Hotpoint aquarius washing machine never gets hot water
The whole process takes 2 and a half hours no matter what number you put the cycle on. And the washing always comes out freezing cold.
  • Washing Mach... Master
  • 17,129 Answers
Possible that the HOT line is not working, check the hot water inlet line, Check the voltage to the heating element, check the element.
check the wiring.
Click on : Element
Posted on Jan 24, 2013
  • 209 Answers
SOURCE: Hotpoint Aquarius WF100 Fabric Cond not rinsing thru & PreWash lite flashing
this sounds like cold water supply not getting to the machine, test the supply from the house is working, is the machine buzzing slightly when it should be filling, if so the fault is the house supply to the washer, if the supply to the washer is fine, check the cold water solenoid for open circuit, thats about all it could be, if it worked fine before, if i have helped rate me please
Posted on Sep 18, 2007
SOURCE: hotpoint aquarius 1000 washing machine parts diagram
no current
Posted on Apr 15, 2008
jumptrout51
  • 3361 Answers
SOURCE: Magtag Washing Machine Can't use cold water only cycle
Stranger things have happened.
Glad it is working for you.
Posted on Apr 02, 2009
canbruce75
  • 1776 Answers
SOURCE: my washing machine will fill with hot water only,
Check for a cold water supply problem by taking a look at the water inlet valve. Remove the water supply hoses and check the small metal screens inside the openings on the valve (especially the cold water side). Make sure they are free of rust or debris. Check the solenoids. They can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad solenoid and the water inlet valve assy will need replaced. Sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 12, 2009
beltronic205
  • 1460 Answers
SOURCE: Hotpoint Aquarius WF560, goes through cycle wash
Could need new motor brush kit>
Posted on Oct 06, 2009
Hi, I've got a hotpoint WF000G which wont rinse properly on a fast wash, still soap suds on the clothing and have to put it on a full rinse cycle to get rid of them. Have tried clearing the filter (which...
Use very little detergent (HE) on a fast wash, about half the amount you usually do and set the machine to heavy instead of nomal, if yours has the settings for water level.The heavy setting uses more water. If your model does not have the normal/heavy settings, wash only very small loads on the fast cycle so that there is more water for the cycle. Also, be sure you are rinsing in cold, since cold water dispurses suds. You should also be sure that your rubber seal is very clean. I use a cloth and plain hot water and clean the seal weekly. It can build up alot of detergent residue as well as mold, etc.
Dec 18, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Machine will not do the whole cycle
Your machine is not gettjng water through the hot water valve.resolve this and it will work ok.
Nov 10, 2008 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint wd440 aquarius
Not all programes fill with hot water.Try on 95 degree wash if it takes hot water ,you are dialing a prog,that does not take HOT.
Oct 31, 2008 | Hotpoint Aquarius WD63 Front Load...
Water fill
if there are 2 hose connections then it is hot and cold fill. if only one hose connection, then connect to cold only.
if two hose connections, then connect at ramdom. put on rinse cycle. if hot water comes in, then connections are the wrong way round and just reverse them
Sep 03, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpiont aquarius wd420
not left on long enough or half blocked water outlet
Nov 15, 2007 | Hotpoint Aquarius WD640 Front Load...
HOTPOINT AQUARIUS WF250 1500 SPIN
check the cold water supply, either from the mains pipe, there is no water getting into the machine, if water is there up to the machine check the solenoid for circuit, to do this unplug from electric, remove lid, and test the two wires on relevant solenoid, no circuit means faulty solenoid, (test with the 2 wires removed from solenoid) take care note position of wires to put back properly answer above based on info given
Sep 24, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Sep 18, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
