Question about Humidifiers
Generalaire 1137 humidifier no water
I have a three year old 1137 humidifier that is not letting water through the solenoid. It is the 115 volt model. I bought a new solenoid and still no water. I have good water supply to the solenoid. When the furnace is on the humidifier fan also comes on but the solenoid does not open to let water through. I have moved the humidistat back and forth from high to low and it does not open the solenoid. Possibly the relay circuit assembly is bad. I guess that is my question are do you have any other ideas or solutions. Thank you.
Joe_Rex
  • 114 Answers
SOURCE: Installation problem
I WOULD CHECK TO SEE IF YOU HAVE ENOUGH V/A OUT-PUT ON TRANSFORMER. I DONT KNOW IF YOURS CAME WITH ITS OWN TRANSFORMER. IF IT DIDNT YOU SHOULD HAVE A MINIMUM OF A 40 V/A RATING STAMPED OR PRINTED ON THE EXISTING TRANSFORMER. IF THE TRANSFORMER IS EXTREAMLY HOT ... YOU MAY NEED A 75 V/A TRANSFORMER WITH THE SAME VOLTAGES. INCREASING THE V/A CANNOT DAMMAGE ANYTHING IT JUST GIVES YOU MORE POWER WHEN EXCESIVE CONTROLS AND WIRING ARE ADDED TO A HVAC LOW-VOLAGE (24v) CIRCUIT. IF YOU LIKE YOU CAN CALL ME AT 727-363-7071. I AM A RETIRED HVAC&R CONTRACTOR WITH 45 YEARS EXPERIENCE. I HATE THE NEW SENSORS THEY HAVE TO ACTIVATE THESE NEW HUMIDIFIERS. I USE TO WIRE THE HUMIDIFIER TRANSFORMER (SUPPLIED WITH HUMIDIFIER) TO THE LINE (110V) SIDE TO THE LOW SPEED ON YOUR BLOWER MOTOR. THAT WAY THE ONLY THING THAT INTERUPTS THE CICUIT IS THE HUMIDISTAT. YOU NEVER WANT THE HUMIDIFIER TO RUN IF YOUR SYSTEM IS NOT "CALLING FOR HEAT". NEVER TRY TO ENERGIZE THE WATER SOLENOID THROUGH YOUR HEAT WIRE(USUALLY SMALL THE WHITE WIRE) FROM THE THERMOSTAT. THIS WILL RESULT IN BURNING YOUR HEAT ANTICIPATOR OUT ON THE T-STAT.
Posted on Apr 28, 2007
  • 4 Answers
SOURCE: water not getting to panel when furnace is on
I had a problem quite similar to this. It was the power connector. This is the 4-pin white connector that engages when the cover is removed/replaced when accessing the water panel.
One of the pins was loose in the connector thereby supplying intermittent 24 volt power for the solenoid that is powered by the fan motor control board transformer in the humidifier cover next to the fan motor (not seen unless fan is dissembled).
If you are technical such as I am this is easy to fix by removing the connector, removing the loose pin, and often each retaining clip on the connector pin can be bent out slightly, then replace the pin, and then it should be fine. Also, it's best to check this out on a bench while running the entire unit. You also might need to replace the entire power connector. Sometimes it's easy to think the problem is a defective solenoid or fan motor/transformer board, etc. It's frustrating, because sometimes the humidifier works perfectly, and then sometimes there is no water flow. Since I did this mine has been 100% OK.
NOTE: IF YOU ARE NOT TECHNICAL DON'T EVEN ATTEMPT TO FIX THIS PROBLEM, CALL IN A PROFESSIONAL TECHNICIAN. LETHAL VOLTAGES ARE PRESENT IF THE FAN CIRCUIT MOTOR CONTROL BOARD IS EXPOSED. ALSO, MUCH OF THIS IS FRAGILE. IT COULD
BECOME COSTLY IF YOU MESS UP.
Posted on Feb 07, 2008
  • 290 Answers
SOURCE: he 260a wiring w/humidistat
try this forum...there are wiring diagrams posted there:
http://forum.doityourself.com/humidifiers-dehumidifiers-130/
Posted on Dec 12, 2008
machtcl1
  • 61 Answers
SOURCE: wiring problem
Sounds like you may have put 120v through a 24v solenoid and humidistat.
Is the HUM terminal on the furnace 120v or 24v?
If it is a 120v terminal you will need a 120x24v transformer and a new solenoid and maybe a new humidistat.
Posted on Jan 02, 2009
mrgrzz
  • 88 Answers
SOURCE: Water does not pass through solenoid
Thanks for your question,
first you need to determine if you have 24 volts from the transformer, if you have knowledge of electrical meters then this should be fairly easy, if not then you will need to do a little rewiring to find out if it is the solenoid, first you will need to do is shut the power off to your furnace, then get some t-stat wire, long enough to reach from the solenoid to the transformer, splice together the new wire to the wire from the solenoid, now take the other end of the wire, take the leads off the transformer (low voltage side) and hook the new leads to it, make sure the water is on, now turn the furnace back on, and if the solenoid is good the water will flow, if it doesnt, then you will need to replace the solenoid, if the solenoid does work then you know your problem lyes with the Humidistat, and you will have to replace that, but you need to determine if you have 24 volts from the transformer first, hope that helped, let us know and please rate this, thanks again ,
mr.grzz
Posted on Jan 25, 2009
Leaking at base due to too high of pressure or defective evaporative filter?
Humidifer FAQ's - General Filters, Inc.
www.generalfilters.com/support/faqs/humidification.html
I already have a GeneralAire® 1042 Humidifier installed, but have a 4,000 square foot home. Should I ... Can't I simply clean my Vapor Pad instead of replacing it? Where do I find ... I am seeing a very slight water leak coming from the bottom of my steamhumidifier. What do I do ... Legacy 1137 = 21 GPD / Up to 3,000 Sq. Ft.
GeneralAire® Legacy 1042 and 1137 Humidifiers - YouTube
? 3:22
https://www.youtube.com/watch?v=IM6IXVcjEdU
Jun 27, 2013 - Uploaded by GeneralAire Inc
GeneralAire® Legacy 1042 and 1137 Humidifiers - How to change the vapor pad .... Evaporator Pad (aka filter) change on aGeneral Aire 1042 ...
[PDF]General Aire Humidifier Owners Manual - On Time Mall
Jan 16, 2016 | GeneralAire Legacy 1040 Humidifier...
My generalaire humidifier leak from the bottom , I have check the hose and inside all ok
Did you check the orifice inside the supply water tube? Sometimes the orifice can come loose and allow to much water inside the humidifier.
Feb 06, 2014 | General Filters 1099-LH Humidifier
What's your problem?Wire connection for GeneralAire power hfumidifier #1137
You will need a current sensing relay to cradle the blower motors common wire to accomplish this.
Jan 08, 2013 | Humidifiers
There is no water going into the humidifier, make: Generalaire 1042
Hello, first thing is check is the strainer going into the solenoid valve for sediment, if there is clean the strainer and reinstall. If the strainer in clean the check if you are getting 24 volts to the solenoid valve, if you have voltage and the solenoid does not let the water thru replace the solenod valve.
Apr 09, 2011 | General Filters 1042-LH Humidifier
Not getting water into the unit and the unit is only about 1 month old
Hello, check to see if you are getting 24 volts to the solenoid valve, if you are and the solenoid does to click to let the water in it must be replaced. If you are not getting 24 volts start at the transformer and work your way toward the solenoid valve to find where the voltage stops.
Feb 26, 2011 | Aprilaire 400 Humidifier
Aprilaire 600 problem
It sounds like you got it...
The solenoid will not open with only 13 volts to it. Jump or apply the full 24-27 volts to the solenoid and see if it clicks and opens and allows water to flow.
If the valve still won't open or pass water, start looking for a plugged inlet solenoid inlet screen or a faulty solenoid valve as well as a faulty humidistat.
Jan 06, 2010 | Aprilaire 600 Humidifier
I just installed a General 1137 Humidifier. IT
One of the Humidistat yellow wires that was secured with a wire nut had broken off at the insulation line of the wire. While the connection felt secure, the electrical connection was broken.
Dec 17, 2009 | General Filters 1137 Humidifier
Water runs constantly through my General 1137 humidifier
If the water continues to run even when the humidifier is turned "off" then you mostly have a defective solenoid valve.
Apr 03, 2009 | Humidifiers
Humidifiers Logo
163 people viewed this question
Top Humidifiers Experts
Paul Carew
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
