Question about HP Pavilion dv2000t Notebook
Blank display on HP dv2000 laptop
I have a dv2000 laptop.It has a blank screen display problem. When I switch on the laptop,there is display for some time and then,I get a blank/blank screen.I tried connecting to external monitor.display is fine. Could it be the problem with my inverter/flex cable/LCD?
  • Geetha Jan 23, 2013
    pls note that my hinge is already broken.
    New Friend:
  • 7 Answers
I suggest you dismantle your laptop and take a look at the LCD cable behind the screen and make sure it is click locked.
Posted on Jan 23, 2013
Testimonial: "Thank you for the reply.I dismatled the Laptop monitor and saw that the cable running from the monitor to the keyboard broke near the hinge.I googled and found that this wire is the wifi cable.IS that true that my display wont work if the wifi cable is not working? or could there be some other problem?"
    Problem Solver:
  • 40 Answers
The symptom that you describe can be form three part.
Firs:
This happen more offen is when the ram is damage. Change the ram and see what happen. Or if you have to slot of ram can remove one and than check the other. a see what hapen.
Second:
The graphic card chip.
This issue normally happen when the laptop is overheated. So if your are working with the laptop and it overheat it with turn off automatically but can be damage the graphic chip. In this case you can resolve this open the laptop and heat it with heat gun.
(this section you need to be carefully)
Third:
Laptop screen.
Need to check if the problem is with the cable that connect the screen of withe the screen itself. if you start the laptop and it look start normally and you listen the song of windows start it mean that the problem is with the screen.
Posted on Sep 11, 2015
SOURCE: laptop screen in complete darkness but external monitor works fine
I have a problem with my hp laptop monitor's hinges, could you link where you were able to purchase those hinges?
Also, make sure you monitor's ribbon cable isn't missing any wires or that all of those wires are fully contacting.
Posted on Jan 16, 2008
SOURCE: HP laptop not booting up - blank screen
hi
I had the same problem faced twice in one month, and it’s a new laptop just one month old,
I have removed battery for for few minutes and fixed it back. And it's working fine now.
If it continues what should I do?
Posted on Nov 02, 2008
Murphybanton
  • 2004 Answers
SOURCE: Screen problem HP DV9000
Please perform system restore on your pc. Restore to factory default and remember to backup your documents.
rate this
Posted on Jun 04, 2009
joecomputer
  • 92 Answers
SOURCE: No display on hp laptop
Well, believe it or not. It's good news that it still works with the external monitor. That means it is not the video card which is embedded in the motherboard and is very expensive to fix. Here is a link to disassemble instructions for your motherboard. Scroll down till you see the dv9000's that should be your laptop. Good luck
Posted on Jul 13, 2009
bob_computer
  • 3153 Answers
SOURCE: Problem for HP HP Pavilion dv2000 15.4
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes P
c
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Hope this gives you the information you need
Bob
Moderator
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through FixYa.
Thank you
Posted on Dec 13, 2009
My computer won't start. when switch on it beep once and power comes but blank screen and stay that way, nothing happens. pls help thanks
Hmmm.. are u using an LCD monitor?
Did u try to use another monitor?
Even on start up, the BiOS didn't show up?
Tell me more...
Dec 03, 2010 | HP Pavilion dv2000 Series Laptop Full...
Blank screen on hpdv2000
hey claim your warranty on your laptop.
it has had a huge recall in the states to do that.
if you have time look up hp dv2000 problems on google
Jan 15, 2010 | HP Pavilion dv6000z Notebook
I have a HP pavilion Entertainment laptop and recently the screen went blank while the power was still on. I restarted and the screen continued to stay blank. I then turned the laptop off and unplugged it...
The connecting data bus between ur laptop monitor and ur motherboard has either been at fault or else there has been some problem with the wire connection between the two......i.e it has been loosen up....
Get ur laptop checked from the hp representative and if possible get ur laptop insured under different laptop policy schemes.....
With Regards
Abhineet Raj
Jul 29, 2009 | HP Pavilion dv2000 Series Laptop Full...
Screen is Black hard drive works screen lights up then goes blank
The Problem is that, your system is in STANDBY mode..bring it back..
This should solve your problem..
Jun 09, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
HP PAVILION DV2000 boot problem
Your could not be booting for several reasons anything from faulty RAM to software issues. Since you cannot boot to any type of working screen you will need to use the operating disc with XP or Vista on it. Put it in the CD-ROM and reboot. Let it run for a while and it will eventually ask you to install or repair. I would try repair first as if you install then you will lose all of your data, docs, favorites, pic, etc. if you have any questions let me know.
Feb 19, 2009 | HP Pavilion dv6000z Notebook
HP DV2000 screen going blank when try to restart my laptop
Check the swapping monitor function screen FN + F4 on Compaq.
It allows to change from internal to external or Both monitors.OR
Start in Safe mode with VGA basic settings and configure your Display settings.
Dec 14, 2008 | HP Pavilion dv6000z Notebook
Hp pavilion dv2000 notebook will not boot up
hi,
i m in Hong Kong. The stupid HP repair center charged US 90 just for inspection!!!!! They they said the whole motherboard had to be replaced, thts additional US 630 dollars, the thing is just 1.5 yr old. They also said i don get to keep the broken mother board after replacement. This is simply irresponsible, unethical, sleazy and UNJUST!!
Thanks. right now the computer is fixed for US70. when i hv time, i'll open it up and see if i can figure it out how it was fixed. The shop suggested tht the computer wont last too long. This is such bad quality for HP... Sorry, i hv to do the following for other victims to find this easily:
(can some creative netizen bring this to the public light to pressure HP to do the ethical things??)
bad quality HP. hong kong HP pavilion dv2000 series manufacture problem. HP unethical.
Sep 21, 2008 | Computers & Internet
HP Pavilion dv2000
If you're able to get a display on the external monitor, then your laptop's monitor has failed. (You'll need to replace the monitor.)
Please, post back w/ answers to the questions and let's see if we can get this issue diagnosed for you.
Apr 03, 2008 | Dell Latitude D600 Notebook
Freezing then blank screen
Have you tried pressing F8 on boot-up and log into safe mode under administrator, no password, and right click on any empty space on the desktop, left click on properties, left click on settings, select a lower resolution,( e.g. 1024X768 ) select apply, select ok, reboot, log in as normal
Mar 26, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP Pavilion dv2000t Notebook Logo
171 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
