Question about Maytag Bravos Series MVWB850YW 28" Top-Load Washer with 4.6 cu. ft. Capacity, 13 Wash Cycles,
F51 Code for maytag Washer - Maytag Bravos Series MVWB850YW 28" Top-Load Washer with 4.6 cu. ft. Capacity, 13 Wash Cycles,
5 Suggested Answers
  • 311 Answers
SOURCE: iam haveing a error code of f51 on my maytag
There are two possible causes of this code an unbalanced load can cause this error, The unit usually tries a few times to redistribute the load before it will display this error. Try another load if the error occurs then you have bigger problems. The other cause could be a bad rotary position sensor on the motor in which case you would probably want to call a tech.
Hope this helps _MJ_
Posted on Jan 31, 2010
TheMobilian
  • 8220 Answers
SOURCE: I have a Maytag Bravo
Defective hall sensor most likely, The cabrio bravos and Oasis machines are all basically the same.
MORE here
Posted on Dec 19, 2010
  • 552 Answers
SOURCE: I have an F51 code
If you are handy, yes. The rps sensor is mounted to the motor. Remove power and tip the unit back. The motor has one bolt in the middle that holds it in place. Once the motor drops out the sensor clips off the stator motor.
First time will take you two hours or so. Not difficult time consuming though.
Posted on May 25, 2011
allbrands
  • 600 Answers
SOURCE: Maytag washer -- what does
hello, you need to install part #W10183157. it comes with instructions itnot that hard to install. it should correct your issue. thanks and please rate me :)
Posted on Jun 08, 2011
I have a Maytag washer about 10 years old flashing code f51 is it worth getting fixed
find out what the code means first off the manufactures website by downloading the user manual and checking the trouble shooting guide first eric
Jan 15, 2018 | Maytag Washing Machines
F51 maytag bravo error code?
The F 51 code, would indicate, the control board is not seeing the proper resistance on the motor circuit .
You should check and make sure there are not any articles, stuck between the tubs, or under the agitator.
Make sure you're not overloading the machine.and you have proper voltage to the unit.
Have you run the unit through a cycle empty ?
You may want to try that, before we have to get too involved in circuit and voltage tests.
Your technical data sheet should be on the inside of the front panel, you'll need to raise the top of the washer, using a putty knife to release the clips in the front seam, holding the top down .
Maytag washer Error Code F51 Appliance Repair Forum
Apr 06, 2015 | Maytag Washing Machines
Washer wont spin. F51 code
the f51 error indicates that your rotor position sensor) is not registering or it is just bad. try this, remove and reinstall the connector at the RPS at least three times to clean off any corrosion built up on the connector and RPS due to the intermittent connections. after that go ahead and try to run a cycle. if you continue to receive the error then you need to replace the RPS sensor. Here is that part to order. Whirlpool W10178988 Sensor AppliancePartsPros com
Oct 05, 2014 | Maytag Bravos MTW6600T Top Load Washer
What does it mean f 51
http://forum.appliancepartspros.com/washer-repair/131926-maytag-washer-error-code-f51.html
Jan 30, 2013 | Maytag Bravos MTW6600T Top Load Washer
Maytag washer flashes f 51
You will need to replace the RPS sensor. There is a kit available that will update that washer to the current design. Here is the kit to order.
Nov 23, 2012 | Washing Machines
MAytag Bravos Quiet Series 300 washing machine starts to fill, stops and shows code F51
F-51 RPS senses rotation when basket ought to be stopped.
It is probably loose or worn out.
Video How To
Oct 22, 2011 | Maytag Bravos 3.8 Cu. Ft. Washer
Maytag washer -- what does the code f51 mean?
Jun 08, 2011 | Maytag Bravos MTW6600T Top Load Washer
My Maytag 300 quite series has a code F51 what does this mean?
Hi and welcome to FixYa, I am Kelly The F51 code is a motor rotor position sensor (RPS) feedback error. In other words the control board is not sensing any motor rotation. It is fixable but will result in the replacement of failed parts. (Sensor or electronic control board) The control board is not cheap. Hopefully you only have a failed sensor.
Thanks for choosing FixYa,
Kelly
Feb 16, 2011 | Maytag Bravos MVWB400V Washer
I have a Maytag Bravo top load glass washer and a f51 code. Top wont open and machine has stopped
MORE here
Dec 19, 2010 | Maytag Bravos MTW6600T Top Load Washer
Maytag Bravos Series MVWB850YW 28" Top-Load Washer with 4.6 cu. ft. Capacity, 13 Wash Cycles, Logo
171 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
