Question about GE Bluetooth In-ear Headset Wireless Headset
Pairing ge 86710
For some reason I can't get my kyocera lingo to pair with this bluetooth. eveything goes smoothly untill the pairing. any advice?
  • 679 Answers
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select 86710once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Posted on Jan 31, 2009
Tip
How to get your ge ear piece to connect
How do I link my GE Bluetooth in ear style headset, model 86707 or 86710?
Answer :
Turn on the mobile phone and place within 10 ft of the headset.
With the headset turned off, press and hold the Talk button for about 7 seconds. You will hear a "pair" tone and the LEDs will flash continually to indicate the headset has entered into pairing mode.
Release the Talk button. The headset is now is "pairing" mode.
Initiate the device discovery feature (Bluetooth discovery) on the mobile phone. Refer to your mobile phone manual for further instructions.
When prompted by the phone, enter the headset passkey (0000). When pairing is complete the LEDs on headset will flash at 3 second intervals and the headset will be placed in standby mode, ready to make and receive calls.
Note: On some mobile phones you will need to activate the Bluetooth feature first and then search for the Bluetooth device. Please contact your cell phone manufacturer or the User's Manual for further information on how to pair pair Bluetooth devices.
Click to view the instruction manual for:
86707
86710
on Feb 28, 2008 | GE Bluetooth In-ear Headset Wireless...
Turn on bluetooth
put the headset into pairing mode. while it is off, press and hold the answer button for 5 seconds (remember: FIVE SECONDS) until you see the LED flash then try to pair it with your phone.
Apr 29, 2013 | Kyocera KYO100 Bluetooth Headset
I have a kyocera bluetooth and I lost the code to pair it with my phone how can I find it? 739G-001 is on the headset. I can pair it with my phone if I can find the passkey I have a samsung phone. The...
I just paired one that sounds like yours with my phone and don't remember needing a pass code, but try 0000
From the quick start guide at:
http://www.kyocera-wireless.com/support/pdf/bluetooth-kyo105-quick-start-guide.pdf
PAIRING THE HEADSET WITH YOUR CELL PHONE
Note: Ensure your headset is powered off, and your cell phone is powered on.
a. Press and hold the Multi Function Button for 6 seconds until the LED Indicator flashes red and blue. A tone will sound indicating your headset is in pairing mode.
b. Activate the Bluetooth connection from your cell phone. Execute the search function to search for Bluetooth devices. When the search completes, a list of supported devices will be displayed on your cell phone screen.
Note: The headset will not be detected unless first placed in
pairing mode.
c. To start the pairing process, select KYO105 from the device list.
d. When prompted select 0000 as the passkey.
Jul 18, 2010 | Samsung Lands Phones
Pair bluetooth em227 with my phone
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above. Then you can discover it with your phone. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Mar 05, 2010 | Southern Telecom Emerson Bluetooth Headset...
Connect ge bluetooth to blackberry pearl
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Jun 24, 2009 | GE Bluetooth In-ear Headset Wireless...
GE Bluetooth connectivity
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Explorer 3XX device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Hope this helps
Season's Greetings from Fixya
Chris (ziraffa)
Dec 26, 2008 | GE Bluetooth In-ear Headset Wireless...
Phone ask for passkey to connect bluetooth
This is more an issue with your phone service provider than it is with the Go 730. You may have previously set a password for your phone's Bluetooth feature. If you can't remember it, you should be able to troubleshoot over the phone with your service providor's customer service, or just take it into a store to get the info back. Once that's fixed, you should be able to pair with your 730 without a problem
Oct 22, 2008 | Tomtom GO 720 GPS Receiver
My phone
Pairing your Cell Phone to your
Bluetooth Headset:
(FROM Bluetooth Headset)
1. Make sure Bluetooth Headset is fully charged!
2. Hold down talk button (center button of headset) up to
(Five) 5 seconds, then WAIT until you see a solid blue
light then immediately flip open earpiece part of headset.
THIS MEANS the HEADSET IS NOW IN PROGRAM MODE.
AT THE SAME TIME/ WHILE BLUETOOTH
IS STILL OPEN & IN PROGRAM MODE….
(FROM CELL PHONE)
1. Click on “Menu” (Left Button)
2. Scroll to Bluetooth icon. (Lower Right Hand side of menu)
3. Click “Ok” button
4. Then click on “My Devices
5. Click “OK” again
6. Select “FIND NEW”: Cell phone searches/connects to pair up
with Bluetooth Headset.
7. Once your Cell phone discovers your new headset, select
ADD” or click on the recently paired headset device.
8. You will then be prompted to enter a pairing code.
Use either..
a. 0000 or
b. 1111 or
c. 9999
Congratulations on paring/ connecting your new
Bluetooth Headset
w/ to your new Cell phone!
Jan 16, 2008 | Kyocera Switchback KX21 Cellular Phone
GE Bluetooth In-ear Headset Wireless Headset Logo
164 people viewed this question
Top GE Radio Communications Experts
Greg Cann
Greg Cann
eradiostore
eradiostore
J.D. Browning
J.D. Browning
Are you a GE Radio Communication Expert? Answer questions, earn points and help others
