Question about Electric Neiko 02845 Breaker Demolition Jack Hammer Kit
Replacing handle on Neiko electric demolition hammer
Jackhammer is not hammering
Its need service if its anchor / drive gear is worn or the o-rings seals are worn, if its this model hammer make a trade-in service that in case its an old hammer like this model its not the model to service by your one the best option is trade-in by your dealer. if its handle this model
http://dasen-hammer.en.made-in-china.com/product/BMgJKvoEXFpm/China-High-Quality-11e-1500W-Electrical-Demolition-Hammer.html
Mar 27, 2014 | Hammering
Can not get braker bit out of dewolt hamer
Use a burner to make the work a little bit lighter but wear safety glasses by this job en een leather apron because of the hard metal pieces that can be come of the chisel sometimes if its an heavy machine unmount first the sleeve, from the machine if you have luck to find somebody with a bearing press can make it come loose , but if its handling a little demolition hammer replace the locking sleeve the drill guide is most times worn if you have used the right chisel for your machine.
Mar 06, 2014 | Electric Demolition Jackhammer
The service light is on and the power is not steady
1 of the 4 electric sliding contacts of the electric field was broken .
Sep 17, 2013 | Bosch 11317evs ¾" Elec Vs Hex Demolition...
Hammer not Jacking
Mine stopped and I took it apart and found a badly worn piston gasket. I can't however find a new gasket. Anyone know where to get parts for the sky687 hammer drill then let me know. Copipeworks@gmail.com
Sep 18, 2012 | Heavy Duty 1240w Electric Demolition Jack...
Makita wire come out
Hi dean
Do you mean a Mkaita 1304b? Is it just the main cable that has come out? in which case you can undo half of the handle and reconnect it to the switch.
May 25, 2012 | Makita Hm3104b 35lb Demolition Hammer +...
Need to change the brushes in my chicago breaker hammer
If change brushes it has having its workinghours Use a service kit for your model if there is support for your hammer ??? on EBAY there is a set brushes parts are maybe hard to find for electrical demolition hammer of this brand.
Carbon Brushes Chicago electric UL breaker jack hammer NEW 46935 harbor...
Jan 30, 2011 | Electric Demolition Jackhammer
I can't find motor brushes for the jack hammer. Any idea where to look?
You should be able to go to an electric motor repair shop and they can order them for you.Also check tool repair shops in your area.
Oct 19, 2010 | Electric Neiko 02845 Breaker Demolition...
Which is the best rotary hammer drill to buy
Hi
yes it is a good tool all deppend on what kind of work you want to
do with it ,
just remamber this is not a jack hammer it is a light impact
Hammer Drill. and it is a problem free if it used for the right
work and load.
Apr 09, 2009 | Neiko Tools USA 6500W-Run 8000W-Peak...
Electric Neiko 02845  Breaker Demolition Jack Hammer Kit Logo
37 people viewed this question
Top Electric Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
Dan Webster
Dan Webster
Are you an Electric Hammering Expert? Answer questions, earn points and help others
