Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
No hard drive in my laptop. Should it still get some kinda power?
I have a laptop without a hard drive. Should it still get some kind of power?
    President:
  • HP Master
  • 1,314 Answers
Yes; your laptop should still have power even if the hard drive is removed.
Thanks and please take a moment to rate this solution as fixya since your question was answered. :c) Thanks!
Posted on Jan 28, 2009
  • Kevin Shafer
    Kevin Shafer Jan 28, 2009
    So why the bad rating? I answered your question and it is the correct answer. This should have received a rating of fixya.
    Genius:
  • HP Master
  • 1,102 Answers
It should have power
you would hear fans running and power light would be on
Hi, I have bought this dell vostro 1015 laptop one and half year ago. Day before yesterday my windows XP hanged and I was unable to shut down. So I pressed power on button for few seconds to switch off...
It sounds like your hard drive has gone bad. As this is a laptop you can try to reseat the hard drive, if that does not help then it might be a case of hard drive crash.
Oct 29, 2010 | Dell Vostro 1510 Laptop
My hp Pavillion dv4 will not boot. For a while it has been having problems waking up from hibernation mode. I always did a hard restart and after a while it would boot back up normally. I have had problems...
Even though a lot of things might have gone wrong and caused this,
But I will try and tell you some troubleshooting steps that you can try.
First of all, disconnect your battery from back of the laptop, and try to power your laptop without the battery there, if it powers up, then just get a new
battery.
Second, get a screw-driver, remove all the RAM(memory sticks) at the back of it, clean their interface with an eraser, and try to power it on first without
them, then replace them back and power it on.
Alternatively,
Remove all your RAM(Memory Sticks), and clean the tip of the connector with an eraser, and re-insert it one after the other.
That is, if you have two of them, after you insert the first one, put on your system and see if it works, then do the same thing with the other one.
If the two of them works, them insert the them all. but if it is just one that worked, just remove the other one that is not working and replace it.
Also from what you have just said, I suspect that your hard drive is likely to be corrupt, or having a bad sector on it.
To be sure of this, disconnect your hard drive from the laptop, and power it up without connecting the hard drive, if it boots up to the point where it says:
"Operating System Not Found" or "No Bootable Device Found", then that shows that your hard drive needs replacement
Kindly Let me know how it goes.
Hope this helps.
Jul 28, 2010 | HP NB199UA Pavilion Notebook
I tried to turn on my hp laptop. At first it flickered and and then I took the battery out and then I put it back in and turned on my laptop again. but the screen was black. Now it remains black.
battery.
Alternatively,
Hope this helps.
Jul 28, 2010 | Computers & Internet
Someone gave me a metrobook vl laptop. It looks kinda old timing and I wanted to get it upgrade. How do I do this without a diskdrive?
Hello
Ok, firstly, you need to have a hard drive in order to use your computer. An upgrade will usually be a ram module upgrade, but let me know what the specs of the computer is so that i can get a better insight on helping you.
Kind regards
Andrea
May 24, 2010 | MetroBook VL Plus C-266 Notebook
What kind of hard drives do acers have in them. Also if I had one without an acer laptop to put it how would i get the information off of it. without having another acer laptop, is there something i can...
You can buy a hard drive enclosure,with USB connection.
Then fit the harddrive in it.
Then connect it to any Windows computer and transfer the info.
Just make sure that the hard drive you are transfering to is large enough and have enough space to accomodate the info.
Just go to this site with www.belarc.com. the laptop you want to ascertain about the hard drive type
Download thesystem analyser,and it will give you a readout om just about avery hardwarea and software on the laptop.
In additio to othe ruseful info.
Jan 22, 2010 | Acer IBM DNES 309170 (91.AB032.008) Hard...
How do I transfer/move the contents of a 70 gb hd to a larger hd without reinstalling the programs?
Macrium Reflect is one method, it can "clone" your hard drive to another hard drive without having to re-install any of your programs.
http://www.macrium.com/ReflectFree.asp
and best of all it is free!!!
I hope this helps,
Thanks David
Mar 10, 2009 | Gateway MX7118 Notebook
LAPTOP WILL NOT POWER ON AND I WANT TO RETRIVE
I send those frequently for repair. Please visit this site at Hp.com check your serial number and I bet your laptop will be there. The warranty was extended for these models and your laptop will be fixed without any cost.Remove your hard drive before shipping or they will erase everything.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us&dlc=en&product=1842189&lang=en
Good Luck!
Mar 05, 2009 | HP Pavilion dv6000z Notebook
I dropped it on a floor. Now it gives an alarm sound.
wow..you'll need to get a data recovery expert to 'snapshot' your drive to attempt to recover your data. I'd suggest that the 'drop' did a major mechanical deal, like a head impact crash. Not good. A local tech store/computer shop MIGHT have the tools to extract the data. Last time I checked, it runs from 100 to 300 bucks, depending on what kind of files are retrieved.
Feb 16, 2008 | LaCie BRICK (301063U) 300 GB Hard Drive
Laptop wont power on!!
I would suggest first formatting the hard drive and then go from there, If that is feasible for you... Good luck... GURU JAY
Jan 30, 2008 | HP Compaq Presario 2500 HP Pavilion ZE...
Keycaps
to get the key back on u will see a metal clip on the underside of the button, kinda hard to explain but easy. take the metal clip and put it in the small clips on the laptop then press the key kinda hard and it will clip into place.. Hope you get it John
Aug 27, 2006 | Dell Inspiron 9300 PC Notebook
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
19 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
