Question about Maxell 665305 GENpro External 2TB USB 7200 rpm Hard Drive
Once wired in and turned on I can not find the drive in windows explorer. I'm using Windows8, brand new machine. Can't find anything like a users guide or manual anywhere. What am I missing
  • Maxell Master
  • 27,725 Answers
Http://windows.microsoft.com/en-US/windows-8/get-started?page=vid1 you will find more information on windows 8
Posted on Jan 24, 2013
New harddrive on computer , old drive had windows 7 new drive has windows 8 . it won't let me download software
Hi with Windows8 Microsoft introduce store a place from where you can download application otherwise you are still able to download any program from internet unless the option to download is blocked by administrator or anty virus program or there is some problem with website.
Apr 08, 2014 | HP Officejet Pro 8600
My Buffalo 1TB mini station HD PCU2 started having some problems after connecting to my new laptop which is having windows8 os. At 1st i couldn't open some folders. It said to format. Did it thrice...
The windows 8 will not recognise the driver for this unit and this is a common problem with win8. Try to get Microsoft download for the correct driver for you machine
Aug 03, 2013 | Computers & Internet
Windows8
There are also books available. some are in PDF format. One is called "Windows 8 Secrets".
Apr 13, 2013 | Samsung Computers & Internet
Corel 8 will not work in windows 7
Corel Photopaint 8 will not work under Windows8, or Windows 8.1 either.
Corel advertises their CorelDRAWx7 graphics suite as being functional under Windows8, but I have to say... I have had no luck getting THAT to work under Windows8, EITHER. It installs just fine, and then when you go to open it, it hangs on the interface initialization. Literally.. hangs. Oh. And you CANNOT kill the process from the task manager, either.
I\'m very glad that I only was trying the Trial version, and didn\'t actually shell out $549 for the full program!!!! I have been using Photopaint-8 for about ten years. It\'s a very powerful editor, it\'s a wonderful program, and the ONLY reason I have to stop using it is because of my OS??? That annoys me.
So does installing a program that a company says "Works under WIndows 8" and then finding out that it WILL NOT WORK UNDER WINDOWS 8.
So don\'t waste your money on the CorelDraw suites, either, if you are stuck with Windows8. They won\'t work under the damnable OS, EITHER.
I have YET to find a freaking image editor that WILL work under this farking OS that is actually fully functional, and not missing severe levels of functionality. Congratulations, Microsoft, on pissing off artists everywhere, and then coupling that with making it impossible for us to DOWNGRADE your USELESS OS.
Don\'t waste your money on ANY of Corel\'s products until they actually become STABLE under Windows 8, folks. And I really hate saying that, because I love their products. But if they wont\' work under the OS that Microsoft has purposely and intentionally made it impossible to downgrade from, then it\'s not worth the money to buy the products...
Jul 06, 2012 | CorelDraw 8 Full Version for PC...
I have a 1998 ford explorer with power windows. They will not come down. Fuses are good, Motors are good. Took Volt meter and tested the window switch on driver side door and they were all good. Need some...
Window fuse's and relay's may be up under driver or passenger side dash or behind glove box, under the hood and even under the seats, and finally on the ends of the dash. All passenger power windows are controlled thru and get power from the master control switch on the drivers door.
Drivers door window gets used the most so it could be the motor, window switch, relay or fuse.
Could also be a broken wire in the rubber boot going from the door to the body. You will have to eliminate each till you find the culprit. Check that all switches return to neutral when released.
The motor and the relay are the most likely to cause this problem. Try swapping the relay with a working window relay. If it still doesn't work, remove the door panel and remove the window motor.
Turn the motor shaft in both directions by hand several turns. Then plug the motor in and see if the switch will now run the motor. Sometimes that's all it takes to get it working again. I have had to do this with brand new motors. If voltage is not present at the motor connector, either a bad switch or a broken wire exists. Make sure to check for voltage coming to that windows switch.
Try this....
Open the door, turn the key to the ON position without starting the engine and everything that makes noise is off. Lean down placing your ears close to the bottom center of the door or at the speaker grill. Press the window switch UP and DOWN. Listen for the window motor. If heard the drive is damaged. If not heard, turn key off and locate and replace the relay with one of the other window relays. Check window again. If it works now, get a new relay. More often than not, removing the motor and turning it by hand will get it working good as new. I have had to do that with Brand New motors! So try it.
If all has failed, with the door panel still off, check for voltage at the motor connector when pushing the window switch. No voltage means its the switch, especially if its a auto down or up switch.
Check the master window control panel on the driver's door. There is probably a lockout switch. It may have a window outline on one end and the same outline with an "X" over it on the other. Press the outline without the "X" and all your windows should work again. As silly as that sounds, a lot people hit that switch without knowing it. Also if that switch(lockout) is faulty, none of the windows will work. That happens A LOT!!
Aug 22, 2011 | 1998 Ford Explorer
I plugged in my new drive, the software installed correctly. Then I opened the pdf manual which had installed along with a lot of other files. My machine's OS is Windows XP. Following this, I came...
First if everything is working you do not have to do anything els, decondly .exe is just the extension you need to know the prefix (what is in front of .exe), if the manual refers to just an .exe it is refering an exemple so don't bother with it, if it works just use it...
Cheers!
Aug 20, 2011 | Western Digital Passport WDXML800UE...
Since installing windows8, I cannot connect to the Internet via Desktop, I have to go through Mozilla Firefox???
I am hoping that you meant "windows 7" and not windows 8, as there is no such thing as windows 8, only windows 7 premature builds.
You could never connect to the internet via desktop. Mozilla firefox is an internet browser, just as microsoft internet explorer is an internet browser.
You can configure which browser is automatically brought up by opening internet explorer (Start>Internet Explorer) and selecting "use this browser as my default browser".
May 03, 2011 | Microsoft Computers & Internet
REV 120 freezes windows explorer in windows 2003
I have had this problem and found it to be the tapes are the cause.
Last week this same problem happened and 8 out of 10 tapes are causing this freezing suddenly. the other 2 work fine and brand new tapes work fine too.
Jun 23, 2009 | Iomega (32961) External REV Drive
Maxell 665305 GENpro External 2TB USB 7200 rpm Hard Drive Logo
94 people viewed this question
Top Maxell Computers & Internet Experts
yobo007
yobo007
Eric
Are you a Maxell Computer and Internet Expert? Answer questions, earn points and help others
