Question about GE Profile WPRE6100G Top Load Washer
Holes in colthes
Small holes and pulled thread
  • GE Master
  • 17,130 Answers
It is time for a maintenance on the washer, Use a good observation lamp to check the drum , check for metal protrusion, check for drum settings.
click on : Maintenance
Posted on Jan 24, 2013
Singer sewing machine 401
Hi the spool holder on this machine is just a plastic rod with a slight taper and it just pushes into the hole. If the old piece is broken off in the hole, drill a very small hole in the centre of the broken piece and screw in a small wood-screw and pull it out with a pair of pliers
Sep 21, 2017 | Singer Sewing Machines
Memory Craft 300 embroidery machine, top thread is coming back up and getting all tangled up with needle? what do I need to do to fix this problem?
Hm, is it possible the needle is pulling the thread back up through the hole? If so, check whether the needle eye is too small for the thread so the thread is not releasing.
Jul 13, 2017 | Sewing Machines
My se270 wont thread witht he cassette i even bought a new cassette and it still wont thread help
if the needle hole is too small for the particular thread it won't thread. if the threader is missing the hole it will need to be adjusted up or down. you will need to look at your threader for a small screw that will allow it to be risen or lowered. also, if the hook on the end of the threader has been broken it will need to be released. this is usually done by pulling the old on off and simply pushing a new one on where the old one was. the other possibility is you are not pulling the thread across the area where the hook is in order for the hook to catch the thread. many of these things mentioned can be found in your users manual.
Nov 15, 2014 | Sewing Machines
How do I change the bobbin in a Janome sewing machine?
There is a small plastic plate where the needle goes down through the foot, remove this cover and you will see the bobbin. Remove the bobbin and refill or selecting another bobbin turn it so that when you pull the thread the bobbin turns anti-clock-wise, slip the bobbin into the black plastic casing, pulling the thread towards the small red arrow at the bottom of the casing, slip the thread between break in the silver metal sleeve pulling it to your left between the 2 pieces of metal this is where the tension on the thread is. You have now changed your bobbin. With the plastic plate still off, hold the top thread with your left hand and with your right slowly turn the wheel, this will send the needle (holding your top thread) down into the bobbin casing and will pick up the bottom thread, pull on the top thread and bring the bottom thread up through the hole in the plate. Replace the plastic plate and recommence sewing. Good luck
Sue
Sep 24, 2014 | Janome Sewing Machines
How to guide thread on kenmore 158.13201
Most machines are very, very similar, therefore, no matter what brand you own, there's basically the same steps to follow: 1. Place good quality thread on spool pin, back right-hand side of machine and raise presser foot UP. 2.Pull thread taut from spool.Make sure silver take-up lever raised to highest position. 3. Guide thread under first tension disc. 4. Hold thread taut, guiding thread into next tension disc. When you get to the take-up leaver (silver lever on right side of machine that has a hole at the top--hold thread taut guiding it from right to left through hole, bring thread down left side of it, and put thread into tension bracket, hold thread taut! Put thread in back of needle into another small bracket and pull thread towards you. Time to thread needle: put thread front to back into eye of needle. Put thread under presser foot and pull under the center of it a good 6".Lower presser foot on scrap of fabric to test. Turn hand wheel toward you to lower needle into fabric scrap. Use foot (or knee depending on machine) to start machine. Do not pull or push fabric but gently guide it. Jimmy Place fabric scrap under needle. Low
Apr 04, 2012 | Kenmore Sewing Machines
How do you put the thread for the needle for a singer sewing machine model 132q?
Put spool of good quality thread on the spool pin. Thread comes off spool counterclockwise. Raise your presser foot before you do the next steps: Presser foot lifted up now? Great! Pull thread tail from spool toward you and hold thread taut as you put it into first tension disk. Have that thread nice and taut? We shouldn't have any loops hanging down over the machine--okay, Keep threading all of the tension disks. You should be able to actually "feel" the thread fall into slots somewhat. Now when you get to that long silver thing with the hole in the top this is called your thread take-up lever. It should be all the way UP. Turn hand wheel- ( large round knob at end of right-hand side of machine) towards you if need be to raise it. Pull that thread taut from RIGHT to LEFT through the hole in the take-up lever. Take deep breadth here... You're almost done! Pull thread down left side of lever til you get to next disk. Put thread in small bracket located behind needle. Bring thread forward --get yourself 6" of thread-- then put it from front to the back of the eye of the needle. Are you okay? Hope I was able to help. Jimmy
Mar 31, 2012 | Singer Featherweight 132Q Mechanical...
I recently received a Juki TL-98Q and a long arm quilting machine. Everything is set up and I have put two sheets with cotton batting between them on the machine so that I can practice. I cannot get...
Hi Donna:
This has two parts; 1) pick up thread, and 2) needle hole direction.
1) To begin and pick up the bobbin thread, typically I start without any material under the arm. Begin with a tail of thread about 6" long pulled out from the bobbin, leave it loose. Then holding taunt, onto about 3" of the upper thread after it leaves the needle, I cycle the machine once. Then it should have captured the bobbin thread. Raise the pressure foot (with the needle 'UP') and slide something between that gap to pull out both threads (Upper and Lower), a ruler or your thread trimming scissors are handy for this. Pull the threads and you should see both upper and lower threads now, ready to sew. Apology for covering this basic item, but . . .
2) As you move into 'new' machines, sometimes the needle is no longer setup with the hole front to back. The gotcha is that on some (bigger) machine the hole goes side to side (yes the needle is rotated a 1/4 turn). As a rule of thumb, the thread goes through the needle and points right at the hook. Small machines may have the bobbin right 'behind' the needle. Larger machines often have the bobbin (and hook) beside (often to the right) of the needle. That means to install the needle with the hole going left and right, and the cutout groove pointed to the side with the hand-wheel.
End.
Oct 11, 2017 | Juki TL-98Q
Poulan PPB200. There are two gas lines inside the tank. They have deteriorated and need to be replaced. One of them is supposed to have a fuel filter. The other one, I don't know. I'm also not sure...
The small one has the fuel filter. The other one is the return line to the tank. The return line is larger and usually have a fitting at the end of the hose and is inside the tank. Thread the new line ( large hose ) Through the hole on the right side. Thread until you can pull it out the filler hole. Install the fitting on the hose and pull it back up until the fitting hits the roof of the fuel tank (on inside of tank ) then that hose goes to the short fitting on the primer bulb. Then thread the small hose through the left hole going into the tank and pull it out the filler hole until you can install the fuel filter. Install fuel filter and pull it back until the filter rests on the edge of the filler hole. That hose goes to the right side of the carburetor. This is if you have a walbro carb. Zama also uses the right side for this hose. Hope my explanation helps. I'm working on one as well.
Aug 21, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
I just bought a white sew ez and am unable to wind the bobbin following the instruction manual. The instructions say to pull the thread down through the clamper (what's a clamper; it's not shown in the...
If you look on the top of the machine, there should be a little round metal disk near the far left side. That's the clamper it's talking about, also known as the bobbin winder tension. As for the hole in the bobbin, you can use any of the holes. I'm assuming you're using a metal class 15 bobbin, the plastic class 15 bobbins only have 1 small hole on each end. Both will work with your machine.
Feb 22, 2010 | Sewing Machines
Machine is threaded but thread not sewing into material, just holes!
Check bobbin thread....Insert the bobbin thread into the bobbin case in a clockwise direction...pull the thread through the **** on side of bobbin case and slide up into small opening...make sure you pull through about 2 inches of thread to enable upper thread to loop. Good Luck
May 10, 2009 | Sewing Machines
GE Profile WPRE6100G Top Load Washer Logo
14 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
