Question about GE Slide Projector Lamp Cmv/cmt 115-125 Volts 300 Watts
I need a projector lamp CMV 115-125 V 300 W or a replacement lamp.
Where can I buy a GE slide projector lamp CMV 115-125 V 300 W ?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 23 Answers
Never used them personnally but try
http://www.bulb-source.com
Posted on Jan 30, 2013
Can I buy a new Bell & Howell Slide Cube Projector?
No! They are no longer made due to the computer generation and slide presentations are usually made with laptops now. You should be able to find one good used one on eBay if interested find your model # of projector and look it up on ebay. They are usually in good condition but make sure lamp works on the one you are buying as these are expensive to replace. Rich
Dec 20, 2014 | Bell & Howell Vintage Slide Cube Projector...
Seeking replacement lamp
Try Bulbman.com or Bulbs.com or the retail chain called "Batteries PLUS Bulbs".
If they don't stock them, they should be able to point you toward someone who does. Good Luck !! Jim
Jun 06, 2014 | Braun Office Equipment & Supplies
A slide got stuck in the projector, and when I took it out the projector just died. No power. Any ideas about what's happened? Thanks
If this is a Kodak Slide Projector, there are 2 thermal fuses (1 is in the motor and NOT replaceable and 1 is in the area of the lamp). Almost ALL Kodak projectors had 2 thermal fuses as described. You need to determine the model, as that will determine which fuse or motor assembly you will have to buy & install to fix your projector. If its a Kodak, let me know the model and I can help you further! You can buy parts for Kodak projectors at: www.micro-tools.com.
Good Luck! Jim
Feb 04, 2013 | Office Equipment & Supplies
Need a replacement dek lamp with a asa code
DEK Lamps for Kodak Slide Projectors are almost always in stock at "Batteries PLUS Bulbs" retail outlets. If you don't have one of these stores in your area, try: www.bulbman.com
Jan 28, 2013 | Kodak Carousel 600 Slide Projector
How do I change my projector lamp?
Instructions
  1. Front Projector
    • 1 Disconnect the power cable from your projector. Allow it to cool for 30 to 60 minutes. Lay the projector upside down on a table.
    • 2 Remove the lamp cover, typically located on one of the rear corners of the projector's underside. Depending on your projector, you will either have to loosen a few Phillips screws or press on one or two plastic release tabs to remove the lamp cover.
    • 3 Loosen the screws holding the lamp assembly in place. Grab the assembly by the handle and slide it out of the projector.
    • 4 Slide a new lamp assembly into the projector. Don't touch the glass on the bulb because it will damage the bulb. Tighten the retaining screws on the lamp assembly and replace the lamp cover.
    • 5 Turn the projector right side up and reconnect the power cable. Power on your projector.
    Rear Projector
    • 6 Unplug the TV from the outlet. Let it cool for 30 to 60 minutes.
    • 7 Remove the lamp cover. On most rear projection TVs, the lamp cover is located on the right or left side of the TV's rear panel. Remove the cover by loosening the screws and pulling the cover away from the TV. Certain manufacturers, like Mitsubishi, have the lamp cover in the front of the TV, near the left speaker. To get to the cover, you must first use your fingers to pry off the front panel below the screen, revealing the speakers and lamp cover. Loosen the screws on the cover and pull it away from the TV.
    • 8 Remove the lamp assembly. Loosen its screws, grab the handle and slide it out of the TV. If you have a newer Sony model, there are no screws. Instead, press the release tab to unlock the lamp assembly and slide it out of the TV.
    • 9 Slide a new lamp assembly into the TV. Don't touch the glass on the assembly, as the oils in your fingers will damage the bulb. Tighten the screws or pop the retaining tab into place.
    • 10
      Replace the lamp cover and front panel, if necessary. Plug your TV back into the electrical outlet and power it on.
Tips & Warnings
  • Touching the lamp assembly before it has cooled can cause a nasty burn.
Read more: How to Change a Projector Lamp ' eHow.com http://www.ehow.com/how_7307928_change-projector-lamp.html#ixzz1rpURlpva
Apr 11, 2012 | Office Equipment & Supplies
I need a new bulb for a super 8 movie projector GE projection lamp 150W incandescent projection lamp
Be sure you have the specific 3-letter code from the burned out lamp, in addition to the model name/number of the projector. Armed with that, go to www.bulbman.com They have lamps for just about anything !! Good Luck!!
jim
Nov 15, 2011 | Kodak Office Equipment & Supplies
It hasnot been used in 12 years. it was working for afew days then it wasnt. the power was on but the big light in the back is out.is it the bulb or something else? Is it worth fixing? can I get an...
Chances are that if the cooling fan is running, then you burned out the lamp. Contact Bulbman.com or Bulbs.com for a quote on the lamp. If your projector is a Carousel 4400, then you will need to replace the lamp with an ANSI Code "FHS" lamp. If that's all that is wrong with the projector the lamp will cost you about $40 (best guess).
Dec 08, 2010 | Kodak Carousel 4400 Slide Projector
I'm having trouble changing the bulb in a Kodak Ektagraphic AF-1 slide projector. The bulb doesn't fit easily into the housing and I don't want to force it.
First of all, verify you are using the correct lamp: it should be a 120volt, 300watt, ANSI Code "ELH" lamp. (This may seem too basic, but you'd be surprised at the number of people who try the incorrect lamp).
If the lamp is correct and you can not insert it by pushing the base of the lamp into the terminal connector relatively easily, then chances are you have a build-up of material on one or both of the lamp contacts caused by arcing (arcing is caused by loose lamp terminal contacts). If this is the case, then you need to replace the lamp terminal assembly (the ceramic-like white piece the lamp terminals should slide into). You should still be able to buy a lamp terminal assembly for your Ektagraphic AF-1 from: www.micro-tools.com
Good Luck !!
May 20, 2010 | Kodak Ektagraphic III E Plus Slide...
Ballast issue on LP640
first off, many churches and schools hang their projectors from the ceiling, and the only time they take them down is when they don't work. it sounds rational, but it gets dusty up there, and without proper and relatively frequent cleaning, the dust builds up and the projector can't release the heat properly. this causes a lot of malfunctions. the ballast is only one of them.
to replace the ballast:
make sure you can get the part from infocus or an authorized service center. it's part # 525-0085-51. after you remove the cover (4 screws on the bottom. you'll need a T10 torx driver. slowly slide the top forward and lift off), gently remove the ribbon cable by sliding the cable locks (on both sides of the cable) towards the front and pulling the cable out. the ballast is at the front of the projector next to the lens and in front of the lamp. pull it out and remove the ballast from it's housing. there are 3 cables coming off- the power plug, the lamp plug, and the lamp enable plug. remove those and replace the ballast. reverse the steps to install.
Aug 13, 2009 | InFocus SP-LAMP-017 Projector Lamp for...
GE Slide Projector Lamp Cmv/cmt 115-125 Volts 300 Watts Logo
74 people viewed this question
Top GE Office Equipment & Supplies Experts
Lampdeng.com
Lampdeng.com
Bill Boyd
Are you a GE Office Equipment and Supply Expert? Answer questions, earn points and help others
