Question about Vehicle Parts & Accessories
Problem on ford super duty seat drivers side. It will go back and forward. It will tilt forward, but will not go down on the back side
    Genius:
  • Vehicle Part... Master
  • 1,669 Answers
Check any linkages under the seat for dirt or blockage. Then, see if something under there is disconnected from the control switch. Finally, if there is a separate motor involved, see if it turns.
Posted on Jan 23, 2013
Driver's side power seat won't move back but will move forward, up and down
If this is a 1994+ Ford, it might be that the seat belt latch is the problem. Most Ford products are designed so the seat belt latch by the center console moves with the seat. The bottom of the latch rides on the seat rail, and with time sometimes it builds up a little play on the rail. As the seat moves forward or back, the seat belt guide often tilts forward or back, just a bit, on the rail, and gets stuck. So you can move forward or back just a bit, but then it jams and you can hear the motor, but can go no further.
The long term fix is to remove the seat, disassemble the seat belt guide and rail, and usually replace some parts.
But the short term solution is often to simply hold on to the seat belt latch and rock it forward and away from the seat as you try to go forward or back. Or, sometimes it works best to rock it backwards and away from the seat as you try to move forward or back. It all depends on which way it is binding.
There's no guarantee that it won't jam again if you move it all the way back or forward, but once you find the right position to hold the seat latch in while moving the seat, you should be able to re-adjust it where you need it to be.
Sep 09, 2013 | Computers & Internet
Trans will drive reverse but wont go forward
Solve Your 2001 Ford Super Duty F 450 Problem Now!
Jul 20, 2010 | 2001 Ford Super Duty F 450
Where is the turn signal flasher relay located on a 2001 f150
2001 Ford Truck F250 Super Duty P/U 4WD 5.4L EFI 8cyl the Flasher is located front seating area, driver side, behind left hand side of instrument panel, on fuse panel. Check the FUSE PANEL...
Also can check this and other details in your 2001 Ford F-250 - Owners Manual. (page 172 and next).
Good luck (remember rated this help).
May 13, 2010 | 2001 Ford F250 Super Duty Super Cab
Can't find flasher location
2001 Ford Truck F450 Super Duty P/U 4WD 6.8L EFI 10cyl the Flasher is located front seating area, driver side, under dash, mounted in fuse panel.
Also can check your 2001-Ford-F-450-Owners-Manual (page 170 and next for Fuse Description).
TY for using Fixya; hope this help (remember comment and rated this).
Apr 14, 2010 | 2001 Ford Super Duty F 450
Where is the fuel filter located on a 08 ford f-150 super crew FX2?
Under your truck on the inner side of the frame rail on drivers side. All 5.4L, 4.6L, 4.2L all the same.
Dec 31, 2009 | 2008 Ford F 250 Super Duty 4WD
1996 Ford Explorer - Eddie Bauer 4WD - Replace Power Seat Switch
the switch pops in or out just pull on it unless you see screws it should just pop right out theres no need to worry about the srs.
Nov 14, 2009 | Ford Explorer Cars & Trucks
Drivers side heated seat not working what can I
check the fuse on the panel, the fuse panel are located in the driver side right by the panel,and check the wires under the seat.
Sep 15, 2009 | 2006 Ford F 350 Super Duty
I just purchased a 2007 jeep liberty sport
I have a 2005 Jeep Liberty and the smae lever that tilts the seat also moves it forward and back. Press forward or back on the switch. Also check for blown fuse or a loose wiring connector under the drivers seat. Good luck, Techjoel
Jun 07, 2009 | 2007 Jeep Liberty Sport
Driver side car seat
The seat may be too far forward, and when it is at the forward limits, the seat sticks. I get in the seat, and I press the back button whilst pushing hard with my feet against the floor.
Aug 14, 2008 | 1996 Toyota Avalon
Front seat upright broken
remove the seat from the truck. just 4 bolts that mount it . a just a couple of screws holding the plastic panels. remove the plastic covers on the tilt lever ( weld or replace parts) no magic here.
Aug 03, 2008 | 2000 Ford F350 Super Duty Super Cab
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
