Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Whirlpool side by side is not working, cold air is blowing from bottom of unit under freezer, there is a click like something is trying to start
  • Whirlpool Master
  • 2,694 Answers
If everything is melting inside freezer and you hear a clicking sound most likely you have a bad start device located on the side of the compressor,unplug it until you repair it or you can damage the compressor,pull out the machine.unplug it and remove the bottom panel,look at the compressor,you'll see a metal clip holding a cover onto the start device,pop the clip off,remove the cover and then slide the start device off of the compressor,there's three pins on the side of compressor,the device slides onto the pins,when you have it off of the compressor,the easiest way to check it is to shake it,if you hear pieces rattling around in it it's cooked.next time send the model number and i can look up your machine,open the fridge door,look up on the right hand side of the wall up near the ceiling,you'll see the model number,you'll need this to get the correct part.
Posted on Jan 23, 2013
  • 86 Answers
SOURCE: Whirlpool bottom freezer - freezer working but fridge not cold
Hi check to see if the unit has 2 compessors! If so then remove the plug from the mains and remove the thermostat housing in the fridge compartment and join the live and common wires together and switch on! It then should start to freeze down. Just get a new stat if this happens and replace it. Becarefull not to bent the log capilary wire as this has a liquid in it and any kink in the wire will mean you will be buy another one..
Good luck....
Posted on Dec 29, 2008
mikedurland
  • 481 Answers
SOURCE: freezer working fine, but no cold air to fridge
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control unit
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Posted on Jun 29, 2008
  • 115 Answers
SOURCE: freezer quit then noticed fridge side not cooling
the relay on your compressor is bad go behind you refrigerator and take off the the bottom panel the relay is on the left side of your compressor usually
Posted on Dec 30, 2008
  • 9 Answers
SOURCE: whirlpool fridge not cooling gone warm air blowing
more than likely the compressor is not starting, it has a starting device on the left side of the compressor which has a relay/overload called a relay, remove the relay and shake it , if it rattles it has gone bad. the relay/overload combination has gone bad and can be replaced with pro41 relay. if the compressor has a run capacitor just eliminate the capacitor when replacing with new relay. connection of the two wires makes no difference.
Posted on Jan 28, 2009
  • 363 Answers
SOURCE: whirlpool freezer not freezing
The fan speed can be deceptive. That is why this problem is so hard to diagnose, when the fan starts to wear out the motor spins but not with enough force to circulate air thru the freezer and rrefrigerator. If you have the ability to swap out the fan motor then it should only cost you the price of the motor and components. Approx. $125.00 if you have the make and model you can go to appliancefactoryparts.com or appliancefactorypro.com to obtain motor and components, But if you have to get serviceman to replace fan it will cost you an hours labor also.
Posted on Jul 28, 2009
Freezer not freezing clicking noises
Almost certainty you have a rear control board fault these boards where notorious for capacitor faults causing relays to click and water dispenser to be erratic , the board can be repaired by a confident electrical engineer or you can buy a complete unit
Mar 31, 2017 | Whirlpool Refrigerators
Hi, my whirlpool side by side refrigerator is not cooling. I cleaned all dust and debris from under unit and coils but it is blowing cool air out of the bottom grate and warm air inside freezer and...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 02, 2011 | Refrigerators
Whirlpool topfreezer refrigerator is not working fan is blowing but no cold air.. already tried cleaning the coils underneath the front and back of unit....plugged it back in and waited three hours and its...
heatman101
Jun 03, 2011 | Whirlpool ET8WTEX Top Freezer Refrigerator
Blowing cool air not cold.freezer not freezing
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Feb 01, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
My fridge is blowing air but its not getting cold. i had someone replace a part, something 3 in 1 dont know the exact part but it worked for a month then stopped getting cold again. what could be the...
Refrigerator
heatman101
Jan 12, 2011 | Whirlpool GS6NBEXR Side by Side...
Bottom of fridge and freezer cold ice maker not
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Nov 28, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator is not cold on top, but still cold on bottom.
Sounds as if you have a bad evep. Fan motor. It souldnt by over $40.00. And if the unit still look and works good other than this problem. It's located behind the inside back freezer panel. Diffaculty level in my opinion is a 5 out of a scale of 1 to 10. 10
Aug 28, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
56 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
