Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
My top-loading washer broke down before the spin cycle, so it's filled with water and won't drain.  Is there a default drain button?  The sensor tab on the lid, which usually fixes the problem, isn't working.  I think the machine might be dead.  I'm just looking for a way to get rid of the water.
    Scholar:
  • 42 Answers
You can remove your drain hose from the back and direct the water out appropriately. The problem would typically be the lid safety-switch you have described above.
-C
Fremont, CA
Posted on Jan 30, 2009
The washer fills agitate but won't spin & drain
Possible fault with the program controller unit. You need to check the program cycle outputs using a multimeter connected to measure the output voltage. On start the inlet should open and then close as the water level sensors works and then proceed to wash. So this much seems OK. Now in the next step the drain valve must open to drain off, then fill once again with the inlet working and water level being sensed. If there is no output in this section cycle then the prrogram controller has errors within the memory . You can remove the panel and reset all connectors and connections.
Oct 30, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
22432 won't spin or drain
CHECK THE LID SWITCH THE PART THAT PUSHES THE SWITCH DOWN MAY BE WORN ENOUGH TO CAUSE THIS PROBLEM. WITH THE LID OPEN START THE WASHER IN THE SPIN CYCLE AND PUSH THE SWITCH WITH A POPSICKEL STICK AND SEE IF THIS PROBLEM STILL HAPPENS
Aug 30, 2009 | Kenmore 22422 Top Load Washer
Washer won;t drain or start spinning
check the lid switch if its ok
you have a problem with the timer
replace it
Jul 05, 2009 | Kenmore 24032\24036 Top Load Washer
Washer will fill with water but the agitator won't spin.
No agitation or spin in any cycle? If so and the machine will drain check the coupler.
Oct 08, 2008 | Kenmore 24032\24036 Top Load Washer
Water fill control
it overflows from the tub then:
This can either be a fault in the fill sense tube( small tube connected to the bottom on the outer tub from the sensor at or near the top of the washer housing ) becoming blocked or broken or a fault with the sensor itself. There is a mechanical adjustment for the level but it is a little fiddly to get the adjustment just right.
If it overfills from the drain hose:
then either the drain hose is too low and the water siphons out before it reaches the maximum or there is a tight seal at the drain hose to house drain port which will cause all the water to siphon out, this can also be caused by a drain hose being pushed too far down the house drain port.
Jul 28, 2008 | GE WDSR2080D Top Load Washer
Kenmore 80 series washer stopped during unbalanced spin cycle
lid switch is broke lever probley broke off or screw holes broke out due to off balance load forcing tub over against switch lever
Apr 29, 2008 | Kenmore 20172 Top Load Washer
Agitator Not Working
check your motor coupler, lid switch
Nov 08, 2006 | Hotpoint VBXR1090D Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
46 people viewed this question
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
