Question about Bosch 11247 1916" Spline Combination Hammer
I have a bosch hammer drill and the hammer is not working
The hammer is not working
smjdragonfly
  • 79 Answers
SOURCE: Bosch VSR 1199 hammer drill keeps slipping in hammer mode
Inside there is a little plastic shaft, where the selector hooks to. They have had problems over the years stripping. Replacement part is still plastic. Yay! You may need a bearing puller or find some way to get the clutch off the shaft. Lemme know. Please rate me
Posted on Jun 18, 2009
harlan301
  • 205 Answers
SOURCE: New bosch psb 550 re with hammer action. Hammer
your pin under the selector switch my have broken off. also the hammer rod could have broken too. if its drilling and not hammering that more likely. you may be under warranty call bosch or log on and go to dealer locator's for the closes dealer to you. hope this helped
Posted on Oct 15, 2009
  • 211 Answers
SOURCE: Bosch GBH 2-20 SE hammer drill stopped working
hi
check the cord and the switch to have continuity,the wires,the brushes,the rotor and stator.
regards savumihai71
Posted on Dec 16, 2009
duane_wong
  • 6826 Answers
SOURCE: my bosch hammer drill 1199
Sure, it could be bad brushes or a broken connection inside the drill.
Posted on Aug 03, 2010
  • 70 Answers
SOURCE: Bosch hammer drill 1199VSR chuck
some drill bits have a certain way to be installed,if not put in correctly it will loosten up
Posted on Jun 12, 2011
Why bosch hammer drill not drilling
its possible the shaft used to engage the drill is broken, how old is the drill? Do you have it under warranty still? if its fairly new i'd return it and get a replacement for it.
Jul 20, 2014 | Bosch Drills
Hammer drill won't hammer
Without knowing which model you have: Most Bosch hammer drills use a plastic connecting rod to attach the piston to the rotating spindle. These are a common failure item and fairly easy to replace.
Jul 18, 2012 | Bosch Drills
I have a bosch hammer dirill that won't chip nor drill but motor run fine
Hi, have you tried the various positions on the front part of the gearbox behind the 'chuck'?
If so, then Im afraid it must go in for repair. These are not an easy fix and personally I would recommend you ask for a 'quotation' as it could be just something simple to do with the 'Gearbox' selector, but it could also be something a lot more serious within the Gearbox.
Good Luck & Best Wishes, John..
Jul 03, 2012 | Bosch 1" Sds+ Bulldog Rotary Hammer Drill...
What's your problem? rotary hammer will not hammer
Look for a lever that has signs hammer/drill or just drill Place the lever in the hammer position.
Feb 19, 2012 | Bosch Drills
How to chisel
The Bosch 1199VSR Hammer Drill is capable of drilling or hammer drilling at two different speeds but can not hammer or chisel only. To do that you need a demolition hammer or roto/demo hammer tool.
Jan 28, 2012 | Bosch 1199vsr 1/2'' Dual Torque Hammer...
I bought a used Bosch Bulldog hammer drill on the internet some time ago and discovered it's not hammering. It will drill be almost no hammer action. Any suggestions?
There is an o-ring on the striker that will wear down over time, this needs to be changed, of worst case the striker has stuck in the hammer piston. Both these repairs should really be done by a service center as these hammer drills are complicated to repair if you are not familiar with them. Any Bosch service center will be able to help you. Just go to the Bosch website and find a center in your area.
Jun 08, 2011 | Bosch 1" Sds+ Bulldog Rotary Hammer Drill...
Faulty bosch hammer drill
a bad trigger switch; bosch sells a replacement part
Jul 24, 2010 | Bosch Drills
hi
regards savumihai71
Oct 11, 2009 | Bosch Drills
New bosch psb 550 re with hammer action. Hammer action does not seem to engage. even with 5mm bit progress is non existent. The bits were bosch masonary bits and I was drilling into concrete blocks
Oct 09, 2009 | Bosch Power Tools Hammer Drills
Bosch 11247 Hammer drill works in drill mode but in hammer mode it spins as drill but does not hammer. Also how can I remove drive shaft from housing?
Usually replacing the o-rings on the piston, striker and Impact bolt will solve any hammering issues. That is considering there is no damage to the mechanical parts in the hammer mechanism.
Feb 27, 2009 | Bosch 11247 Factory Reconditioned 1 -...
Bosch 11247 1916" Spline Combination Hammer Logo
73 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
