Question about Kenmore Elite 45986 Front Load Washer
What dose suds mean and how do i fix it.
Ran trough the code system only got up to 5 and then stayed there. cant get it to work.
  • Kenmore Master
  • 17,129 Answers
Click on : SUD error
Posted on Jan 24, 2013
How do I fix a washing machine that doesn't fill with water, but spins and drains? Water enters the detergent holder, but doesn't seem to make it to the tub. Draining can be heard as well, even though
Hum for one a front load H.E washer should not be having very much suds as u claim it had. Are u aware the front loads are made to use very little soap and if u use to much soap hence alot of suds, ur SUDS SENSOR will act up and can shut down any wash cycle. a trick is to run just water and some vinagar trough a couple loads if u can get to wash at all. Another issue u may have is a plugged line somewhere. or loose unconnected water hose line hence the water on the ground effect. u may want to check ur flow line from the entry into the tub where the water at the moment I cant recall the name of the gadget but it can get clogged or damaged and hinder the water from entering the tub
Jan 15, 2015 | Kenmore Washing Machines
Tip
Sud mean
over dose of detergent detectd during the wsh cycle ////// the motor control unit senses a suds lock condition by analyzing the current draw on the drive motor . if "sud" is displayed a potential suds lock is detected . this may signify a badpump an extra heavy load excessive detergent or excessive suds.................
on Aug 05, 2010 | Washing Machines
Maytag washer leaking from bottom
This is a fix for the Maytag MAH2400AWW, the machine kept displaying SUDS, the machine is 2-3 years old and it started doing this 4-5 months ago. I cleaned out the washer, and used HE detergent, ran it empty, to try to flush it out, used approved cleaners and ran it throught the cycle, still no good. I finally took out out a maintenance contract with BSF, the service guy came out today pulled the pump off and showed me inside it was missing half of the blades off the impeller. I remembered a year ago a coin had wedged in the pump which I took out and put back, not realising it had taken some teeth off the pump. Therefore the pump was not able to pump out the sudsy water very well which was staying inside the drum causing the suds light to come on, they installed a new pump for me, which was covered in the contract for free. Now it's working like new again.
Mar 06, 2012 | Maytag MAH2400A Front Load Washer
I keep getting either SUDS or the F35 code. I finally was able to get it to run so I ran it without detergent. Now I tried it again and it is back to SUDS again. Any ideas?
ok...run unit on rinse and spin only,,we need cold water,,if unit still shows sud error make sure drain hose is not kinked,,,if we still have a sud condiction or error ,,remove toe panel and clean filter.good luck
Sep 07, 2011 | Kenmore Elite HE5t Washer
The "clean" light blinks 8 times, then there is a pause, then it blinks once. The dishes are clean but not dry, as if it has not completed the drying cycle. We had an engineer out to fix it who said it...
I'm not familiar with Kenmore but it sounds like a faulty heater element. The flashing 'clean' light normally means a water flow problem (blocked pump etc) but since it's washing that isn't the problem. After washing they dry with steam, which needs a heater.
It may be a problem with the board, as your engineer thought, but i would sooner replace the heater, but they are not easy to reach.
A suds sensor may be present, should be a plastic grille or hole in the side or back wall halfway up, this you can flush with a garden hose, messy but it usually works!
Mar 28, 2017 | Kenmore Dishwashers
Tried to wash a load of clothes and keep getting an error code "sub". The machine will not complete a cycle, won't rinse, etc. What does the error code mean and how can I fix it?
SUDS LOCK (OVERDOSE OF DETERGENT
DETECTED DURING THE WASH CYCLE)
The motor control unit senses a suds lock condition by analyzing the
current draw on the drive motor. If “Sud” is displayed a potential Suds
Lock is detected. This may signify a bad pump, an extra heavy load,
excessive detergent, or excessive suds.
Possible Causes / Procedure
■ If too much detergent was used:
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Mar 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer say LG what dose that mean
My washer stopped and displayed the LE error code. I turned off the power button and tried again, but after a few seconds it want back to LE. Finally, I unplugged the power cord, plugged it back in, and the washer ran normally.
Dec 21, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washer displays code F 02 which means drain problem but the drain line is clear. Also displays suds but i ran with no detergent and it still says suds. Issue seems to happen right after rinse cycle before...
"F02" is a Long Drain error code. This indicates that you have an obstruction somewhere in the drainage system. In most cases this means you have a clog in the drain pump. The following link explains:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris and small articles of clothing can commonly clog in this area as well causing the drain cycle to fail. NOTE: The "SUD" error code can often occur in conjunction with the "F02" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error should go away.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
Oct 06, 2009 | Washing Machines
HE4t Elite F02 error code
its the error code for a long drain time most likely you need to check the filter in your pump for obstructions First if you have a wet vac pull the drain hose out of the drain spout and use the vac to pull the water out of the washer through the drain hose.If not you will need a pair of radiator hose clamps from the auto parts store. Pull the screws from the lower panel at the front of the washer and remove it.in side you will see a rubber hose coming down from the tub to the drain pump. Put the radiator hose clamp there if you didn't have a shop vac.On the front of the pump is a round part with a handle turn that and remove the pump filter .Clean any foreign objects out of the pump and look inside the pump to make sure no impeller blades are broken if any are you will have to replace the pump. put the filter back in and tighten it. If you had to use the hose clamp remove it now.reassemble and don't forget to give the tech his four boxes if this fixes it
Jan 25, 2008 | Kenmore Elite 45986 Front Load Washer
Error code SD
I work for an appliance company in the service department, and what this really means is that you could have a suds build up in your machine, or that you used too much soap on this particular cycle. If starting over does not work, you can buy a product called washer magic at almost any store and it will clean your machine out. Also, running vinegar through the machine will make any suds dissapate.
Nov 14, 2007 | Maytag Neptune MAH6700A Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
32 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
