Question about Stihl Garden
Stihl fs 250r magneto flywheel gap seeting?
Need to know the setting for the gap between the coil and flywheel
steve_lima
  • 181 Answers
SOURCE: coil flywheel air gapfor stihl 09 model
set the air gap at .011 to .012.inches,set carb high and low needles at 1 turn and 1 turne to start. after running it might take a minor adjustment to finish
Posted on Jan 12, 2009
dontbother10
  • 2220 Answers
SOURCE: what is the gap setting on a poulan pp4218av chain saw
You need something non-magnetic. Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when flywheel is rotated.
Card stock is usually 0.0085 - 0.0095"
If you still have no spark after assembly please reply below and I will happily assist you. HTH
Lou
Posted on Feb 08, 2010
dontbother10
  • 2220 Answers
SOURCE: magneto to flywheel gap for Husqvarna 455 Chain Saw
Ignition module gap
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 22, 2010
wireguy212
  • 1627 Answers
SOURCE: Need Coil to Magneto Settings
You should use a 25000 brass feeler guage bit as a rule a piece of cardboard from a ciggerette package will work just fine.
Posted on Apr 13, 2010
dontbother10
  • 2220 Answers
SOURCE: Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin: need gap for magneto adj....
Ignition module gap
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Apr 27, 2010
No fire to plug need to test coil
Lawmowers have a coil mounted along side the flywheel. You have to remove pull cord assembly, then remove flywheel nut. now the coil is exposed. most of the time rust on the flywheel is the only problem. Clean with 120 grit sandpaper. Loosen the coil screws so the coil can move in and out, then palce a match-pak carboard flap between the flywheel and the coil and snug down the screws. you should be all set. Now make certain to check the flywheel key to see if it is bent or broken. These keys are made of soft metal to protect the crankshaft from being damaged. So replace the key if damaged or broken. This should solve your problem. To test the coil you either need a ampmeter, or you can pull the cord while holding sparkplug wire 1/2 inch from engine bolt and look fo spark while pulling the rope. Good luck. Don't forget to remove the matchbook from the flywheel after setting gap, which is .010 thousands of an inch.
Mar 28, 2014 | Briggs & Stratton Garden
Put new coil need how to set the coil
For an external coil, the air gap should be 0.3mm,slacken the fixing screws, place a suitable feeler gauge between the coil laminates and the flywheel, turn the flywheel so as the feeler gauge is sandwiched between the coil laminates and the flywheel manets, now tighten the fixing screws.
Dec 30, 2012 | Garden
My 5 hp briggs stopped running. No spark. took recoil off to reveal a rotten coil with wires rotted off. cleaned off the flywheel and replaced the coil with one from Napa. The engine does not have points...
Did you set the Air Gap correctly, it should be .020 inch. If the Air Gap is correct and you cleaned the pickup magnets, you should be getting spark. I have different color coded plastic sheets of the correct thickness to set the Air Gap on different engines. You could use a use a side panel from a plastic soda bottle (Mt Dew, Pepsi, ect) Place it between the Flywheel and the Armature/Ign Coil. Allow the magnets on the Flywheel to pull the Armature/Ign Coil together and then tighten the Armature/Ign Coil bolts. Carefully turn the Engine while pulling the plastic from between the Armature/Ign Coil Pickups. The Armature/Ign Coil is now properly set.
Generall speaking for a gasoline engine to run you need 3 things. (1) Spark, (2) Gas and (3) Air.
I hope this is helpful. UAW 974
Jun 25, 2011 | Sport & Outdoor - Others
Replaced coil an still no fire out of wire kill wire is not hooked up
My name is Dane and I am going to help you solve your problem. Ok, there aren't many things that can cause you a problem here. First, I have to say to check that spark plug. Make sure it's correctly gapped and not cracked or fouled. Now, check that the flywheel is clean and rustfree. Make sure you have set the coil gap correctly.
To set the gap for the coil, get a regular business card and use it as a feeler gauge. Turn the flywheel so the flywheel magnets are away from the coil. Loosen the bolts to the coil, and pull the coil back, making the gap as large as possible. Rotate the flywheel so the magnets are next to the coil. Slide the business card in between the coil and the flywheel magnets and loosen the coil bolts. If your coil has 2 legs, make sure the business card is under them both. Make sure the coil is even and just snug against the card. Now tighten down your coil bolts and spin the flywheel to remove the business card. Turn the flywheel at least 1 complete turn and make sure it doesn't contact the coil. You're done!!! Put it back together and try it again. It's not unheard of to get a bad new coil. Don't think just because it's new it has to be good.
Well, I think this should get your problem fixed. Thank you! Dane
Dec 22, 2010 | Echo Pb - 413t Backpack Blower
How do you set the gap between the coil and the flywheel, what is the gap on a 4hp snowblower briggs&statton
Too set the gap for the coil get a regular buisness card and use it as a feeler gauge. Loosen the bolts to the coil. Rotate the flywheel so the magnets are next to the coil. Slide the buisness card in between the coil and the flywheel magnets and make sure the coil is tight against the card.
Now tighten down your coil bolts and remove the busisness card. Turn the flywheel at least 1 complete turn and make sure it doesn't hit the coil. You're done!!!
Well, I hope I've helped. If you found this information useful, please leave me some THUMBS UP if you think I'm deserving! :-) Thank you! Dane
Dec 05, 2010 | Briggs & Stratton Garden
Oh160170048F engine I removed the coil, now i don't know what the gap should be??
The air gap from the ignition module (coil) to the flywheel can be set with a clean and dry business card. Set the gap to maximum and snug down the bolts. Then rotate the flywheel around so that the magnet is positioned directly in front of the module. Place a business card in the gap, and loosen the bolts. The module will be drawn to the magnet. Tighten the bolts and rotate the flywheel to remove the card.
Dec 02, 2010 | Garden
I am replacing a bad coil in my Echo SMR 2100. I need to know the air gap between the coil and the flywheel.
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction abates and remove the card. Ensure nothing contacts when the flywheel is rotated.
Aug 06, 2010 | Echo Garden
16'' chain Saw wont fire
Ignition module gap
Lou
May 02, 2010 | Garden
I need coil and spark plug gap settings for echo hc 1500 type E2 hedge trimmer.
0.026 inch, or 6-8 mm is the plug gap.
The ignition coil air gap range is 0.012 - .016"" or .3 - .4 mm. This is the gap between the flywheel and the ignition coil.
An easy way to gap your coil is use a normal business card between the coil and flywheel, tighten the screws and remove the card.
Oct 23, 2009 | Echo Garden
Garden Logo
468 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
