Question about Whirlpool WFW9150W Front Load Washer
Getting strike loose from latch on Whirlpool front load washer
The strike broke and also had to replace the latch. Inserted the strike into the latch to be sure it was right one and now they won't come apart so cannot install.
  • Whirlpool Master
  • 17,130 Answers
Click on : Door lock
Posted on Jan 24, 2013
jsrock516
  • 5911 Answers
SOURCE: Getting a small plastic piece out of a door
If the piece is jammed (locked) in the door latch assembly, there is a manual release that you can use to open the door latch to see if the piece will come from free. The following link advises:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
This may require two people. One to pull on the manual release, while the other works on retrieving the broken piece from the door latch.
Another method may be to remove the door latch assembly so you can easily manipulate it outside the machine. This link explains how to remove the door latch assembly:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
Now...if the piece is jammed too far inside the door latch assembly, a last resort would be to replace the latch. I hope it does not come to that, but it may be a last resort. The link provided will give you all the necessary steps to complete this repair, if required.
I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Nov 08, 2008
rickzilla
  • 706 Answers
SOURCE: Whirlpool Duet front loading washer - handle broke off
Hello elgatogordo,
You should be able to identify the part you need as well as order it from this website.. here is the link.. http://www.pcappliancerepair.com/model-display.php
Hope this helps..
Regards,
Rick
Posted on Dec 04, 2008
  • 63 Answers
SOURCE: Whirlpool ht duet still getting F dl error
main ccu board bad
Posted on Jan 20, 2009
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool front loading washer and dryer F28 keeps coming up
F28 is a serial bus error from the CCU (Central Control Unit) to the MCU (Motor Control Unit).
All you need is some Electronics contact cleaner spray and a 1/4 inch socket to remove the top of the machine and the back of the machine.
The CCU is the computer looking box at the top front right hand corner.
Find connector M13, (has red marking on it and only 3 wires) disconnect it by pushing the retainer tab back and pulling gently on the connector.
Spray the contacts of the connector and computer with connector cleaner.
Then re-assemble connector.
The MCU is in the back lower left corner.
Find the connector with 3 wires and red mark, and remove this connector in the same way you did the other, spray it and re-install.
Put the back and top back on.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Posted on Sep 28, 2010
  • 403 Answers
SOURCE: Having problem with the door lock/latch assembly
replace the door lock assembly
Posted on Feb 05, 2011
How can i take the front off the washer to replace the door latch ?
You shouldn't have to take the front door or panel off to fix the door latch. You should have part on the door and part on the inside panel of the machine.
Jul 27, 2012 | Frigidaire Affinity ATF7000E Front Load...
WFW9200SQ00 Whirlpool washing machine. Door strike doesn't go in the latch, seems a mechanical issue. There is a little white pin inside the latch on the way. Any ideas what can be wrong?
Does the door strike seem to be broken and is that what you see inside of the latch asm.? if no the strike is ok i suspect the latch itself has broken apart and your seeing a internal part of it through the opening where the strike fits into, in which case the latch/lock assambly would need to be replaced.
The part numbers are
DOOR LATCH ASM. 8183270
DOOR STRIKE W10217552
GENE
Oct 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool GHW9400PL0 front loading washer. The door won't stay closed, and I think it's because the plastic latch on the base of the machine broke. The latch portion (white plastic) looks...
you have to inspect that switch carefully,, its actually got 2 , a secondary switch latches just before the spin cycle, I'll try and locate the part for you
Jul 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have an ATF8000FS1 front loading washer. The door is hard to close and subsequently broke the door strike. If I lift up on the door it aligns the strike better with the latch. There appears to be no...
There is next to no adjustments so if the door dropped then the hinge must be bent . You may be able to very gently pull up on the door and re-align it but most likely you will have to replace the hinge.
Feb 26, 2011 | Frigidaire Affinity ATF7000E Front Load...
The door wont lock, My 11month child can open anytime. even when it's full of water Please help Many thanks Matt
No nod # but all front load washers lock or should/// ether your door strike is broke or the door switch latch is not locking..sometimes the door strike can work but be wore so the latch won't grab it sence the door strike is cheaper I would try that first......If I helped you please vote if you need more help please ask..and good luck
Feb 05, 2011 | Washing Machines
The door latch broke, I got the replacement part but am not quite sure how to install it.
The following link explains step-by-step how to replace the door latch on a Whirlpool Duet front loading washer:
If you have any questions about this repair, or need additional assistance, please let me know. I hope you find this information helpful.
Aug 29, 2009 | Whirlpool GHW9400 Duet Washer
The locking mechanism latch broke and we replaced it
helps to lift the door a lil when shutting it hinges may be worn and latch is easy to get to just take the clamp loose around the boot and 2 screws hold it
Jul 07, 2009 | Frigidaire ATF6000ES Front Load Washer
Whirlpool WFW9150W Front Load Washer Logo
89 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
