regions
Press the PLAY Button on the remote control
Good luck
Feb 15, 2008 | Philips DVP3960
Region Free Code: Philips DVP 5980
this worked perfectly, thank you!
Dec 19, 2007 | Televison & Video
Philips DVD580MT DVD Player Logo
48 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
