Question about Dryers
This piece has a tear in the plastic part that snags clothes while drying. What is this part? Temperature sensor?
  • Dryers Master
  • 2,636 Answers
I suppose you are right.
Seems like every year they put more and more shut-offs on them to stop lawsuits from dryer fires.
If I had this problem, I'd try 3 things.
1) I'd see if I could take a Dremel tool and sand down the edges of the piece of plastic to keep it from catching the clothes.
Is it plastic?
2) I'd go to a hardware store to see if they have some epoxy that can handle extreme heat and try to "feather" the edges with epoxy.
3) Call the manufacturer and ask them for their fix, you gotta know other people are having this problem.
I think that is a Whirlpool or a Kenmore/Sears machine, by your picture.
Be blessed.
Posted on Jan 23, 2013
5 Suggested Answers
david04928
  • 102 Answers
SOURCE: whirlpool ultimate care II dryer: dry clothes sensor
Make sure that the vents are cleaned to include outside. Where it hook on to the dryer make sure that the housing is cleaned also. That should take care of the problem. Thankyou and if you need more help let us know.
Posted on Mar 16, 2009
canbruce75
  • 1776 Answers
SOURCE: Roper electric dryer. Clothes not drying. Temp ok/timer not?
I would supect a faulty high limit thermostat. This small round device is mounted to a metal plate and attached to the internal ductwork. It can be tested using a multimeter or ohmmeter. Test for continuity. It should have none. Hope this helped and best wishes.
Posted on Aug 11, 2009
MNfisherman
  • 11896 Answers
SOURCE: the temperature is low, couldn't dry the clothes
It is most likely the heating element will need to be replaced. You can test it first to make sure it is getting power that is constant
Posted on Oct 22, 2009
  • 530 Answers
SOURCE: One of the plastic pieces inside the drum is loose
take the kick panel off
look at the drum where the baffles are
are there screws holding them in
make sure you turn your power off first before doing this
let me know if you need more help
you can go to repairclinic.com and type in your model number to locate the parts you need
Posted on Feb 11, 2010
The dryer snags and tears up our clothes
Thank you for your post, friend!
From what you are describing it sounds like the felt may have come off your Frigidaire dryer. I would recommend seeking assistance from a professional to come out and properly repair your appliance. This would help avoid any unnecessary part purchases. -Matt
Oct 01, 2014 | Frigidaire Dryers
What is this dryer piece? It snags and tears our clothes.
That is your sensing electrodes. Senses the dryness of your clothes while in the auto cycles.
Sep 28, 2014 | Dryers
Electrolux gas dryer snagging clothes
Good Morning Friend,
I understand your Electrolux gas dryer, model# EIGD55HIW, is snagging and tearing your clothes. There is a possibility that the temperature is too high and you are overdrying your clothes. Make sure to dry your clothes on the correct temperatures and correct times. The other possibility is, the finish inside of your dryer has been scratched or chipped. This can cause a snagging or tearing of clothes. To prevent further scratching and chipping of the drum finish, make sure to always remove any foreign objects from pockets before laundering, as well as make sure zippers and fasteners are not hitting the inside of the drum. Hope this is helpful.
-Best Regards-
WP
Jun 21, 2014 | Electrolux EIGD55HIW Gas Front Load Dryer...
Icemaker stopped
Broken wires at the ice maker or the temperature sensor falling out can cause that problem. Check your digital temperature readout at the top of the refrigerator with the doors open. If it reads 88 88 and has a flashing digit, check the ice maker temperature sensor for a cut or broken wire. The temperature sensor and rubbery gadget holding it in place often fall out of place when the drooping wires snag on the ice scoop or whatever. The sensor assembly is held in place by a wimpy plastic clip that breaks easily. Sometimes the wires get cut or broken when this happens.
After fixing this problem several times, I finally made a metal bracket from aluminum angle, drilled and tapped 4-40 holes in it, and drilled the plastic icemaker to mount it more permanently. I added a wire tie to hold the temperature sensor wire up and away from possible snag sources. The sensor wire and wire tie are not shown in the photo below, but if you have the tools to solder the wires and fabricate a bracket it helps a lot. It is easy to get the ice maker out, once you discover how to remove the drawer from the slides (two plastic clips at the rear of the slides).
Pull the front cover off, take out the two screws, and unplug the wire connector and it drops right out.
Ice maker assembly upside down on bench.
Aluminum bracket and screws
Bracket installed. The sensor is not shown in this photo, but the wire comes out the right side and crosses in front of the metal bracket. The wire tie holds it to the bracket near the top center (hole not shown).
Sep 13, 2013 | Samsung Refrigerators
The hard plastic ring inside my Kenmore dryer has broken and it snags and catches clothes, can I remove this piece ?
You can remove but you need to replace the part or unit will get worse.Your clothes will start getting stuck
Sep 04, 2013 | Kenmore Dryers
Ice maker not making Ice.
z
2q==
z
Aug 18, 2013 | Samsung RS2630WW Side by Side Refrigerator
How to change the sensor on the LG DLE1310W
Moisture sensor? Why would you need to replace that? Is it tearing your clothes up?
Feb 08, 2013 | LG DLE1310W Electric Dryer, White, Super...
My towels are coming out of the wash frayed and coarse. My lighter cottons are all stretched out. What is causes this to happen and how do I repair it.
Hi
If your washer has developed a bad habit of snagging and/or tearing your clothes; before scrapping your washer, try these few tips:
1) Check, by hand, the smoothness of your washer. Look for any broken fins or roughness on the basket surface. Replace, if necessary.
2) Reduce the size of your loads. Heavy, cramped loads can cause a lot of friction which leads to tears.
3) Reduce the amount of bleach used. Bleach can eat holes in clothing.
4) Verify water level is not too low, especially during rinse cycle, where snags are more apt to occur.
5) Consider placing delicates in a garment wash bag
6) Front load washers have no center agitator, so they are less likely to tear clothes.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 16, 2011 | Washing Machines
I have 1998 bmw 323 the rag top has a few small snags in it. No tears just small snags that I dont wanrt getting worse.
If you don't want to hand sew the top then cloth adhesive will work to keep loose end from unravaling further. depending on the fabric and color I like a very small amount of either goop, contact cement, or a very small amount of superglue. for best results make a small repair in a not to noticable place and let it completely dry. then see what it looks like. if you don't like it don't do that again. Sometimes with contact cement you can hand mold the loose pieces after the glue starts to dry. goop dries a little quicker so you need to work pretty quick. superglue is the hardest to work with but done carefully it will give you the longest lasting and least showing result. be extra carefull not to get the glue on anything and make very small repairs one at a time.
Apr 23, 2011 | Car Audio & Video
Dryers Logo
Top Dryers Experts
