Question about Jenn-Air JS42SEFXDA Stainless Steel Side by Side Refrigerator
Js42sefxda jenn air freezer dripping water from the top vent
I have a jenn air model js42sefxda it is at my second home and not in heavy use. I do have a pretty filled with food and it does not have the ice maker connected. Just recently it has started to drip from the freezer vent hole the large oval located on the ceiling near the front and drips down the shelves onto the bottom. It is not a consistant flow. I did remove the top grille cover and vaccumed the fins but there really wasn't much on them. Both sides are cooling properly and I did check to make sure that the vents were not being blocked both in the refrigerator and freezer side. Any help would be great.
  • 1,214 Answers
Check that the drain tube for the defrosted water is not plugged. Someone on here just the other day had the same exact problem, and that was the problem they had.
Posted on Jan 28, 2009
Jennair jsp42ppdbda faulty evaporator drip pan - leaking down into freezer compartment
I've got the same problem. After installing a replacement drip pan (W1019913) and disconnecting the thermistor per the enclosed instructions, the problem returned within two months. I just called Jenn-Air customer service and was told that there is a new design for the drip pan this is only available through Jenn-Air, and not through distributors. Therefore the part I purchased in November through a distributor was the old design (even though it was dated 1/27/11).
The Jenn-Air rep agreed to have a tech install the new design under warranty, even though I purchased the unit almost 5 years ago. I'm hopeful that this will correct the problem.
If you still want instructions on how to remove the drip pan, let me know. But I would return the part you've got and ask Jenn-Air do it for free.
Dec 14, 2011 | Jenn-Air JCD2389G Side by Side...
Jenn-Air js42sefxda. Freezer and fridg won't cool. Ice was built up at the top of the freezer. I turned it off for 24 hours and once the ice melted it operates normally. How do I prevent the ice...
There is a defrost timer that normally controls the defrost cycles.
It appears that the defrost timer has failed. A new timer needs to be fitted. a technician can help you with that
Mar 24, 2011 | Jenn-Air JS42SEFXDA Stainless Steel Side...
Best thing to do is pull the plug for 24 to 48 hours. Put towels on floor to **** up the melted water. Plug back in and if everything works the drain is clear. If it refreezes then the defrost timer is bad which is not a cheap cure.
I hope my suggestions helps and all the luck to you.
Dec 23, 2010 | Jenn-Air JS42SEFXDA Stainless Steel Side...
Jenn Air JTB2488AE Freezer Top refrigerator. Water puddles inside the refrigerator space beneath the vegetable crispers. The ice maker has been turned off and the water still appears. The amount of water...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Sep 04, 2010 | Jenn-Air Refrigerators
Water dripping inside top of refrigerator.
if freezer is on top what is happening is your drain hole behind freezer panel is clogged
Nov 11, 2009 | Refrigerators
My jenn air freezer is not making cubes. the
The water inlet valve may be staying open. You can swap the wires on the dual water inlet valve and disconnect the water line at the valve which goes to the ice maker. When you try the water dispenser the water will come out there. When you stop the water dispenser, if the water at the valve doesn't stop, the valve isn't closing so you'll need to replace it. If it does stop after trying it several times then the problem is with the ice maker.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Jul 13, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Cold freezer/warm refrigerator
Same problem with Frigidaire Gallery model#GLRT182SAW5 (dated 2002 on back of case)
Vents were blocked with ice. Vents (from top compartment to lower) located behind light. You can check by poking a chopstick up the (2) holes; be careful not to hit fan blades.
- took freezer coil cover off in back; checked that defrost heater element was working (marked and rotated the timer in the hole next to light); checked that fan working. Found ice in the vents and defrost drip area. Got it out with hair dryer.
- cleaned compressor coils in back (check fan is rotating; also tweaked some of the compressor tubing bends to make them more smooth - read somewhere about a manufacturing defect ...); blew out drip tube from defroster while down there.
- Set the freezer control to WARM and the refrig control to COLD (THIS SHOULD IMPROVE AIR FLOW FROM TOP TO BOTTOM).
- Put thermometers in top and bottom. Checked that refrigerator cycles (not running continuously). Checked that cold air is coming down from (2) vents behind light.
OK: so far, so good. Lower compartment is 40 or under. Top is under 18.
CONCLUSION: Suspect marginal design. Had problems with another similar model where defroster ice doesn't drain correctly, pools and refreezes. Leading to blocked vents as well as blocked defroster drain and similar problem including dripping water from top to bottom and warm bottom.
Nov 12, 2007 | Frigidaire Refrigerators
Jenn-Air Glass Door - How to Clean
Sounds familiar. I saw this thread this afternoon while trying to clean my own oven window. My sense is it is definitely a design flaw. It's just too easy to drip something down the top door vents onto the inside of the multiple glass panes.
Here's what I did. I removed the door, following the manual instructions. Open the door to 1/4 and lift it up. Then I put it down on a soft surface and started removing screws until it came apart. It wasn't too complicated though it took some time. Be sure to keep track of your screws as you do this as there are a few different kinds.
Aug 28, 2007 | Jenn-Air Jenn Air French Door Floating...
Jenn-Air JS42SEFXDA Stainless Steel Side by Side Refrigerator Logo
212 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
