Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Water leaks inside freezer and form ice on the bottom floor
  • Majibur Rahman
    Majibur Rahman Jan 23, 2013
    Ice forms on the bottom floor even when water supply for ice maker is shut- mujib_57 .
    Scholar:
  • 142 Answers
I would recommend that you examine the drain hole and physically remove all visible debris. Pour a mixture made from a teaspoon of baking soda dissolved a 1/2 cup of warm water into the hole. Baking soda is great because it helps to break down the cell walls of plant matter (like any algae living in the drain) and removes smells, too.
Then use a long piece of pipe cleaner to push any remaining debris down into the evaporation tray underneath the refrigerator.
Posted on Jan 02, 2015
Drain valve plugged
Posted on Jan 23, 2013
SOURCE: Whirlpool refrigerator Model # ETIRHMXKT
can be worn gaskets...clogged pipes or coolant leakage.
tell me about
Posted on Jun 22, 2008
  • 4 Answers
SOURCE: Ice dispenser little flap not closing after dispensing ice, build up of ice on inside
you have apossibale air leak mixing with cold air from refer
Posted on Oct 17, 2008
gaeb7
  • 25 Answers
SOURCE: hotpoint csx22bc 21.7 cu. ft. leaking water on freezer side
Look for obstruction at the drain tray for the freezer. Common to have plastic wrap sucked into that area.Or gunk in the drain line. Blow through line to insure the gunk is not an issue.
Posted on Mar 01, 2009
woodchuck789
  • 4066 Answers
SOURCE: water leaking from icemaker on outside
If this is your water dispenser leaking
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Posted on Jul 08, 2009
  • 10865 Answers
SOURCE: 25 ft side by side fridge which does not dispense ice
use a hair blow dryer to warm up the chute and dry up any moisture then lube the chute with a cooking spray, pam is a good one.
Posted on Aug 16, 2009
Why does ice keep forming in the bottom of the freezer and how do we fix the problem?
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 15, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator and freezer not cold also inside of freezer wall ice is formed. What could be the problem ? Please help.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Oct 04, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Whirlpool refrigerator with the ice maker inside the freezer. It does make ice, but a lot of the ice bubes are either hollow or partly formed. I took the filter off completely and it not help. Any...
Good day,
Sounds like your not getting enough water on the fill cycle.
Unlike a washing machine, you have 7 seconds for a fill cycle to complete. Period.
It's either the water valve on the bottom rear of the machine not opening completely and must be replaced since it's a non-repairable item, or the house water supply system is corroding and slowing the water down.
Sep 13, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool refridgerator is leaking water on the freezer side (side by side refridgerator) onto the floor. The ice machine was overflowing with ice and has frozen ice in the ice maker that won't budge. We...
WAS IT LEAKING FROM INSIDE THE FREEZER OR FROM BOTTOM OF FRIDGE? ONCE IN A WHILE YOU NEED TO TAKE OUT THE ICE BIN AND DUMP ICE OUT AND CLEAN IT. HOW CAN THE ICE MACHINE OVERFLOW WITH ICE WHEN THE ICE IN THE TRAY WON'T BUDGE? NEED CLARIFICATION. SOUNDS LIKE YOU EITHER HAVE A BAD ICE MAKER MODULE OR THE SOLENOID FOR THE ICE ON THE WATER VALVE IS BAD.
Jan 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water leaking from refrig.onto floor
check if it isnt comming from your freezer side back wall...
open the back wall of your freezer and make sure the drain hole in the bottom is free all the way to the pan next to the compressor on the back.
911servicetoday .com
Jan 01, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My side by side fridge freezer is flashing CF alarm code. What does this mean
Change filter most likely this is the filter for the water.Meaning dirty water and foul tasting ice.Some filters are located in the front easy to reach areas at the bottom near the floor usually left side under freezer.
Nov 04, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Refrigerator(side by side) leaking water
First question would be is your ice machine leaking? If so then disable the ice machine until we can find the cause of leaks and repair them. Is the freezer freezing well? Food compartment temps OK?. Let me know and I will work to help you resolve this. Sea Breeze sea breezehvac@yahoo.com
visit my site below
http://servicepartstec.blogspot.com/
Mar 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The water and icecube dispenser constantly leaks water on floor
Needs new solinoid valve. Usually located on the back bottom of refrigerator
Jan 07, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
134 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
