Question about Crafts & Hobbies
Zipper won't zip up its almost shut closed
    Genius:
  • 1,669 Answers
If all the teeth of the length of the zipper are snapped together, it is closed and the pull piece is all the way at the ends of the two matching sections. It appears jammed at that point, right? If so you may need to use a little muscle to pull the end links one way and the zipper tab the other. A pair of plyers sure could help.
Posted on Jan 23, 2013
A zipper replacement for a tommy hilfiger back pack. zipper breaks open, after it is zipped close.
You can do a google search for "tailors" in your area, call and ask them if they would replace/repair a zipper on your back pack.
This FixnZip item may also work, without any sewing needed.
Zipper Repair Without Tools or Sewing FixnZip
Nov 16, 2016 | Tommy Hilfiger Watches
Using an invisible zip foot my machine jams after a few stitches. It doesn't jam with any other foot, and when I sewed with the foot on a scrap of fabric with no zip as a test
Make sure that the needle is not too close to the zipper coils. Also, that the needle is not hitting part of the presser foot. Sounds like the needle is most likely encountering the zipper coils which are deflecting the needle. Move the coil further away from the needle.
Sep 04, 2016 | Sewing Machines
How do I fix a complete zipper
if you mean how do you sew in a zipper
do it up and then position in in the opening using pins to hold it in place while you sew it in
when finished you can open and close the zip and it will always be in line
Dec 06, 2015 | Sewing Machines
I am trying to insert a zip. The needle is not moving far enough to the left or right so that it doesn't hit the zipper foot. Please help
try using a 1/2 foot as this will allow the needle to get close to the edge or zip
commonly used for making a rope edge
available from any sewing machine shop
Aug 01, 2015 | Sewing Machines
The zipper on my Asos dress split and it is stuck in the middle of the zip with both ends open. Now I can't zip it down
Hold the zipper that both sides are parallel then go upwards then downwards . Once u go upwards look it could be a little thread stuck in it .
Coz it's a plastic zipper it happens just get it replaced .
Aug 30, 2014 | Sewing Machines
My zipper on my jacket wont zip up.
Make sure it is properly hooked at the bottom. Get a cake of soap and rub it on all the zipper teeth. Carefully and slowly try to ease the zipper up. Also,make sure there is no material caught in it.
Oct 13, 2013 | Eureka Tundraline Tent
Got bernina 1015 sport sewing machinewith one foot want to buy zip,buttonhole &overlock foot is ther a special number or do all bernina feet fit al types of bernina machines
This machine uses 'New style' snap on feet. The reason it is 'new' is because old style Bernina feet are the complete foot, whereas new style you just 'snap on' the foot base.
Ebay is the best place to find original Bernina feet at very reasonable prices. I recently purchased a solid steel 'old style' foot from UK for U.S. $28.
When purchasing zipper feet, decide if you want regular zipper foot or invisible zipper foot. Often it is cheaper to order both at the same time, due to S&H fees.
Jul 24, 2011 | Sewing Machines
How to sew in a zip? with Empisal dress maker 270
Sewing in a zipper is a fairly easy process, though a bit hard to explain in words :) You need an iron, pins and a zipper foot for your machine. The zipper foot allows the needle to get close enough to the teeth of the zipper without the foot getting hung up by the teeth.
The best thing to do in order to understand the process if you've never done one before is to look a a video on youtube and watch how a zipper is put in. Here is one link that shows how to insert a zipper http://www.youtube.com/watch?v=ue5z2rWS588&feature=related ...but there are several others too. Some show specifically "invisible zippers", some show side seam zippers and others show how to put one in where you have a waste band. When you get to the link above look to the right side of the page where you will see other videos to pick from too.
There are lots of interesting sewing videos on youtube. You'll note that though the process is basically the same different seamstresses have different tricks for getting a straight and tidy looking zipper.
May 16, 2011 | Sewing Machines
Would you please advise how I put a zipper foot on my brother bm-3600, the needle will not align with the foot when I put the foot down! Thank you.
Did a google image search, this looks like a newish machine so I'd assume clip on feet?
Put the foot on the pressure plate, lower the foot on and align so it clicks into place.
Couldn't get an image of the foot but many zipper feet are designed to mount either left or right side of the foot so you can sew both edges of the zip in the same direction, ie pressure foot to left of the needle for one side, and to the right of the needle for the other side of the zip, you want to stitch in the same direction to avoid creeping.
Some machines you change the change the needle position to the left or right in order to get up close to the zipper foot.
Probably a manual would assist explaining this better, if you don't have one for the machine, I'd suggest that you obtain one.
Mar 07, 2011 | Sewing Machines
Crafts & Hobbies Logo
73 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
