Question about Schwinn Cycling
Serial number EC44575 also found F77 - just wonder what year boys bike
Cannot find any numbers on pedal these were close to screws holding on back wheel
    New Friend:
    Problem Solver:
  • 18 Answers
Why do you want to know is it real old then you could go to youtube and there are videos that tell you how to read those things but it would have to be before they were bought out by Wal Mart.
Posted on Jan 24, 2013
randy54156
  • 55 Answers
SOURCE: rear wheel problem
Take the wheel off the bike. take the outer two nuts & washers off. You will then have another set of nuts. You should only beable to get eathier a 1/2 or 9/16 wrench on the inner nuts. Then tighten those nuts. Not too tight, just snug. Replace the wheel on the bike, replace the washers & nuts and tighten those tight.
You should beable to pedal.
You did'nt say if this is a single speed, 3sp, 10sp or 15sp. If you have additional gears, then you may have to reallign the cam for shifting.
Posted on Nov 08, 2008
  • 21 Answers
SOURCE: remove the pedals from a boys huffy bike
Bike pedals can be a little tricky, but most likely for that bike you will need a 9/16's wrench. There should be some flat surfaces inboard of the pedals between the crank arm (the long arm that you screw the pedals into). Now, here's the hard part - the R pedal is normally threaded, but the L pedal is reversed. The easiest way to remember which way to turn the wrench is to stand behind the rear wheel and you will always pull the wrench towards you to loosen. Depending on how long the pedals have been on, they might be pretty tough to get off. You could use some penetrating spray (like Liquid Wrench) and let that sit for awhile. Also, once you get the pedals off, remember to put a little grease on the threads so that next time they won't be so tough!.
Posted on May 14, 2010
Coachphil
  • 347 Answers
SOURCE: gave my 10 year old
Your pedal falling off is never a good thing, nor is the entire crank arm assembly.
For this one you are best taking it into your local bike shop and have them take a look at why both of these fell off. There are a number of reasons, from stripped thread to missing bolts and nuts to improper assembly. None of these are a good scenario with a childs bike, or any bike for that matter.
Alternative, and my personal suggestion - Take the bike back to where it was purchased and exchange for a new one. These parts should not fall off after years of riding let alone 2 days, and would constitute a warranty and safety issue.
I WOULD NOT RECOMMEND CONTINUING TO RIDE THIS BIKE, SINCE YOU DO NOT KNOW WHAT ELSE WAS IMPROPERLY ASSEMBLED.
Posted on Nov 29, 2010
Coachphil
  • 347 Answers
SOURCE: Where can i find the serial number on the 16"
The Serial number is most commonly located on the bottom of the bike inbetween the crank arms.
Sometimes it has been painted over and tough to read. Yoiu may also need to remove a plastic protector from the area, but not always.
If the serial number is not there it may be near the where the rear wheel enters the frame on either side. or near the steering column of the bike.
Posted on Dec 09, 2010
dunnbiker
  • 8546 Answers
SOURCE: I am wondering where I
Any Mongoose dealer or bicycle shop should be able to handle that or just web search for a 20" BMX wheel. It doesn't appear to be unique.
Posted on Sep 13, 2011
R610 U0439 Is this a Fuji bicycle serial number? I just want to know if this I should real Fuji 1997 made
This really backdated serial number i'm try to found out it but but there no option even the official site don't have this number
Fuji Bikes Fuji Bikes Building the best bikes for 118 years
Sep 16, 2017 | Fuji Cycling
I have a bridgestone 10 speed bicycle with a serial # 252185 and would like to knowthe model # and year of production in Tokyo Japan
The model is written right on the frame, unless it's been repainted. The info you are looking for will not be found with the serial number.
May 15, 2016 | Cycling
How do i find year if all i have is serial number.
Bike serial numbers - Bike Index
https://bikeindex.org/serials
All bikes all have unique serial numbers. ... Hopefully you can find the serial numberon the bicycle you're looking at, Contact us if you're having trouble. Okay ...
What bike serial numbers are - and where to find them. ... All bikes all have uniqueserial numbers. Most bicycles have their serial number engraved beneath ..
How to Read and Check Your Motorcycle or ATV VIN ...
www.motosport.com/.../how-to-read-and-check-your-motorcycle-or-atv-...
Jul 10, 2014 - The Vehicle Identification Number or VIN of your motorcycle, dirt bike or... The VIN contains information on the manufacture, model year and where it was built.... to find exactly what you need and quite often a sales rep will ask for it. ... dirt bikeor ATV the VIN tells you or a prospective buyer if the bike has ...
Jan 05, 2016 | Motorcycles
Looking for the make of a frame with this serial number U485606471 or U4356064171
Locating your bike's serial number. The majority of serial numbers are located under the bottom bracket where the two pedal cranks meet. Simply turn your bike upside down and record the number. If there is no serial number there then check places like the headset at the front of the bike or the rear stays.
Locating your bikes serial number
Serial numbers
Dec 17, 2015 | Cycling
Bike serial number look up
Usually the serial number is stamped on the frame underneath the bottom bracket. Turn the bike over and look at where the pedals are attached to the bike.
Failing that it will be stamped on one of the bottom rear wheel stays. They are the bits where the back wheel is held.
Hope this helps
Sep 04, 2014 | Huffy Cycling
How do you find age of schwinn bike
I don't remember hearing about any important numbers being under the pedals. Pedals are detachable, so you wouldn't put an important number there. The bike serial number is usually stamped on the round tube that houses the pedal mechanism, the central plate that a kick stand is attached to or at the back and usually on the left hand side. Honestly there's million's of barely used bikes out there ( we in the USA are notorious for buying bikes and then not using them) and I doubt you've got one worth more than 25$. If it's been in the shed, then the tires and tubes are probably flat and dry rotted. It'll cost about $40 to replace the tires and tubes, so keep that in mind. Now if you've got a "Stingray" or something with a banana seat, you could get around 200$ for it. Remember a bike is only worth what someone is willing to pay for it. Oh yeah, if you still think you've got something special, go to EBay and see what something similar to it has sold for.
Jul 18, 2013 | Schwinn Cycling
I have a grundig yacht bot 205, serial number 001143. I was wondering what year and where it was manufactured?
The Grundig Yacht Boy 205 was early 90s and could have been made anywhere. The Grundig Yacht Boy 205a was early to mid 60s and made in Germany.
Apr 28, 2011 | Grundig Yacht Boy 205 AM/FM/SW Radio
Gave my 10 year old son a 20" huffy axis this past Wednesday for an early Christmas present. The pedal fell off Friday! How do I put it back on? The pedal, as well as the thing that screws into the...
Nov 29, 2010 | Huffy 20in Boys Axis Bike
Cycling Logo
48 people viewed this question
Top Schwinn Cycling Experts
Michial Gueffroy
michael
michael
Jim Goldsmith
Jim Goldsmith
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
